Couple of Tricks
Discussion in '1st Gen Tundras (2000-2006)' started by Professional Hand Model, Apr 29, 2018.
  1. Apr 29, 2018 at 11:22 AM
    Professional Hand Model [OP] A.K.A ‘Golden Hands’
    Hand Protectors
    A few tricks to help with other 1st Gen owners.
    Every once in a while, unhook your battery cables to ‘reset’ your engine computer. This helps the transmission shifting memory to reset to factory setting. Especially helpful when you tow/haul a brief load every once in a blue moon and you want your computer to ‘unlearn’ this memory.
    Take a 10MM wrench and tighten (every 6 months) the valve cover screws. There are 10 screws. An 1/8 to quarter turn max depending on the ‘feel’. These aluminum valve covers loosen from engine heat over time. I learned this trick a few years back when smelling burning oil eminating from the gasket seal. The cover screws were very loose (half to 3/4 turn per) and once tightened the problem was fixed. Now its a regular maintenance thing and no problems. Just do not over turn the screws and stagger your screws tightening like you would tire lug nuts.
  2. Apr 29, 2018 at 11:46 AM
    LaaMahTundra
    LaaMahTundra Luv it Moa, when it's Clean!
    So Co Metro, OC
    06 Tundra limited DC 4x4
    SS SnugTopper.
    Good tips to remember thanks
  3. Apr 29, 2018 at 12:07 PM
    Sunnier
    Sunny
    San Diego, CA
