Cracked Rotor / Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by AThomas21, May 3, 2021.
  1. May 3, 2021 at 6:18 PM
    AThomas21
    AThomas21 [OP] New Member
    Forest Grove, OR
    2015 Toyota Tundra SR5 Crew Max Magnetic Gray
    6” Rough Country Lift 18” Black Rhino Rims 35x12.5 M/T Tires A.R.E Color Matched Canopy Interior LED Canopy Lighting Side Canopy Win-Doors Yakima Rack Custom Dual Exhaust w/ Flowmaster Super 10 Muffler K&N Cold Air Intake NFab Side Step Bars Black Fender Flares Paint Matched Grill Surround / Hood Bulge Blacked Out Badges Window Tint WeatherTech Window Rain Guards Interior AJT Design Blackout Kit
    Has anyone seen this happen to a rotor before? This was from the front, these were only 2 months old. They are the AutoZone Duralast Gold. Do you think it was just a poor manufactured part or could there be something else wrong that could have caused it? I have a 6” lift, not that it would make a difference. I’m just dumb founded currently.
  2. May 3, 2021 at 6:21 PM
    rt_tundra_co
    rt_tundra_co I'll get tired of tweaking this truck...never
    '15 SR5 CM TRD
    Magnaflow cat-back exhaust Leer Topper, color matched to truck Thule Aeroblade roof rack on topper FABTECH 4” Suspension Lift Decked Storage, 2 drawer SPYDER LED headlights and taillights kits Hertz HDP5 5 Channel Class D Amplifier 2 x 10” subwoofer boxed behind rear seat Door speaker upgrades by Elite Auto Sound Colorado Springs Lock’er Down EXxtreme Console Safe LD2043EX Lock’er Down rear seat 3 x safes Lock’er Down gun magnet 80 LED in-grill light bar Baja Designs LED ditch lights TRD Pro grill Rotiform SIX-OR 20x9 wheels 35x12.5R20 Toyota Open Country R/T tires TheSource sPOD power control hub with in-cab installed accessory switches Firestone Ride Rite air suspension system with Air Command remote, on board compressor and rear bumper air port SDHQ rock sliders
    Have to assume defective part.
    AThomas21[OP] and TheBeast like this.
  3. May 3, 2021 at 6:25 PM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    Just get Toyota parts. They are very cheap
  4. May 3, 2021 at 6:25 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    I think defective. I have quit buying any brake parts from NAPA or any others since it seems they are all selling Chinese garbage. The OEM brakes are about the best thing out there. I went Powerstop drilled/slotted rotors with z36 pads and they dont stop as well as the OEMs.
    Oey12 likes this.
  5. May 3, 2021 at 6:38 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Definitely has to be defective.
    I've been using duralast brakes for years and never had issues. Yeah they're not the best but when I was a poor college kid, I had to use what I could on vehicles.
    Autozone should warranty those but then again, you're back to duralast parts. As others say, switch to OEM.
    Rocko9999 likes this.
  6. May 3, 2021 at 6:39 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Holy chit!! I’ve seen a lot if mechanical carnage and fixed a lot of broken junk in my life and have never seen anything like that before.
    My first thought was loose lug nuts, but there are no scrub marks on the wheel face, and no thread marks from the studs. So I’m with you. A bit dumbfounded. How easy is it to keep breaking it up with a hammer? (Wear a face shield or at at least safety glasses / safety squint, please!!)
    ColoradoTJ likes this.
  7. May 3, 2021 at 6:43 PM
    umarali
    umarali New Member
    Arlington, TX
    After my last disaster with autozone brand some brake pads i had to replace caliper piston so i switched to OEM cant go wrong and they arent overly expensive
  8. May 3, 2021 at 7:03 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    I would guess an over torqued lug nut. But that’s me.
    Edit: or something stuck on the inside of rotor or hub face during install.
  9. May 3, 2021 at 7:45 PM
    Jchetty
    Jchetty New Member
    Wow that is bad. Did this happen to one or both?
    That is a catastrophic failure. I have a hard time believing that any rotor would fail in such a spectacular fashion.
    if it was just one, maybe it was a return that suffered abuse. If 2 rotors had similar issues- I would bet something is rubbing or hitting. Look for any shiny parts as I have a hard time believing a rotor would fail like this. I have never seen anything like this before. Had this not been a heavy duty rotor, your wheel(s) would of sheared off.
    Oh- and an overtorqued lug would not cause this. The lug stud would snap if anything.
  10. May 3, 2021 at 7:50 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Ugh... I had a pep boys rotor crack on the disc itself and it claimed my rear caliper damn near my truck too..
  11. May 3, 2021 at 8:38 PM
    Crazy right? What about over torque? I would think the studs would snap off first.
    landphil[QUOTED] likes this.
  12. May 3, 2021 at 8:43 PM
    Do you run wheel spacers by any chance?
    1lowlife and landphil like this.
  13. May 3, 2021 at 9:55 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I would have to agree. I see no marks on the inside or outside of the rotor hat that explain anything.
    I’m thinking very poor metallurgy has to be the issue. Maybe too many melted down Jeep parts? :D :boink:
    I’d check that wheel bearing for play, and the caliper for any stuck pistons just to cover all the bases.
