Crazy noise from dash
Discussion in '2.5 Gen Tundras (2014-2021)' started by RUSTY1130, Jan 18, 2023.
  1. Jan 18, 2023 at 4:33 AM
    RUSTY1130
    RUSTY1130 [OP] New Member
    2014 trundra 1794
    TRD Intake TRD exhaust. 7in BDS lift fox 2.0 on 37x12.50x20.
    Need help with a noise coming from dash. It happens between 20 miles per hour and 40 miles per hour gets louder up to 40 miles an hour goes away under 20 miles an hour and above 40 miles an hour. Sounds like it's coming from inside - under windshield center speaker area. It's not the radio it's not the heating system I've disconnected all of that even down to my gauge cluster and it still happens. Almost sounds like a buzzing/whining noise
  2. Jan 18, 2023 at 4:43 AM
    RUSTY1130
    2014 trundra 1794
    Here is the sound.
  3. Jan 18, 2023 at 4:48 AM
    RUSTY1130
    2014 trundra 1794
  4. Jan 18, 2023 at 5:17 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Ok that's weird. Sounds like really bad electronics interference. Did you upgrade any electronics around the time this started? Is your windshield cowl damaged?
    Saltyhero13 likes this.
  5. Jan 18, 2023 at 5:23 AM
    RUSTY1130
    2014 trundra 1794
    No. I've removed stereo completely. Definitely not wind noise. Driving with stereo out sounds to be behind it.
  6. Jan 18, 2023 at 5:30 AM
    MadMaxCanon
    Try covering opening?
  7. Jan 18, 2023 at 5:56 AM
    That sound isn't coming out from any of the speakers? I has something similar a few weeks ago. It was a bad RCA cable.
  8. Jan 18, 2023 at 6:03 AM
    RUSTY1130
    2014 trundra 1794
    No I've dis connected all speakers also. Lol it's driving me crazy
  9. Jan 18, 2023 at 6:04 AM
    I hear you. I have a noise near my pillar and left dash speaker area, and it's not the door hinge. :notsure:
  10. Jan 18, 2023 at 6:06 AM
    RUSTY1130
    2014 trundra 1794
    Yeah I've literally had almost the whole -Dash out and still cannot figure it out it's like there is an internal wall between the firewall and behind the stereo.
  11. Jan 18, 2023 at 7:09 AM
    RUSTY1130
    2014 trundra 1794
    Seems to be behind stereo
  12. Jan 18, 2023 at 7:15 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Does having the wipers on have any effect on it?
    Does it do it when it's raining?
    Not saying this is your issue but;
    We have some tractors at work that sound just like that when you get up to highway speeds.
    It's the rubber molding around the top of the windshield.
    I have to put gorilla tape all the way across the top of the windshield rubber to make it stop.
    Took me 5 years to figure out what it was.
    That noise would drive me insane.
    Good luck
    1UP and RUSTY1130[OP] like this.
  13. Jan 18, 2023 at 7:17 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Sounds mechanical to me. Check cabin blower, driveshaft, axles, everything else rotating?
    RUSTY1130[OP] likes this.
  14. Jan 18, 2023 at 7:22 AM
    RUSTY1130
    2014 trundra 1794
    I've checked all the above. All seems good. I've unplugged everything I could think of and still hear it. It starts at 20mph and goes away over 40mph.
  15. Jan 18, 2023 at 7:24 AM
    RUSTY1130
    2014 trundra 1794
    I brought at once to my local Toyota dealer they told me it was the stereo. I brought it back without the stereo in it and said what is it now. They want it for a full day's labor to diagnose not happening.
  16. Jan 18, 2023 at 7:36 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    When you say you've had all the speakers disconnected, did you disconnect them physically at the speaker? Or they still go to the amp and what you did is disconnected the head unit from the amp?
  17. Jan 18, 2023 at 7:38 AM
    RUSTY1130
    2014 trundra 1794
    Yes at the speakers in dash. And the stereo completely out from harnesses
  18. Jan 18, 2023 at 7:42 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Does the noise change with engine RPM? Try to shift manually (or rather prevent shifting for a bit longer) and see if 20-40 MPH noise moves.
  19. Jan 18, 2023 at 11:23 AM
    RUSTY1130
    2014 trundra 1794
    Stays the same
  20. Jan 19, 2023 at 7:32 PM
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    Super frustrating - I hope you get it solved. Please post an update if you figure out.
    Does the noise happen when in P/N when revving the engine? Does engaging 4wd change anything?
    While driving and the noise is happening, if safe, can you shift into neutral and see if still present?
  21. Jan 19, 2023 at 7:41 PM
    Sounds like a reed vibrating. My wife’s Jeep GC did this and it turned out to be the rubber seal at the top of the cowl / base of the wipers. I ran a strip of gorilla tape across the seal and it quit. New cowl is $400. F that noise. Worth trying to tape the windshield seal and driving it again. Hers was most prominent around 55-70mph.
  22. Jan 19, 2023 at 7:51 PM
    RUSTY1130
    2014 trundra 1794
    Only happens while in drive. Not sure about the 4x4 . I will have to try and see. But I've also jacked it up off ground while in place sitting still and still happens so definitely not wind.
  23. Jan 19, 2023 at 8:02 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Did you have the hood open when you did this? Noise generated from outside coming into cabin, or only icom9ng from n cabin?
  24. Jan 19, 2023 at 8:08 PM
    RUSTY1130
    2014 trundra 1794
    Seems to be only inside..
  25. Jan 19, 2023 at 8:09 PM
    1UP
    1UP Truck Gang
  26. Jan 20, 2023 at 5:32 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Definitely sounds like something thin vibrating to me... have you checked all your heat shields and underbody fittings - running board mounts, skid plates, etc?
    I have learned that sounds can be very deceiving. I chased a rattle that I was SURE was in my dash or mirror mount, only to find later that it was just a tape measure inside my center console... It sounded like it was in front and above me, but it turned out to be next to me and below...
    Good luck.
