Crank no start 2008 Sequoia
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by nhcollc, May 3, 2025.
  1. May 3, 2025 at 3:46 PM
    nhcollc
    nhcollc [OP] New Member
    Todd
    2008 Sequoia will crank no start. Just got Computer back and checked out okay. No blown fuses. It’s not getting fire. We’ve check multiple connections.
    I had similar issue with Lexus GX460 that was a blown ignition fuse. Could it be a bad started relay? How to check?
  2. May 8, 2025 at 7:38 PM
    ScorchedTaco
    ScorchedTaco New Member
    Az
    2012 Sequoia platinum 2012 Tacoma trd or
    You can check your relay by pulling it and running a jumper between the points . But If its cranking your starter is getting juice - so probably not the relay . I would check out your fuel pump ….
  3. May 9, 2025 at 10:39 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Fuel pump and neutral safety switch is what I would check next.
