Crank Shaft Position Sensor P0335 at 4000 RPM(2008 5.7L)
Discussion in '2nd Gen Tundras (2007-2013)' started by yota_best, Oct 11, 2020.
  1. Oct 11, 2020 at 1:37 PM
    yota_best
    yota_best [OP] New Member
    2014 Tundra SR5 5.7L 4WD Double Cab TRD
    Back in the summer I started the truck after it sat for a couple days and the dash lit up like a christmas tree with the check engine light, traction control light, flashing VSC OFF, and flashing 4LO. I googled the combo and believed it was just a short with an ABS wire on the axle. However when I drove the truck it was in limp mode. Disconnected the battery for a min and lights went away and truck was out of limp mode.
    Forgot about it until it started to throw the code whenever I'd go to pass someone on the highway I frequently drive. No limp mode these times though. Seems like usually around 4000 RPM.
    Because I was usually 100 miles from a code reader I'd pull over and disconnect the battery again.
    Eventually I read the code and it was "P0335 1. Crankshaft Position Sensor "A" Circuit 2. Crankshaft Position Sensor Circuit(NE Signal)"
    Called my mechanic and he said it's likely just the sensor went out and to replace it with an OEM sensor not some aftermarket autoshop one.
    Did that. Cleared the code. Tested it and it threw the code again.
    Can't get in to my mechanic till the end of November.
    Any thoughts or feedback on the problem would be appreciated. Thanks
    Bber08527116 likes this.
  2. Oct 11, 2020 at 2:25 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
  3. Oct 11, 2020 at 2:31 PM
    yota_best
    Yeah that's the one
  4. Oct 11, 2020 at 2:47 PM
    JohnLakeman
    Of the possible causes listed on code sites, the next most likely would be a bad electrical connection at the crankshaft position sensor or a harness electrical problem. You might try the careful application of dielectric grease to the sensor terminal pins. Apply sparingly...you're just trying to insure a good electrical connection at each pin without bridging across and shorting. If that doesn't work, then the entire harness will have to be traced and checked for damage. You don't have mice in your neighborhood do you?
  5. Oct 11, 2020 at 3:04 PM
    yota_best
    Yeah I've read that it could be the wiring is too close to a belt and it gets frayed by the belt but I can't find any information online for where the wiring runs through the engine bay. I'll try the dielectric grease. And no mice that I'm aware of and from what I could tell from replacing the sensor its all pretty well tucked up away from the ground. I should also note that my mechanic did the cam tower reseal on the engine at one point during the summer which involves taking a large portion of the front end apart but I can't remember if it was before or after it started giving me the code.
    Thanks for the input by the way! I appreciate it
    JohnLakeman likes this.
  6. Apr 1, 2022 at 6:00 PM
    Tossman
    Tossman New Member
    2012 Tundra
    Did you ever fix the problem. I have encountered the same problem
  7. Apr 29, 2022 at 4:53 AM
    Bber08527116
    Bber08527116 New Member
    08 tundra
  8. Apr 29, 2022 at 4:54 AM
    Bber08527116
    08 tundra
    I'm having same issue crank no start but no codes changed the crank sensor with orielleys sensor work for a while and does the same again did you have any luck with yours yet
  9. Apr 29, 2022 at 8:51 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    You really need to use OE parts for these trucks, did you buy the Denso one they sell?
    Your crank/no start could very easily be the fuel pump control module, which seems to be a common culprit that's hard to diagnose for this situation.
  10. Apr 29, 2022 at 10:27 AM
    Bber08527116
    08 tundra
    Just bought one from Toyota and now no crank no start and now it's giving me po335 code crank sensor bank a?
  11. May 6, 2022 at 3:47 AM
    toy-yeti
    toy-yeti New Member
    07 tundra
    Anyone getting anywhere with issue?
  12. May 7, 2022 at 7:02 AM
    Bber08527116
    08 tundra
    Well I found that my ecu was completely covered in what looks like white caulking cleaned it up and ran again
    NueveTundra likes this.