  14. May 3, 2021 at 9:59 PM
    Definitely one of the weirdest failures I have seen.
    Absolutely correct on Jeep parts. Just Empty Every Pocket is a true statement.
  15. May 4, 2021 at 8:03 AM
    NumberOfTheDay
    NumberOfTheDay Gloves are on, scene is safe.
    SR5 TRD 4X4 OFF-ROAD Barcelona Red Double-Cab
    3/1, 295 70 R18. Some Color Matching
    Do you have wheel spacers installed?
  16. May 4, 2021 at 9:26 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I'm puzzled over the fracture surfaces being beige. That makes my hackles stand up.
    Black Wolf, FrenchToasty and landphil like this.
  17. May 4, 2021 at 9:53 AM
    Rocko9999
    Rocko9999 New Member
    Chinese pot metal.
    MTRock likes this.
  18. May 4, 2021 at 10:45 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    It looks like a cold pour to me. Like the material was not at the proper temp and some of the areas started to solidify to early.
  19. May 4, 2021 at 11:16 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    That really sucks. That's the worst I have ever seen! How could that many chunks be missing?
    The really bad part I put these on my truck yesterday :fingerscrossed:
    AThomas21[OP] likes this.
  20. May 4, 2021 at 11:39 AM
    AThomas21
    Forest Grove, OR
    Nope, no wheel spacers
  21. May 4, 2021 at 11:40 AM
    AThomas21
    Forest Grove, OR
    That was my second set unfortunately, I put these parts on in October 2020, February 2021 I had to replace due to them being warped. Now this happened after 2 months. Just bought OEM
    Piki, 15whtrd and MTRock like this.
  22. May 4, 2021 at 11:43 AM
    AThomas21
    Forest Grove, OR
    I messed with it a little bit prior to returning to AutoZone. It would break apart fairly easily
  23. May 4, 2021 at 11:50 AM
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    My mechanic (who I trust) talked me into them. He said he has had no complaints from other customers and they warranty is good. Hope I don't ever need the warranty.
  24. May 4, 2021 at 1:24 PM
    NumberOfTheDay
    I've used them before on different cars and a SUV and had no problems with them. I wonder if this one skipped the heat treat during manufacturing. What were the symptoms that caused you to look into it and pull the wheel? I guess you would probably be able to see the holes with most wheels still mounted.
    Or maybe this is a new feature, you know, for brake cooling. :facepalm:
  25. May 4, 2021 at 1:43 PM
    AThomas21
    Forest Grove, OR
    you know I did look into drilled rotors, this isn’t what I was thinking though haha!
    I was going down hill and my steering wheel stated violently shaking when I started braking a little. When I say violently, I mean 2 hands death gripped on the wheel keeping it straight..
  26. May 4, 2021 at 1:45 PM
    AThomas21
    Forest Grove, OR
    I have used them before with no issues, my Tundra doesn’t like them for whatever reason. Back to OEM for my Tundra
    Njmike13[QUOTED] likes this.
  27. May 4, 2021 at 2:10 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Plz include pics of any cliffs and/or mailboxes that gave their lives for what I heretofore proclaim Deathride 2021.
    Search Elkhunter. You'll get it.
    Jaypown, 15whtrd, tttrdpro and 2 others like this.
  28. May 5, 2021 at 6:11 AM
    blanchard7684
    blanchard7684 New Member
    #1. I'm glad you are okay and so is everyone else sharing the road.
    Here is what I see.
    2 months old so this is a very low cycle fatigue area
    the "hat" of the rotor takes most of the torsional stress from forward inertia and the brakes.
    the "hat" area also has a large thermal load.
    The fracture surface looks like a low cycle fatigue; almost an overload type surface. but its a picture on a screen...but it looks like some burnishing or polishing was occurring.
    There are multiple cracks leading to high stress areas at opposing ends of the hat, both inner and outer, where there is a large change in cross sectional area (a 90 degree bend).
    One hole is in middle of hat but has one fracture surface bordering a strange looking scratch mark that goes all the way around the rotor hat.
    The color of fracture surface is likely road debris or muddy water
    From this I'm thinking it is a casting problem in the hat area, particularly on the far edges inner and outer. I'm betting there are multiple cracks in the hat area. The ones that caused this were stemming from casting flaws likely at or near the surface. The large hole in the middle likely was caused by a crack in the middle of the material not visible to the eye.
    If I had to venture a guess I'd bet the casting didn't cool uniformly.
    Assumptions
    The rotors weren't installed incorrectly with debris between the hub and the rotor leading to bending stresses.
    The rotors weren't loose leading to vibration.
  29. May 5, 2021 at 10:44 AM
    gtoninn
    gtoninn New Member
    Andy
    2015 Tundra Platinum
    This guy gets it!
    I was coming on here to say that it could be a cooling issue, or porosity in the casting. Because it most likely has a high percentage of Chinesium, that is most likely the reason it failed.
    Glad everyone was safe!
    2mchfun likes this.
  30. May 5, 2021 at 11:03 AM
    2mchfun
    I would say poor final inspection of casting prior to machining process. Add in significant centrifugal forces while in use coupled with frequent significantly rapid heating and cooling. Recipe for disaster!! Luckily it was prevented. Buy a lottery ticket before your luck runs out!!
