Cranks and wants to start but dies off
Discussion in '2nd Gen Tundras (2007-2013)' started by 07TNDRA, Nov 20, 2018.
  1. Nov 20, 2018 at 7:03 PM
    07TNDRA
    07TNDRA [OP] New Member
    07 sr5 v6
    my 07 v6 sr5 will crank, after three cranks it wants to turn but will then die off. Pump hums and seems to work just fine. Filter is clean, intake is clean, throttle body clean. Fuses are all ok.
    What else should I take a look at?
  2. Nov 20, 2018 at 8:07 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Try looking at your MAF sensor. Pull it out and see if anything is on it.
  3. Nov 20, 2018 at 8:16 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Probably a good time to do a fuel pressure test.
  4. Nov 22, 2018 at 5:52 AM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    Engine immobilizer ??
    Sounds like the anti theft system is working against you. Happens to Tacomas mostly in very cold weather.
    If you have a spare key, try it.
    Any codes?
    15whtrd likes this.
  5. Nov 22, 2018 at 6:42 AM
    Emire221
    Emire221 New Member
    NJ
    Most likely this, it happened to me once and had to disconnect the battery to reset the system.
    NewImprovedRon likes this.
