Couple questions 07 2wd 5.7
Discussion in '2nd Gen Tundras (2007-2013)' started by Blur'd Vision, Jul 30, 2021.
  1. Jul 30, 2021 at 6:41 PM
    Blur'd Vision
    Blur'd Vision [OP] New Member
    Dave
    2007 Tundra DCAB SR5
    Seems my bumper sensors are too sensitive. They beep now and then for no reason. What can this be and can I desensitize them??
    Secondly I drove it 3 miles today to get some items at Walmart. Left it in the parking lot for no more than 15 minutes. 95 degrees outside, When I got back in to go home the engine started ran 2-3 seconds and stalled. It did this 4 times before the 5th attempt it started fine and we drove home. No check engine light, nothing. It has 135,000 miles on the clock too. Any ideas? My thought is fuel pump. Thanks
  2. Jul 30, 2021 at 6:46 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    How old is the battery would be my question?? Battery going dead has weird ways of showing you up... ask me how I know... how old is the fuel??
  3. Jul 31, 2021 at 9:37 AM
    Blur'd Vision
    Dave
    Battery is good, new when I bought the Tundra a few months ago. Fuel is a week old.
  4. Jul 31, 2021 at 9:45 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Maybe a fuel filter needs replacing?
  5. Jul 31, 2021 at 9:47 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Did you have the battery load tested? I would plug in a scan tool to see if there are any pending codes. There have been other owners with similar issues who paid to have the fuel pump replaced as a best guess, then they had to go back and actually figure out what the issue was when the new fuel pump didn't solve the problem.
    On the parking sensors, the little trim pieces that go around them can crack and let the sensors rotate a little bit, then they'll beep randomly.
  6. Jul 31, 2021 at 9:48 AM
    Blur'd Vision
    Dave
    I was thinking a fuel pressure problem? It didn't make a difference if I hit the pedal to rev it or if I let it try to idle, it still stalled. Restarted right away like normal. Weird. Maybe it didn't like being at Walmart. I know we don't like it there. Plugging it in today to see if there are any codes stored.
  7. Jul 31, 2021 at 9:55 AM
    audiowize
    Paul B.
    It could be an issue with the security system in the car and the chip in the key, so you'd want to be sure it happens with all the keys you have.
    It could be an issue with the fuel pump control module.
    It could be an issue with a stuck injector bleeding down your fuel pressure.
    It could be a weak battery or a corroded body ground.
    Or maybe the fuel pump.
  8. Jul 31, 2021 at 5:43 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    Does it start ok now? Or still hard starting?
    If the check valve in the fuel system is bad you can lose fuel pressure when you shut it off. If it wont fire off right away on the first crank you can try cycling the key on and off for 3 seconds about 3-5 times before starting. If it fires immediately like it should you are losing fuel pressure.
