Correct Spicer Carrier Bearing for 1st gen tundra EXACT TOYOTA OEM
Discussion in '1st Gen Tundras (2000-2006)' started by 00TundraZ, Apr 30, 2019.
  1. Apr 30, 2019 at 7:02 AM
    00TundraZ
    00TundraZ [OP] New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Ok, so I am really making this for everyone that might be searching for the correct spicer carrier bearing and doesn't want to pay $170-190 for one that comes in a Toyota box. I ordered the following carrier bearing from DriveTrainAmerica.com. It claims they only fit the 4x4, but it shows 2000-2006 right in the item description. The Spicer factory number is #5002334.
    I signed up for their email and received 5% off rebate (Code is "5%OFF). With shipping and all I paid less than $65!
    As you can see below, the rubber around the bearing is actually stamped "TOYOTA" with the other side showing "SPICER" in the rubber molding.
    https://www.drivetrainamerica.com/s...ma-driveshaft-center-support-carrier-bearing/
    I hope this helps someone in the future save some $$$ and have a quality replacement to last many years!
  2. Apr 30, 2019 at 4:25 PM
    Professional Hand Model
    Hand Protectors
    Sweet find! I paid somewhere around $190 for mine. I’ll post a pic for comparison.
    Great find on this for a save of over $130!
  3. Apr 30, 2019 at 5:23 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Solid find. Good research. I wish I had seen this prior to going "OEM". As soon as the guy at the driveshaft shop opened the box he said "that's a Spicer". Definitely got hosed on that one. I wonder if there is any difference between the two. I don't remember mine saying anything on that rubber area.
  4. May 1, 2019 at 4:10 AM
    Hand Protectors
    The part numbers are different as well. I looked to see if there is another picture of the other side of mine and couldn’t find it. Guess I pop under later and snap one.
  5. May 1, 2019 at 4:19 AM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    I just recently replaced my crappy aftermarket carrier bearing,u-joints with spicer brand. Took driveshaft with parts to shop and had them install and modify driveshaft with slip spline at rear end, so far so good
  6. May 1, 2019 at 4:20 AM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Well admittedly I have not installed this. I went by drivetrainamerica.com’s listing stating it fits 2000-2006 tundra 4wd. I certainly hope it fits and can help someone in the future. If it isn’t the right replacement I will update this thread immediately requesting it be deleted.
    Maybe I jumped the gun a bit :oops:
    Hopefully I can report back with good news!:thumbsup:
  7. May 1, 2019 at 4:22 AM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    I have zero vibrations right now, but I know my bearing rubber is just trashed so I want to replace ASAP when time allows. I hope replacing doesn’t cause some random vibes that I wasn’t getting before.
    I’ve been attempting to hunt down correct u joints but after further research I think I’m going to leave them alone for the time being. Haven’t looked yet to confirm if I have a double carden or not.
  8. May 1, 2019 at 4:23 AM
    MOTORHEAD
    DAVID
    LOS ANGELES CA
    Mine is a 2 wheel drive and it should be the same part number. I called them to verify before i purchased from them. I removed and installed the driveshaft my self but had a driveshaft shop do the work and balance complete assembly. Hope this helps
  9. May 1, 2019 at 4:34 AM
    Hand Protectors
    I hope it works too. Everything looks the same so far. You should be good. I just post stuff up to compare and contrast to make sure. Spicer is a great brand.
    Per your u-joints and double cardan, I’d leave them alone unless they start acting up. I did a ton of research on this and all the variations. The conclusion based on others was to just buy a new drive shaft. Makes sense as the OEM has many different joints and part numbers. Too much work hence buy a new shaft.
    If it works, don’t fix it.
  10. May 1, 2019 at 4:36 AM
    MOTORHEAD
    DAVID
    LOS ANGELES CA
    Mine does not have a double cardon joint, so i cant comment. Maby because mine is 2 wheel drive.hope it’s works out
    00TundraZ[OP] likes this.
  11. May 1, 2019 at 4:39 AM
    Hand Protectors
    Maybe after market?
    Looks like you have a spacer drop to accomodate your lift?
  12. May 1, 2019 at 6:45 AM
    MOTORHEAD
    DAVID
    LOS ANGELES CA
    Rcd 6” lift with icon extended length coilover with camburg upper control arms also 3” body lift. Did all the work myself
  13. May 1, 2019 at 8:50 AM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Thanks 00TundraZ!
  14. May 1, 2019 at 10:22 AM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    :cheers:
    This forum has already helped me out a ton, just want to help others if possible!
