"Correct" Order of a few MODS
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kevin80, Apr 20, 2021.
  1. Apr 20, 2021 at 8:30 AM
    Kevin80
    Kevin80 [OP] New Member
    2016 SR5 Crewmax
    I am looking to get the following done in the next few weeks, but was wondering what the "correct" order should be:
    1) Spray-in bed-liner
    2) Retractable tonneau cover
    3) Undercover swing-out cases
    My initial thought was to get the liner sprayed before everything else but I am wondering if it will be easier to install the Undercover cases BEFORE the liner gets sprayed.
    Thanks for any insight.
  2. Apr 20, 2021 at 8:39 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    liner first, otherwise they will need to uninstall the cases to do the liner.
    bediner
    case
    tonneau
    is what I would do.
    tttrdpro and Cpl_Punishment like this.
  3. Apr 20, 2021 at 8:39 AM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    I would install the brackets for #3 (have them lined over) and then do #1, then do #2.
    Black Wolf and Saltyhero13 like this.
  4. Apr 20, 2021 at 8:40 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Agreed
  5. Apr 20, 2021 at 8:40 AM
    clarkritchie
    clarkritchie New Member
    My factory spray-in liner fully covered the T55 bolts on my bed, meaning if I ever want to loosen them to install, say, the Victory molle panel or whatever, I will mess up the spray on those bolts. In other words, I would seriously consider what might get sprayed which would make installing those other bits a hassle, and at a minimum mask them off. Or install them, then uninstall them, mask them off, etc.
    frichco228 and panicman like this.
  6. Apr 20, 2021 at 8:42 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    This
  7. Apr 20, 2021 at 9:01 AM
    coolj34
    coolj34 New Member
    Justin
    2017 Crewcab SR5
    Great idea. That's thinking ahead!
  8. Apr 20, 2021 at 9:45 AM
    Kevin80
    2016 SR5 Crewmax
    Thanks for the help!! I just read another thread that goes over the install but it's a few years old, does anyone know if they bracket/install has changed? It looks like (based on pics from that thread and pics of the cases online) that the case itself has changed a bit...
  9. Apr 20, 2021 at 11:12 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    I don't have the current instructions but would get some silicon plugs to put in the holes you don't want Bedliner in. This is what I have for my painting etc...
    https://www.amazon.com/gp/product/B00LHXN7JK/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8
    Kevin80[QUOTED][OP] likes this.
  10. Apr 24, 2021 at 6:51 PM
    Kevin80
    2016 SR5 Crewmax
    I took the drop in liner out (and installed the brackets for the under cover cases) in anticipation of the spray in liner but I noticed 14 threaded holes with nothing in them under the liner... is that normal? Any idea what they’re for?
    Theres 4 at the front of the bed and 5 down each side.
  11. Apr 25, 2021 at 1:15 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
  12. Apr 25, 2021 at 4:59 AM
    Yep, bed rail bolt on points. You need to decide if you want bed rails too. I have a retractable cover that attaches to my existing bed rail. If you are not getting red rails you need to plug up those holes. If you don't and you change your mind and decide to get red rails, those holes will be a pain to use. Definitely plug them with the silicone or plastic plugs. ACE Hardware should have them.
  13. Apr 28, 2021 at 9:33 AM
    Kevin80
    2016 SR5 Crewmax
    Thank you.
