Could I put a off road tire on my 23 Tundra TRD sport?
Discussion in '3rd Gen Tundras (2022+)' started by giakkon, Jun 7, 2023.
  1. Jun 7, 2023 at 12:09 AM
    giakkon
    giakkon [OP] New Member
    I have a Trd SPort Premium pack Tundra.
    And I would like to study and learn for camping
    But the wheel and tire on this package is 265/60/R20
    Does any brothers know or recommend how I change my tires to be offroad without any lifting
    because I am a new. thank you so much for all professional teachers in here!!!
  2. Jun 7, 2023 at 12:44 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Here are 2 options in your current size that should outperform the capabilities of the truck...
    https://www.tirerack.com/tires/tire...SR0OCAT3&vehicleSearch=false&fromCompare1=yes
    https://www.tirerack.com/tires/tire...R0WPAT3W&vehicleSearch=false&fromCompare1=yes
  3. Jun 7, 2023 at 6:55 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Go to a tire shop and ask them what will fit if you wan to go bigger with the stock rims or replace the stock tires with pretty much any All Terrain tire and bobs your uncle.
    Black@Blue19 likes this.
  4. Jun 7, 2023 at 1:19 PM
    giakkon
    Thank you so much for the answer and advise brother!! Do you have any recommendations for my stock tires too? Wish you all the best
  5. Jun 7, 2023 at 1:20 PM
    giakkon
    Thank you so much brother!! I’ll stop by and give a ask
  6. Jun 7, 2023 at 2:25 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Big question is do you want to remove/ trim plastics? you can cram a 35x11.5 on stock wheels in there, youll just need to a lot of cutting and trimming. If it were me I would aim for a 34x11.5x20 tire- the toyo at3 275/65/20 is the best tire i have ever ran, put over 600k miles on the at2 and at3 in my 07,14,16,19 and 22 tundra's
    TundraDan723 and mayan like this.
  7. Jun 7, 2023 at 7:21 PM
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    If you want to keep your fenders and ride height then the 275 65 20 will work the best. I run toyo open country at3s in that size and they are quite and they fill in the wheel well liners. No rubbing or scarping but they are LT 10 ply tires. Nitto ridge grabbers just came out with a 116 rated 275 65 20 tire which would be a little softer
    TundraDan723 likes this.
  8. Jun 7, 2023 at 7:56 PM
    topdec
    topdec New Member
    AWD Sprinter, 2023 4R ORP, 2 3rd gen Tundras - sold
    If you are just camping at campgrounds and not overlanding, I would start simple.
    My suggestion would be the Cooper Discoverer AT3 4S in 275/60R20. These will do fine on dirt/fire roads, and only half an inch taller than your stock tires. They are also SL tires that weigh only 44lbs. You shouldn't see a big hit on your highway mpg.
    https://www.tirerack.com/tires/tire...idewall=Blackwall&partnum=76TR0DA4S&tab=Sizes
  9. Jun 7, 2023 at 8:02 PM
    I have these on my '18 Sport......love them.
    Tripleconpanna likes this.
  10. Jun 7, 2023 at 8:02 PM
    Welcome from NY.
  11. Jun 7, 2023 at 11:05 PM
    giakkon
    Thank you so much for replying.
    i do not want to remove or trim plastic. but looking to put a better tire for the unexpected rocky road when heading to the destination.
    looks like the Toyo AT3 is one of a really good choice !!!
    can i just change these on my oem wheel without doing any cut/trim/lift please?
  12. Jun 7, 2023 at 11:10 PM
    giakkon
    Thank you so much for replying. And Yes sir.I would like to keep fenders and ride height as is. I am still trying to read more article for the tires. Do not know if my oem wheel can just change from 265/60R20 straight to 275/65R20 as your recommendation. Because I really love these wheels looking...
  13. Jun 7, 2023 at 11:12 PM
    giakkon
    Thank you for replying sir. These tires seem a really good choice too. half an inch taller should go just fine!!! I appreciate!!
  14. Jun 7, 2023 at 11:12 PM
    giakkon
    really!!!? LOL, sounds good sounds good
  15. Jun 8, 2023 at 12:18 AM
    Tripleconpanna
    Not quite sure what you are asking regarding 'recommendations for stock tires'... but, if you're asking what to do w/them, I'd sell them to re-coup some of the money you're spending on the ATs...
    Also, regarding some of the other questions and responses about not wanting to cut, trim, mold, shape, lift, etc...
    Just stay w/the stock tire size when you purchase your more aggressive AT tires, and you should be fine. Plus, you won't have issues w/speedo calibration, clearances, extra wear and tear on parts, etc...
  16. Jun 8, 2023 at 6:49 AM
    Breathing Borla
    AZ
    This ^
    you start going with all these bigger Load E and just a heads up, the ride is worse and the MPG will take a hit
  17. Jun 8, 2023 at 7:25 PM
    TRDoffroadPRO
    Yes but they look a lot cooler and do actual truck things instead of those sissy tires that come stock. 275 65 20s fit just fine are 1 inch taller than the stock tire. Hypertech will have a calibration soon enough and I get 17-18 mpgs with the steup but I'm also hybrid
  18. Jun 8, 2023 at 9:16 PM
    giakkon
    GOT IT SIR!! thank you SO much!!!!
  19. Jul 10, 2023 at 2:57 PM
    Hacknsack
    Hacknsack New Member
    22 Lunar Rock Sr5 TRD sport
    Hey guys I have a 22 sr5 trd sport. What size tire can I put on the oem trd sport rims? Thanks.
  20. Jul 10, 2023 at 11:08 PM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
    If you are willing to go with new wheels, you might find a better ride off-road with 17" or 18" wheels with a higher aspect ratio tire (the height of the sidewall as a percentage of the tread width), as an example I went with 265/70-18 Continental TerrainContact AT tires on Method Racing 318 wheels with +40 offset, fit beautifully and the truck rides a bit better due to the taller sidewall on the tires.
  21. Aug 2, 2023 at 7:37 AM
  22. Aug 2, 2023 at 7:56 AM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    You could just go without changing or buying anything. Go with other people in another truck so they can help if you need it.
    Truck can do a lot stock.
  23. Dec 23, 2023 at 4:19 PM
    Jongie123
    Jongie123 New Member
    Johnny
    2022 Midnight Black Metallic Tundra 4x4
    You mind sharing pic of your setup ?
  24. Dec 30, 2023 at 7:13 AM
    TNC
    TNC New Member
    I just picked up a '24 SR5 with sport premium package. Just curious if i can put 18" tires in place of the 20" without changing wheels.
  25. Dec 30, 2023 at 7:17 AM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    :monocle: That would be one hell of a stretch.
    itundra22, pwpblue and Mattedfred like this.
  26. Dec 30, 2023 at 11:05 AM
    NickBrewer
  27. Dec 30, 2023 at 11:39 AM
    teab
    Ty
    Denver
    Yep head on down to your local tire shop and ask them to do it! Is don't see what's stopping you from asking a tire shop to do it.
  28. Dec 30, 2023 at 12:37 PM
    TNC
    TNC New Member
    Key thing is will that be proper specs, 18" tires on 20" wheels
