Coolent leak and cam tower leak?
Discussion in '2.5 Gen Tundras (2014-2021)' started by rodm1, Jul 5, 2020.
  1. Jul 5, 2020 at 7:45 AM
    rodm1
    rodm1 [OP] New Member
    Guy's it looks like I have some kind of coolant leak (water pump?) and a cam tower leak on passenger side. They are dry but you can see the trail they make. My question is sow they are dry but leaking and my warranty is up at the end of the Month how should I handle this with Toyota? Should I get a claim number from Toyota corporate since my warranty is up at the end of the month?
    Will talk to dealer Monday to get this moving.
  2. Jul 7, 2020 at 8:19 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Any update ?
  3. Jul 18, 2020 at 6:42 AM
    rodm1
    Toyota said they will replace the water pump but they will hold of on the cam tower until it leaks more then they will cover the cost. It's just a stain on the block not wet and I didn't won't the engine opened up at this time anyways.
    I'm happy with that it gives the driver side more time to start to leak before tairdow begins. Would be nice to just fix this problem at the assembly plant.
