Crankshaft position sensor
Discussion in '1st Gen Tundras (2000-2006)' started by Cr2008, Apr 16, 2017.
  1. Apr 16, 2017 at 3:55 PM
    Cr2008
    Cr2008 [OP] New Member
    2008 tundra
    Location of the crankshaft position sensor on a toyota tundra 2008
  2. Apr 16, 2017 at 3:55 PM
    Cr2008
    2008 tundra
    Just need to replace it
  3. Apr 16, 2017 at 4:01 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Welcome to the forum. Google is your friend. This is assuming you have a 5.7
  4. Mar 25, 2020 at 12:54 AM
    Kaber97
    Kaber97 New Member
    There appears to be 2 locations for the Crank Shaft position Sensor. Which one do I replace? P0335 error code, A Circuit Malfunction.
  5. Mar 25, 2020 at 1:05 AM
    Kaber97
    Kaber97 New Member
    Sorry read it wrong. Camshaft is on top and crankshaft is on the bottom.
  6. Mar 27, 2020 at 1:30 PM
    Kaber97
    Kaber97 New Member
    Here is the part for the crankshaft position sensor. I located it left of the oil pan (when on your back looking up). Removed the cover plate, 10mm bolts. Removed the sensor, 10mm bolt. Then unplugged it as it was easier to do once out and able to grab hold of the release tab better20200327_130924.jpg 20200327_130357.jpg 20200327_130730.jpg 20200327_133951.jpg
    speedtre likes this.
  7. May 8, 2020 at 12:30 PM
    Jemreyes908
    Jemreyes908 New Member
    Jem
    2007 tundra
    How did you know it was your crankshaft sensor was going bad ? I think I have the same problem but I’m getting 5 different codes cam shaft sensor and crankshaft sensor.
  8. May 19, 2020 at 5:23 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    How did we miss this one?
    MrMitch96, BestGen and FrenchToasty like this.
  9. May 19, 2020 at 11:20 PM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    2000-2006. That is all. TY.
    bmf4069 likes this.
