creak noise on acceleration
Discussion in '2.5 Gen Tundras (2014-2021)' started by erikog76, Jan 29, 2018.
  1. Jan 29, 2018 at 7:34 PM
    erikog76
    erikog76 [OP] New Member
    los Angeles
    2017 tundra 2.5 in lift front 1 in rear
    trd wheels 2.5 inch front lift 1 in rear block
    fellas I 100% figured out my creak noise on my 17 tundra. you could only hear it in the cab and it always came from high passenger side behind dash. only noticeable from a complete stop and take slight take off. well after lubing, torquing, and spinning my wheels. I found it. the eco harness grommet that hangs off the firewall on a bracket with 3 10 mm bolts. well that rubber retainer would creak when the engine would shift under load. finally. hope this helps someone else,
  2. Feb 27, 2018 at 10:20 PM
    Tundra83
    Tundra83 New Member
    2016 platinum tundra 5.7
    I found the same problem on my 2016. I put a zip tie around the grommet and bracket. I went for a drive and no noise3266F0C0-060B-43D2-9841-ED0132DF6ED2.jpg
  3. Feb 28, 2018 at 10:44 PM
    Stuffs
    Stuffs New Member
    I did the same thing. Its actually the ECU housing that is making the rattling sound. The way the harness is attached to the bracket transfers engine vibrations to the firewall creating the weird but annoying rattle. Zip tying it instead reduces the vibrations transferring to the firewall. I found that out but leaving the hard clipped in, wrapped a tshirt around the ECU from under the dash and the noise went away.
    TrdSport20 likes this.
  4. Mar 1, 2018 at 5:53 AM
    Now if I could just find my 10mm socket!!!
    Nice find OP. Thanks for sharing.
  5. Mar 1, 2018 at 12:23 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Haha my 18 had the exact same issue! It was driving me nuts!
    erikog76[OP] likes this.
  6. Mar 1, 2018 at 1:23 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Trade them in for a 2016. Mine has no such problem. :)
    Tundraman479 likes this.
  7. Mar 1, 2018 at 1:26 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    I haven't noticed this on my 2018, but now I'll know what to do if it ever creeps up. Thanks!
  8. Mar 2, 2018 at 6:30 AM
    Stig
    Stig New Member
    I wrapped the ECM and did the zip tie thing. Still the same creak, rattle, tap, ticking noise
  9. Mar 2, 2018 at 7:26 AM
    Ladicius
    Ladicius New Member
    2014 MGM Platinum
    I was wondering what the creak was under acceleration, I'll do this and see if it solves my issue, thanks!
  10. Dec 15, 2018 at 1:14 PM
    FlyFisher1966
    FlyFisher1966 New Member
    Fabio
    Tundra Trd Pro
    I Have A 2015 Pro
    Having The same issue.Thanks for Posting I would have never have figured it out .
    Rather than zip tie I thought I would try soaking with some wd40.Wala it worked! Creak Is Gone!
