Cracked Pinch welds under bed (!!)
Discussion in '2.5 Gen Tundras (2014-2021)' started by goffredo, May 29, 2022.
  1. May 29, 2022 at 1:08 PM
    goffredo
    goffredo [OP] Grease Nipple
    Lake Tahoe, California
    2018 Tundra Limited Double Cab Magnetic Gray
    Noticed a little more creaking than usual from the rear end when going over speed bumps etc. Crawled under to inspect suspension torque settings and saw demolished pinch welds under the bed, on the passenger side above the rear wheel. One of them has crept into the bed material and is starting to crack and the length of the bed.
    I’ve got a 900# camper shell that is permenantly attached and a fancy aftermarket Icon RXT suspension. I don’t wheel it hard. 36000 miles, 2018 Platinum. Any suggestions?
    Occidentalis likes this.
  2. May 29, 2022 at 2:49 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    That's what happens when you jump driveways! :bikewhoops:
    Warranty try? That's pretty bad for it being only 2018!
    woods and Xcumminsguy like this.
  3. May 29, 2022 at 2:51 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    900lb camper shell?
    woods likes this.
  4. May 29, 2022 at 2:58 PM
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    I'm guessing he has one of those slide in shells that's like an actual camper.
    woods likes this.
  5. May 29, 2022 at 6:16 PM
    goffredo
    It’s a roof top tent camper shell thing from Vagabond. it’s either 700 or 900#, I forget.
    I’m not sure if the warranty would cover this, or if the camper shell (or after market suspension or after market bumper) would void any claim I may have.
    But Vagabond has been outfitting Tacomas for years, and I’ve seen comically heavy slide in campers on Tundras that look like they’ve been on for years and years, so I’m not really sure if I just got a bad bed or not, and not sure how to approach the dealership.
    Super disappointing. I was hoping to slip under the truck and tighten a few bolts to stop the squeaking and then I see the blown up pinch welds.
    On close inspection, The ones on the drivers side are starting to go too. A sad day.
    HulkSmurf14 likes this.
  6. May 29, 2022 at 6:52 PM
    HulkSmurf14
    2014 Tundra Limited
    Bummer man, that makes for some dreary weekend fun... I'm not sure how one could approach a dealer with a warranty claim either but what about a flatbed in-lieu of a new bed or repaired bed..? It would be stronger, lighter and more offroad capable with approach/departure angels...?
    FrenchToasty likes this.
  7. May 29, 2022 at 7:23 PM
    goffredo
    Oh I’m sure I can get my welding buddy to fix this thing up good as new. But it’s clearly not working for the camper shell that I have, so I’ll probably just weld it up so I can sleep at night, then sell it, and move on. The market for roof top tents, and low mileage tundras, is just too good to pass up right now.
    Honestly this truck is just too big for me. Great overlanding rig until this happened. But I never loved it like my 1st gen Tacoma, which I’d much prefer to spend my time and effort on. And the girlfriend is really in love with the idea of a heated shower and flush toilet, so maybe it’s time to move on to a 25’ tow camper. I dunno.
  8. May 29, 2022 at 7:36 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    So your plan is to tow a 25 ft travel trailer with a Tacoma?
    reneaux, 1UP, rphass17 and 1 other person like this.
  9. May 29, 2022 at 8:57 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    A slide in distributes the Load across bed floor. 700 is a lot on the bed rails. Think of the forces when hitting brakes/bumps on the front corners of the bed. Yes its pathetic a truck in 2022 cant take a load like that
    goffredo[OP] and Terndrerrr like this.
  10. May 29, 2022 at 9:03 PM
    Wow. That is some pretty significant damage. Not sure I would have a friend that can "weld" do this job unless he is very experienced in auto body repair. I know how to weld and would not tackle this job especially if you have a spray in bed liner installed.
    Depending on options, you are around 700 lbs for the Vagabond Nomad (assuming that is what you have). This is well within your payload ratings right? Right. Here is the problem:
    The bedsides are really not rated for that much weight (obviously right?) and over time it really takes a toll on the bed mounts/brackets. A normal slide in camper sits on the floor of the bed on top of the frame and then also has 4 tie down points. Usually the front ones have frame tie downs and the rear are either bumper button or frame tie down (smart ones use rear frame tie downs) like this one:
    What you are essentially doing is twisting up your bed off-road (which is normal without weight). The camper shell is a hard mounting point that transfers the stress to other areas (welds/brackets). This would have happened over time with just normal road use.
    I wouldn't even think about attempting a warranty claim. An insurance claim is the route I would go or pay out of pocket.
