Coolant temp gauge
Discussion in '1st Gen Tundras (2000-2006)' started by 88mmalloy, Apr 15, 2020.
  1. Apr 15, 2020 at 1:53 PM
    88mmalloy
    88mmalloy [OP] New Member
    mike
    Ok so my issue is, my temp gauge is not working. Every other gauge on the panel works fine. Plugged in my meter and it’s not throwing any codes. Also, I replaced the coolant temp sensor. Any ideas?
  2. Apr 15, 2020 at 2:56 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    What year/make vehicle are you working on in case you might need FSM schematics for troubleshooting purposes ?
  3. Apr 15, 2020 at 3:00 PM
    88mmalloy
    mike
    It is a 2003 tundra v6 sr5
  4. Apr 15, 2020 at 3:06 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Adding that info to your profile can be a big help !
    Attached are applicable pages from 2003 FSM showing checks one can make !
    TTund16 and FrenchToasty like this.
  5. Apr 15, 2020 at 3:53 PM
    88mmalloy
    mike
    Thanks so much! This goes a little bit above my knowledge but I can dive into it if need be. With all of these possible issues in the pdf, do you think just replacing the instrument cluster would work? I can get a pretty cheap one from the junk yard near me. Thanks again
  6. Apr 16, 2020 at 4:51 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    In all honesty, if those 3 checks are beyond your capability, replacing the instrument cluster would be a quick and dirty way, if it is indeed "cheap".
    What happens if you tap the cluster in the area of the temp gauge, do you have needle movement ?
