Crank pulley out of alignment??
Discussion in '1st Gen Tundras (2000-2006)' started by Cibraceday, Jan 2, 2021.
  1. Jan 2, 2021 at 8:02 PM
    Cibraceday
    Cibraceday [OP] New Member
    Hey all, I have an 02 TRD with about 190k. I was having some serpentine belt issues and so decided to to replace tensioner and check other components. Timing belt and water pump look fine visually. However, during my inspection I noticed my crank pulley was 3/8" toward the block when compared to the fan and other accessories. I thought I must be mistaken and so installed the new belt and turned the engine. The belt immediately slipped off at the crank. Is it even possible for this pulley to move aft? And what are some possible remedies?
    Thanks
  2. Jan 2, 2021 at 8:03 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Time for a new crank pulley.
    The rubber isolator fails and the pulley slips over.
  3. Jan 3, 2021 at 5:19 AM
    DanielDD
    DanielDD Too Old to Rock and Roll and Too Young to Die
    2001 TRD Tundra
  4. Jan 3, 2021 at 5:27 AM
    Professional Hand Model
    Hand Protectors
    Yeah. Inspect. Take pics. Post them. Probably pulley separations.
    Stuck in the '00s and Tundra2 like this.
  5. Jan 3, 2021 at 8:00 AM
    Cibraceday
    Here are photos
  6. Jan 3, 2021 at 8:12 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Ouch... hopefully you caught it before it damaged any engine surfaces. You may need a replacement lower timing cover, though..
  7. Jan 3, 2021 at 8:14 AM
    Cibraceday
    Thanks for pics in the article. I realized your HB looked just like mine.
  8. Jan 3, 2021 at 8:32 AM
    Hand Protectors
    Yeah there is separation. Hope your Oil Pump Housing didn’t get eaten into. Looks like you have a Newer Style Tensioner. I just installed one myself when doing Timing Belt Change. Wonder if someone used a strap to hold the HB (instead of a puller) in order to remove it during the last TB Change?
    Stuck in the '00s likes this.
  9. Jan 3, 2021 at 12:40 PM
    DanielDD
    2001 TRD Tundra
    Been there, done that and got the T shirt. Mine ate thru the timing cover and started to chew through the crankshaft sensor mounting point. DO NOT drive that vehicle! I ordered a new harmonic balancer thru RockAuto and if you need a new timing cover, get the OEM from Toyota. Of course, you will need a tool to remove the harmonic balancer.
