Cornering lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by bensky, Nov 27, 2023.
  1. Nov 27, 2023 at 10:39 PM
    bensky
    bensky [OP] PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    I had a Nissan Maxima back in the day that had cornering lights and I’ve missed them ever since. The Rough Country front bumper kit comes with 4 fog lights. 2 are more than adequate. So, I aimed 2 of them out and tapped into the turn signal switches to activate the relay to turn them on and off. The wires that plug into the harness on the turn signal assembly are negatively switched so you’ll have to wire the relay to be triggered with the ground (see diagram below I found on YouTube.) The wires on my 2018 are light green for left turn and dark green for right turn. If you have a different year, a simple multimeter can help you find the right colors for yours. I only use waterproof relays and seal and solder the connections with these cool connectors on the Amazon link. Now I don’t know how I ever lived without them!IMG_0017.jpg IMG_0010.jpg IMG_0009.png
    The video is distorted as it’s from the wide angle lens on my dash cam, but it gives you the idea.
    https://youtu.be/pfnIJXnHJEc?feature=shared
    Amazon link:
    Limited-time deal: Kuject 200PCS Solder Seal Wire Connector Kit, Solder Seal Butt Terminal Waterproof Insulated Electrical Butt Terminals Wire Splice for Automotive Marine Boat https://www.amazon.com/dp/B083LZS69N
    Saltyhero13, 1UP, KNABORES and 4 others like this.
  2. Nov 28, 2023 at 3:38 AM
    biebs96
    PA
    Very cool!
    ryanwgregg likes this.
  3. Nov 28, 2023 at 5:03 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Neat little mod, looks great... :thumbsup:
  4. Nov 28, 2023 at 6:22 AM
    Skaufma0
    Skaufma0 Just a little stitious.
    Rock Hill, SC
    2018 MBM Limited CM
    This is awesome. Here's me trying to figure out a way to do this with a factory bumper. :facepalm:
    biebs96 likes this.
