Crazy Door Locking Situation
Discussion in '3rd Gen Tundras (2022+)' started by iiawah808, Dec 2, 2023.
  1. Dec 2, 2023 at 6:22 PM
    iiawah808
    iiawah808 [OP] New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    Delete
  2. Dec 2, 2023 at 7:06 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    What else has happened with the truck? Glad you got it opened up!
    Kap1 likes this.
  3. Dec 2, 2023 at 7:08 PM
    doublethebass
    doublethebass New Member
    Minneapolis
    2017 Tacoma TRD Pro 6MT
    yikes dude - that's scary. Not sure what happened, but glad your kid was ok.
    pwpblue likes this.
  4. Dec 3, 2023 at 12:35 PM
    xc_tc
    xc_tc New Member
    I would try to recreate this again (with windows rolled down). Seems really strange. My truck won’t lock if I use the sensors on the door handles and the key in the center console.
    TundraDan723 and pwpblue like this.
  5. Dec 3, 2023 at 12:44 PM
    firehawk003
    firehawk003 New Member
    Did you try putting your finger on the lock/unlock sensor on the top front of the door handle? Also, was it raining? I often have the doors lock/unlock when washing the car if the water contacts that same area of the door handle.
    GODZILLA and pwpblue like this.
  6. Dec 4, 2023 at 12:35 PM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    One thing to keep in mind is keeping cool. The fob was in the truck, so hopefully near a sensor, and you need to place your hand on the door handle for a few seconds. If you yank quickly, it does nothing.
    I wonder if its some sort of wash/wax coating that folks use on their vehicle that keeps an electrical charge and leads to unintended unlock/lock? I am not a nerd so can’t use technical terms but I guess a way to test that theory is to carista it and turn off keyless entry.
  7. Dec 8, 2023 at 9:55 AM
    TFRK9TUNDRA
    TFRK9TUNDRA New Member
    B
    2023 platinum
    Have you had any other door locking issues? My drivers door randomly locks (2023 new platinum).
  8. Dec 8, 2023 at 1:24 PM
    iiawah808
    Oahu, HI
    I did tap the sensor on the two front doors while trying to open. That did nothing.
    I did keep cool for the first minute until it sinked in that I couldn’t open the door while and my 2yo daughter was locked in her car seat, locked in a truck in hawaii 90 degree weather.
    Then after several more minutes after that, I’m panicking.
    I’m sure anyone would lose their cool or it could just be me. Idk…I love my daughter quite a bit.
    Leo's first likes this.
  9. Dec 8, 2023 at 2:51 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    So glad your daughter was Ok in that hot and humid environment.
    -The door touch sensors should not work unless the Fob is on your person/body.
    - The doors should not lock even if closing a manually locked door when a Fob is inside EXCEPT if the doors are locked from inside with a door switch. (you can lock yourself inside manually with your Fob inside with you)
    - Why the truck locked itself and then unlocked 10 mins later on its own makes no sense. Something is shorting causing it to lock/unlock automatically. Could it be the door switch in the door you used to load her?
    Was there a second Fob involved ?
    Very odd. Gremlins….
    iiawah808[OP] likes this.
  10. Dec 8, 2023 at 3:02 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Sorry to hear this happened to you.
    Not a Tundra, but a Duramax has done this while we were way up in the mountains. We now have hid-a-keys under the vehicle in case this happens. Have never been able to figure out why or what to fix.
    The truck has the nick name of Ghosty Locks.
  11. Dec 8, 2023 at 7:34 PM
    iiawah808
    Oahu, HI
    I seriously cannot figure out what happed or how.
    I changed the batteries in both my fobs for the time being and looking into getting into another vehicle.
  12. Dec 9, 2023 at 8:20 AM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    I’ve noticed that if a door is partially closed it will lock but not respond to the door handle. Pushing the door that isn’t closed all the way shut enables the door handle.
    aj350925 likes this.
  13. Dec 9, 2023 at 8:35 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My wife's Pilot has the same sensors in the door handles and push button start and whatnot. I don't see any reason not to keep the fob in my pocket the entire time I'm using the vehicle.
    jcm1689 likes this.
  14. Feb 1, 2024 at 7:47 PM
    Airbender
    Airbender New Member
    2024 Tundra XP
    2024 Tundra Xp Quad, One crazy anomaly, at approximately 8:40pm (EST), went to vehicle, which was parked inside my home garage, used remote to unlock all doors (double tap on remote). Opened driver door, partially stepped inside and started vehicle. After start, place key/fob in the small tray on center console, closed door, went back inside to allow vehicle to warm for a few minutes (45 degree
    temp). When I returned to vehicle, it was locked tight as a "zipped jacket," engine running key fob in plain view. I walked around entire vehicle to ensure this was really happening (engine running, doors locked, fob inside). Couldn't do anything about it, second key/fob was NOT accessible to on this evening. So the vehicle for approximately 30+ minutes before auto shut-off. I was hoping it would self unlock if the engine shutdown, no-can-do! I ended up having to call a vehicle service to unlock the doors, given I had an early morning appointment to keep. Anyone else with this mysterious anomaly? I do have phone video of the entire event.
  15. Feb 1, 2024 at 8:51 PM
    Tundranewcomer
    Tundranewcomer New Member
    ‘22 MBM Platinum w/ power running board and advanced package
    There’s a thread on this.
    Mattedfred likes this.
  16. Feb 3, 2024 at 5:02 AM
    22whatwedo
    The Open Road
    Did you try the unlock on the App?
    pwpblue and iiawah808[OP] like this.
  17. Feb 3, 2024 at 6:18 AM
    DRP
    DRP Old Member
    Dave
  18. Feb 5, 2024 at 7:56 PM
    Tundranewcomer
    Regardless of who posted first his thread has 3 pages. I don’t think there are any solutions on it but sounds like you didn’t know there was another thread before. Not even sure everyone is having the same exact problem.
  19. Feb 7, 2024 at 6:35 PM
    Tundranewcomer
  20. Feb 7, 2024 at 10:02 PM
    boblc123
    boblc123 New Member
    2024 Tundra Limited 4x4
    butthurt much?
    doublethebass likes this.
