Creaking door behind dash
Discussion in '2nd Gen Tundras (2007-2013)' started by CoMo78, May 1, 2020.
  1. May 1, 2020 at 8:10 PM
    CoMo78
    CoMo78 [OP] New Member
    Have a troubleshooting opportunity on a 2011 5.8L Crewmax 4x4: There’s a weird “creeping door” noise that comes from behind the dash to the right of the wheel. It happens in a few seconds when the engines starts and a few minutes after the engine is turned off. Makes me think something’s being energized/de-energized. I just bought the truck and there’s magnets below the rear window button - I think they had something installed that required them to remove the dash.
    Thoughts?
    Thank you!!!
  2. May 1, 2020 at 9:35 PM
    Hillbilly Taz
    Hillbilly Taz New Member
    Glenn
    AL
    2011 Tundra SR5 DC, Silver Sky, 4.6 L V8
    Westin Steps, Tonneau Cover, Vent Visors, Go Rhino Dominator Step, Husky X-act mats
    Hopefully someone will chime in soon.
  3. May 1, 2020 at 9:40 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    It’s the actuator for the vent system. It’s basically opening air ducts and closing the air ducts. At least that’s what I thought it was.
  4. May 1, 2020 at 10:30 PM
    CoMo78
    I read there was something that only happened if the thermostats were sync’d, but I hear it either way.
    Is it ironic to go from a Tacoma TuRD to a Tundra non-TuRD that farts when you turn it on and off?
  5. May 1, 2020 at 11:05 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    this; common in the 4runners as well.
  6. May 2, 2020 at 4:26 AM
    Adam New Member
    Yup, blend door actuator. Nothing bad is happening.
  7. May 2, 2020 at 5:58 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Actuator ghost..
  8. May 2, 2020 at 6:54 AM
    Failure2comply
    Failure2comply Master HVAC Tech
    VA
    2008 Tundra Crewmax Limited w/factory 20" wheels
    Trailer brake. Limousine tint in rear windows. Ultra Gauge "Blue". Toyota bed mat and bug deflector.
    This...
    Tundyfundy[QUOTED] likes this.
  9. May 2, 2020 at 11:04 AM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    Agreed the actuator for the vent system. May be time for a new one. A friend tried to fix this issue on a different vehicle but ended up replacing the actuator. If you can get in there without too much trouble you might be able to lube the actuator shaft, so it operates smoother. The only problem with these units is most of them are plastic and once worn they need to be replaced.
    Tundyfundy likes this.