  15. May 1, 2019 at 2:25 PM
    Cacoleman2014
    Cacoleman2014 New Member
    Louisiana
    2006 Tundra SR5 double cab
    Waiting for the confirmation this will fit 2wd....ready to buy. I cheaped out on the last one and it blew the rubber out the first time I pulled a trailer. Didn't even make 3000 miles
  16. May 1, 2019 at 3:28 PM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    I hope it works out for you!!!
  17. May 16, 2019 at 7:21 AM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Just to update, I installed this and it worked perfectly.
    2000 Tundra SR5 Access Cab 4x4. Mine has the Double Carden joint in case that matters. Just want to give as much info as possible to hopefully help someone else out!
  18. May 17, 2019 at 5:08 AM
    Hand Protectors
    Is your bearing on upside down? Here is a pic of mine newly installed. The larger lobe of the assy was on the bottom on my OEM original. The new OEM was identical.
  19. May 17, 2019 at 6:46 AM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    I concur. The single hole of the bearing assembly should be facing the ground, which puts the 2 holes upward facing the bottom of the truck. It would appear from your photo that the 2 holes are facing the ground. Easy fix, just unbolt those 2 bolts and spin it. That will likely put your driveshaft in a more straight line! :thumbsup:
  20. Jun 27, 2019 at 1:01 PM
    Acatlin96
    Acatlin96 amateur breeze shooter
    Austin
    Central Coast, CA
    2003 AC SR5 V8 4WD TRD
    I don't mean to revive an older thread, but wanted to share my experience with ordering a new carrier bearing today.
    Yesterday I crawled under my truck just to look around, and noticed the rubber on my carrier bearing was torn. I have been hearing a high pitched whine as I accelerate for the past few months, and believe this could be the culprit. I found this thread to check for part numbers, and searched the Spicer 5002334 on www.drivetrainamerica.com. It was out of stock, but also listed for 4WD only. I called them up, and an extremely helpful rep named John saw that the manufacturer was backed logged and wanted to confirm that this was the right part number for my 2003 2WD.
    John later called me back and told me he spoke to their in-house specialist, as well as confirmed with the manufacturer, that the correct part number for the 2WD carrier bearing is actually the Spicer 211750-1X. I was so impressed with their customer service and attention to detail that I ordered the part through Drivetrain America and not Amazon, where it was $6 cheaper.
    So, for all those 2WD owners out there needing to replace their carrier bearing, the part number is Spicer 211750-1X! I will update you all after my installation next week.
    MacNhangin, jmd0792, Jasont and 11 others like this.
  21. Jun 28, 2019 at 11:27 AM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Hey that's great! Thanks for updating it. That's why I made this thread in the first place. To help people realize their carrier bearing may need attention and where/how to find the right quality part for a fair price.
    Thanks for your input!!:cheers:
  22. Jul 2, 2019 at 9:55 AM
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Just ordered one off eBay (out of stock at the link) for $55. Will report back once installed on my 06 DC. Thanks for the heads up!
    Konniekay91 and 00TundraZ[OP] like this.
  23. Jul 2, 2019 at 10:33 AM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    good deal! My hope was to at least supply the right part number for those that need it. I have heard great things about customer service there, but if it's out of stock you gotta get that stuff replaced fast sometimes!
    Best of luck!
  24. Jul 2, 2019 at 11:59 AM
    SCRunner12
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Thanks, just looked up the install. Going to be a bit more work than anticipated haha.
  25. Jul 2, 2019 at 12:30 PM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    IT's not too bad. Just make sure you mark your position of the driveshaft so you re-install the same. an impact makes a world of difference on that project!
  26. Jul 15, 2019 at 6:38 PM
    Cacoleman2014
    Louisiana
    So I ordered one of those 211750-1X bearings. I got it from Amazon, tho It said it would not fit. Put it in today and it seems to work great. I can't really tell over the wheel bearing roaring. Ugh... If it's not one thing....
  27. Nov 11, 2019 at 6:40 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Thanks a bunch amigo! I been needing one of these
    FrenchToasty likes this.
  28. Dec 11, 2019 at 2:16 PM
    Bubbles
    Bubbles Decent!
    Sunnyvale Trailer Park
    05 Tundra Limited, 96 Supra Turbo 6MT
    Ordered, thanks for that heads up!
  29. Dec 13, 2019 at 2:28 PM
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
    Good info. I was getting ready to purchase an OEM after a lot of cringing at the OEM price.
  30. Dec 13, 2019 at 4:28 PM
    Bubbles
    Bubbles Decent!
    Arrived in two days, that’s crazy quick for something that isn’t Amazon!
    bmf4069, Trailscape and TX-TRD1stGEN like this.
