Coverking seat cover installation 2019 tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by atebit, Jul 13, 2019.
  1. Jul 13, 2019 at 7:15 AM
    atebit
    atebit [OP] New Member
    PA
    19 QS DC TRD Limited
    I Purchased neoprene coverking seat covers. Coverking provides a video that goes too fast, but by scrubbing the video back a few times I can figure most of it out. One of the last steps is to “connect the hooks” that are dangling from the rear seat back, but they don’t tell you what to connect them to.
    There are apparently no printed instructions so I’m like :confused:
  2. Jul 13, 2019 at 7:31 AM
    DoubleJackOnTap
    DoubleJackOnTap New Member
    SW Washington
    2018 Super White TRD Sport
    CoverKing Neoprene Seat Covers, UltraFlex
    Stretch them under the seat and hook to the metal cross bars that run beneath the seat. Make sure you aren't going around the slider mechanism that adjusts seat / forward and back. Also be careful to avoid the wires.
  3. Jul 13, 2019 at 8:44 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I have the Coverking neoprene covers (really like them), and iirc you're supposed the hook the ends of the back and front straps together under the cushion. As I remember, I think they had proprietary plastic ends (not the usual "S" links) that were adjustable on the straps (adjust for good cover fit), and designed specifically to hook together. As mentioned before, be careful to avoid any junk under the seat.
    Edit: @atebit Sorry, you said seat backs. Checked mine. I hooked the rear seat back cover strap to the second seat spring into the bottom cushion. That's about where the strap length ends. Those straps do have small "S" links.
  4. Jul 13, 2019 at 2:04 PM
    atebit
    PA
    Thanks for the replies, will give it a shot!
  5. Jul 21, 2019 at 4:55 PM
    FLMallCrawlr
    FLMallCrawlr New Member
    2019 Tundra limited
    20x9 pro comp wheels Custom built exhaust w/magnaflo S&b intake 6112 front Fox back Rigid ditch lights Infinity speakers with kenwood amp 2 10” mtx subs
    I cant get my backseat armrest to close all the way with the cover kings neoprene no matter what I do.. fml
    dpast88 likes this.
  6. Jul 21, 2019 at 5:15 PM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    I left mine dangling on my carhartt seat covers bc there is no good way to hook them in.
  7. Jul 23, 2019 at 8:44 PM
    MICKs18yota
    MICKs18yota New Member
    Ohio
    2018 Tundra SR
    I had same problem when I installed my new covers on my DC just left the straps hang in the back seat. I do like them though fronts were easy to put on but that back top panel was tough.C3720A02-021B-4AF9-8847-DB1594F4EA05.jpg
  8. Jul 8, 2020 at 10:25 PM
    Skier98
    Skier98 New Member
    Samuel
    2018 QS Crewmax
    Camburg Bumper Ridgid pods Snugtop N-Fab steps
    I am having the same issue! Did it ever end up closing?