    Sorry to see this man...it really sucks.
  11. May 29, 2022 at 9:17 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    How would bed stiffeners affect his problem? Would they be helpful or make it worse?
  12. May 29, 2022 at 9:39 PM
    Might help a little, but sends the stress to the next weakest point...
  13. May 29, 2022 at 10:46 PM
    goffredo
    I'm not sure I follow ... I would call my insurance company and ask them what, exactly? I wouldn't mind paying my deductible to get this fixed, I just don't see how insurance would help here, when the damage that was done is by my own dumb luck. I thought insurance was for stuff damage that other people did to the vehicle.
    I wonder if talking with a collision shop would give me some options. I'm sure they've seen worse damage than this. They would have enough expertise to remediate this problem, and they might be able to help me navigate insurance and advise me of cost.
    I guess first thing is to get rid of that camper shell. It's obviously not compatible with the truck, and the kind of (fairly light) off-roading I do.
  14. May 29, 2022 at 10:47 PM
    goffredo
    No, I'd have to get a new tow vehicle for a 25 ft trailer.
  15. May 29, 2022 at 10:54 PM
    So if you get into an accident, it’s your own dumb luck as well right? I would call your insurance company and tell them your camper did some damage to the truck.
    Check with some local body shops to see how much it will cost to fix.
    batman900 and NewImprovedRon like this.
  16. May 30, 2022 at 10:48 AM
    goffredo
    Thanks for all the input! I think I have a plan now. I'm going to sell the camper shell and then focus on getting the pinch welds on the bed fixed up through a collision repair shop.
    Booney, ColoradoTJ, batman900 and 2 others like this.
  17. Jul 12, 2022 at 11:43 AM
    goffredo
    I admire your optimism that an auto insurance company would pay out on a claim like this, but here is the letter I got today:
    "The damage to your vehicle appears to be caused by wear and tear. Therefore, there is no basis upon which we are able to afford coverage for the repair of your vehicle since the damage appears to have been caused by wear and tear."
  18. Jul 12, 2022 at 11:46 AM
    Well you tried. Who is your insurance company?
  19. Jul 12, 2022 at 12:00 PM
    Nightshade Tundra
    Nightshade Tundra New Member
    Alex
    2021 Ram 2500 Laramie
    Man this sucks but the damage does appear to be wear and tear there is no sudden and direct impact which would fall under your collision coverage.
  20. Jul 12, 2022 at 12:05 PM
    goffredo
    It's AAA.
    I'm going to guess we'll be seeing a lot more bed failure posts in the next year or so. I was the first or second person in the manufacturing queue to receive this style of "big full sized aluminum roof-top tent shell that rests entirely on bed rails" a few years back and there were not any others out there for full-sized trucks at the time, so now there's hundreds more people out there with the same setup I have, that haven't had enough time yet to fail. And like I said, I go off-roading extremely frequently in this rig, but no crawling and certainly not at high speeds, so I am sure there are dudes who beat their truck beds up a lot harder than I do.
    I'm planning to have a welding guy take a look at things and see how he can better tie the weight of the camper shell to the frame, rather than its current situation where all ~700 pounds rests about 40% on the side bedrails and 60% on the bedrail the runs along the back of the cab. I surmise that having this much weight on the cab-most bedrail, along with torsional side-to-side loading and twisting of the truck bed, while rolling over rocks and obstacles, caused this issue. I think an ideal solution would be to have (3) 1/4" or 1/2" thick plates that sit on top of the 2 side and 1 cab bedrails forming a big "U", and then have the camper shell sit on top of those. Then, from the 3 plates, have support members that run diagonally down (perhaps with gussets), through cut-outs in the bed floor, and attach directly to frame. Also, doing fix-up on the current cracks that have formed along the bed and on the supports underneath it which are pictured in my initial post. Unfortunately this requires removing my $600 bedrug and melting the shit out of my $800 custom-color linex spray in liner.
    I saw that Cali Raised has Tundra bed stiffeners (link) but those wouldn't really help because they provide support at the tail end of the bed, where the least amount of camper shell weight bears down. In fact they might make things worse by stiffening the tail end but not the cab end of the bed, which would in turn create even more torsional twisting on the cab end of the bed where all the weight is.
    Not_a_toy_yoda likes this.
  21. Jul 27, 2023 at 2:42 PM
    Not_a_toy_yoda
    Not_a_toy_yoda New Member
    2018 TRD Off Road 4x4 double cab
    Did you get this resolved? What did you end up doing?
