Couple problems with 4wd and mirrors.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Fitz19d, Dec 23, 2015.
  1. Dec 23, 2015 at 8:09 AM
    Fitz19d
    Fitz19d [OP] New Member
    2015 5.7 SR5 Tundra
    Black wheel dip. Prodigy P2 Brake Controller
    So running into two issues on the new truck. First is the features placard says heated mirrors. The side mirrors have the defrost symbol on them. I can't find a button in cab so figure automatic or tied to the main window defrost.
    Whichever it is the don't defrost? An i missing something? It's a 15 sr5. DC.
    Next more important one is I've had issues getting into 4hi. Previous, got it on my 3rd attempt. Today i gave up after eight. I tried it from parked where i was, then tried it after having out of drive way, again after going forward. Then a couple times going back and forward to try and unwind it out whatever. Drive down the block and tried at stop sign. No go.
    Drive to work 40 miles away, get in parking lot and try it fit fun. Guess in on first try.....
  2. Dec 23, 2015 at 8:15 AM
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    Need to be in neutral to swap it from 2 hi to 4 hi. As far as your defrost on your mirrors, comes on when your set to defrost for the windshield.
  3. Dec 23, 2015 at 8:33 AM
    Fitz19d
    2015 5.7 SR5 Tundra
    I was in neutral too for some attempts. On the 15 i swore it said in park in manual.
    Likewise with the mirror i had the defroster on all the way to work and side mirror Frost never melted.
  4. Dec 23, 2015 at 8:38 AM
    Sefferston
    Seth
    ERMERGERD TOYOTA
  5. Dec 23, 2015 at 8:41 AM
    cfdfireman90
    cfdfireman90 New Member
    Cory
    Southern NH
    2015 Tundra Limited/TRD Double cab
    On my 15 limited there is a button on the climate controls for the mirror heat. Four wheel drive you should be able to put it in while moving at any reasonable speed.
  6. Dec 23, 2015 at 8:56 AM
    Fitz19d
    2015 5.7 SR5 Tundra
    Sounds like i should try moving reading elsewhere. Guess i still had the older advice of doing stopped as moving harsher on it.
    I don't have a limited. My center console doesn't look like that.
  7. Dec 23, 2015 at 9:34 AM
    cfdfireman90
    Cory
    Southern NH
    If all else fails, look in your manual.
    Sefferston likes this.
  8. Dec 23, 2015 at 9:56 AM
    AMRE2ME2
    AMRE2ME2 New Member
    2016 DC 4x4 Limited TRD
    Not correct. You need to be moving for it to engage into 4H. It also disengages faster if you are moving.
  9. Dec 23, 2015 at 10:07 AM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    I stand corrected. Every time I've engaged 4H was in neutral.
  10. Dec 23, 2015 at 11:23 AM
    This.
    I also "excercise" the acuator by placing it in 4hi on a straight road for at least 10 miles a month.
    I also use 4L on a small portion once a month.
    MotoTundra likes this.
  11. Dec 23, 2015 at 11:29 AM
    Fitz19d
    2015 5.7 SR5 Tundra
    Think I'm sequestered away on the shifting issue. Ooh week for the old advice i had if skiing it from a stop.
    Just these mirrors acting like duds. Will reicw then tonight and drive with defrost on whole drive to confirm.
  12. Dec 23, 2015 at 11:30 AM
    Use the defrost button to the right that (as pictured a few posts above) and that'll do the mirrors and rear window.
  13. Dec 23, 2015 at 11:36 AM
    Fitz19d
    2015 5.7 SR5 Tundra
    And as stated, i do not have that button. I have no button anywhere except the swivel on heat fit main window defrost.
  14. Dec 23, 2015 at 11:40 AM
    Can u post up a pic of what u have and maybe we can research it for u.
  15. Dec 23, 2015 at 11:42 AM
    Fitz19d
    2015 5.7 SR5 Tundra
    I can tonight maybe, i am at a fixed post and can't go as far as where in parked.
  16. Dec 23, 2015 at 4:01 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    On an sr5 you should have a mirror defrost button...i do. Look under your screen where it says TUNDRA. It is the 3rd button on the right.
  17. Dec 23, 2015 at 8:48 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    On an SR5, this button is for the rear glass and the side mirrors.
  18. Dec 23, 2015 at 9:06 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    @Fitz19d. You should have a button under the stereo that has the same symbol as what is on the mirrors just like @MotoTundra shows above. It doesn't get very hot and may take time to get to temp and melt frost.
    You don't need to be parked or in neutral to switch to 4x4. Most of the time you need to move forward for it to engage. You can be driving down the road and switch to 4x4 as well. I wouldn't suggest doing it at highway speeds but back road speeds is fine.
  19. Dec 23, 2015 at 10:19 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    My 4wd seems to engage disengage quickest while moving but kind of coasting. If you are hard on the gas it won't engage as fast.
    Always good to exercise it like @Sean266 said. I didn't with my Tacoma and getting in and out of 4LO was tricky until I started doing it more often.
  20. Dec 24, 2015 at 7:56 AM
    2015 LIMITED CREWMAX 4X4
    2015 LIMITED CREWMAX 4X4 New Member
    Glenn
    2015 Tundra Limited TRD 4wd crew max.
    Bed cover, spray in bedliner, tinted windows, black coating on wheels, blacked out grill and all other badges, 2.5" front leveling kit, rear Firestone air bags.
    4Hi while driving up to 45mph I believe, 4low u have to be stopped in neutral.
  21. Dec 24, 2015 at 8:08 AM
    csuviper
    Broomfield, CO
    Correct 4 low has to be stopped and in neutral
  22. Dec 24, 2015 at 8:16 AM
    csuviper
    Broomfield, CO
  23. Dec 24, 2015 at 12:44 PM
    Fitz19d
    2015 5.7 SR5 Tundra
    Alright, kinda odd story. With a description of where it should be and photo from someone. Figured it out. When I bought this used I was shown a console button button blank that was controlling an accessory power line they said I could wire to something. Think previous person had it for a labtop or something? Unsure. But I just figured it used a blank button I'm used to seeing on non top trim models of other vehicles. While digging around in glove box seeing if I was missing anything I found I guess the original button itself with the defrost symbol. Guy gave up using mirror defrost to have a clean power button/supply for something? Doesn't make sense to me, but that's best I've figured. Will be getting someone I know who knows the wiring to check to see if the mirrors completely disconnected or if they work when turning the power on/off with this button? (Since I figured this out havn't hide frost to test on.)
  24. Dec 24, 2015 at 2:44 PM
    I've engaged and dis-engaged from 4HI to 2HI at speeds over 70mph when needed with no problems numerous times. Same thing with my 09 Tacoma on my way up to AK. My 07's defrost button controls the heated mirrors and it is not super fast it super cold out in the morning.
  25. Dec 24, 2015 at 4:03 PM
    I think he means being able to engage into 4WD at a certain speed. You can disengage at any speed.
  26. Dec 25, 2015 at 7:23 AM
    On my way up sometimes I would come across dry pavement so I would switch to 2HI on the fly and back to 4HI on the fly as soon as I would hit ice/snow again. I would let off the throttle slightly before engaging/dis-engaging. I did this a bazillion times and never noticed any problems engaging or dis-engaging regardless of what speed I was traveling at. After awhile the road conditions stayed poor once I got to Yukon Territory. Was in 4HI from there on out all the way to Anchorage and I wasn't taking my time.
