Coolant in oil
Discussion in '2nd Gen Tundras (2007-2013)' started by Bktrd4x4, Nov 23, 2019.
  1. Nov 23, 2019 at 11:27 AM
    Bktrd4x4
    Bktrd4x4 [OP] New Member
    New York
    2010 tundra red
    Hey everyone
    The motor locked up in my 2010 tundra 5.7 and I drained about 1 gallon of coolant out of the oil pan. I just had the air management valves replaced by a dealerdeale 3000 miles ago Could this have anything related to the replacement of the air valves? Or what would have been the cause of this the truck was running great no signs of overheating. This happened really quick.
  2. Nov 23, 2019 at 12:23 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
    There has to be some sort of breakdown of a gasket or seal between the coolant and oil. Head gaskets are the usual culprit
    14CRWMX and Jrharvey02 like this.
  3. Nov 23, 2019 at 12:31 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    How many miles on that 2010 Tundra? Which # owner are you?
  4. Nov 23, 2019 at 2:07 PM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    +1. Lockup probably hydrolock caused by coolant in one of the cylinders.
    Greg
  5. Nov 23, 2019 at 2:56 PM
    NWExplorer
    NWExplorer this guy
    Washington
    2010 CM Platinum 4x4
    Take it back to the dealer but watch/read about the AIP valve replacement process first so you have ammunition.
  6. Nov 25, 2019 at 9:35 AM
    Bktrd4x4
    New York
    2010 tundra red
    The truck has 153000 miles on it I'm the second owner. I would like to say thanks for the replies. Going to pull the spark plugs and see if it woll turn over and go from there.
  7. Nov 26, 2019 at 2:54 PM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    sorry to hear. Keep us posted