    I also had an icon RXT setup and a bed rack with RTT. Seems the floor in my bed, towards the cab, and just left of the bolt tying the bed to the frame is now torn. Need to get the bed repaired. Not sure if I can weld as is, since I also have end liner on top. I’ve taken the rack and all accessories down for now. Considering picking up a slide in camper.
  22. Jul 27, 2023 at 3:15 PM
    coTony
    Tony
    Montrose, CO
    That would be time for a flat bed for me. I have a 2018 and crawled under there and looked. No damage but I have SDHQ bedrail supports and I do not sport a topper
  23. Jan 17, 2024 at 1:42 PM
    DavidinPhx
    DavidinPhx New Member
    Phoenix
    2021 DC Tundra SR5
    Icons, Deavers, 34s, 4.88s, F&R e-lockers, Ovrlnd Camper, & other stuff
    Well, I wish you were wrong about seeing a lot more failures, but you're not!
    I have a '21 Tundra DC TRD with the 38gal tank. Ovrlnd camper (weighs 390lbs) on for 3 years (~85 nights out so far, yes, my wife counts them . . ). Upgraded suspension and I do have bed stiffeners in the rear. Carry nothing on the roof to add weight. Battery (40lbs) sitting right above the bed bolt in that area too, so well supported. Crack in D-side front underneath, but no bulge yet and no bed wiggle. Wouldn't know it's there except I checked after seeing this video: https://youtu.be/6UNx5X70_4Q?si=1CHFa2gmir4Bwfb0
    Clearly Toyota did not support the bed well there, especially if you compare to the P-side same spot. I don't abuse it, but do wheel tougher trails, and I tend to go faster over washboards to smooth them out. Don't think it was the weight, but rather the torsion of wheeling and likely my last trip with a really, really rough run (aired down, shocks adjusted soft!) down the flat parts of upper Hole in The Rock Road with the absolute worst huge washboards ever. Haven't figured out how to address it yet. Not getting rid of the camper or truck though.
    Edit: just to be clear -- I'm not Angry Camper of the video, and I'm also not saying the specific camper caused this. I thing is is clearly a design flaw from Toyota when you put even a light weight camper shell on the bed rails and then mod the truck and wheel it.
  24. Jan 17, 2024 at 2:09 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Tundra Crewmax Platinum 4WD
    Does anyone think a standard fiberglass topper over time would be heavy enough to do similar damage? My 2018 has a fiberglass ARE she'll on it, and has since new. I just recently bought the truck and the previous owner solely used it for a tow rig. When it warms up, I'm going to go check underneath to ensure I i don't have any similar damage.
  25. Jan 17, 2024 at 2:12 PM
    DavidinPhx
    Phoenix
    2021 DC Tundra SR5
    By "SDHQ bedrail supports" do you mean their hidden bed stiffeners (for the rear)? Or is it something else I'm not finding?
  26. Jan 17, 2024 at 2:27 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    I have no such damage on mine after 3 years with a fiberglass shell. I don’t off road and occasionally carry paddle boards on the roof. My dad’s long bed has had a shell on it for 13 years, probably 50k miles of gravel roads and most of it towing/ hauling - no damage. I think these campers that rest on the bed rails are just too heavy, especially at the front where the sleeping beds cantilever over the cab.
    Red&03Taco[QUOTED] likes this.
  27. Jan 17, 2024 at 3:15 PM
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    This is the precise reason why I never ever buy used vehicles, especially trucks!! :eek:
    -T
    woods likes this.
  28. Jan 17, 2024 at 3:40 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Seam weld that sucker!
    Maybe add some reinforcement while you’re at it. Then you can find the next weakest point in the system.
  29. Jan 17, 2024 at 4:10 PM
    Not_a_toy_yoda
    I can confirm, and based on research that I have done, I believe this to be a fundamental design flaw of the double cab tundras. I have gathered what I believe to be ample evidence of this and would love to get together with everyone who has an issue and see if we can’t make toyota rectify this by fixing the issue or getting us into a CrewCab instead.
    71511252449__829B12B8-4ECD-4CDF-A51A-35F790B86D3C.fullsizerender.jpg IMG_0851.jpg
  30. Jan 17, 2024 at 4:16 PM
    Not_a_toy_yoda
    The problem is there is no bed support after the final bed bolt. The double cab bed is “floating” for lack of a better term for the last 15” or so past the bed bolt towards the cab. You can see how the frame slopes down and goes under the cab. On the Crewmax this is a non issue. The cab sits right in front of the last bed bolt so the entire bed is supported. IMG_0166.jpg
