Coolant in oil 2008 5.7
Discussion in '2nd Gen Tundras (2007-2013)' started by Rontech71, Nov 16, 2019.
  1. Nov 16, 2019 at 5:20 AM
    Rontech71
    Rontech71 [OP] New Member
    2008 Tundra
    I have a 2008 with a 5.7 and under the oil fill cap it is full of "snot". The oil doesn't look milky and I see no signs of coolant when I do an oil change. Has anyone else seen this? Is it cause for concern? Maybe a PVC problem?
  2. Nov 16, 2019 at 5:30 AM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Short trips? My 06 did this due to the one mile commute to work. Never got up to temp
    MS22 and 15whtrd like this.
  3. Nov 16, 2019 at 5:34 AM
    Badger Co-Op
    Badger Co-Op Blood sausage, cheese, and lutefisk; hit me!
    Kenny
    WISCO
  4. Nov 16, 2019 at 5:35 AM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    I just noticed this same thing yesterday on mine. The oil that I drained was not milky at all, and the coolant was just fine.
    A google search mentions that this is normal in cold weather, and I hope that is correct.
  5. Nov 16, 2019 at 5:42 AM
    Rontech71
    2008 Tundra
    Nope not short trips. I drive 25 miles one way to work and back every day. Engine is getting up to temp quickly as it should and stays there. 169,000 miles, very few short trips throughout its life.
  6. Nov 16, 2019 at 5:46 AM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    If you are are not losing coolant, more than likely condensation in engine. Pretty normal in cold weather and short trips. Normally find at top of engine.
    MS22, Trooper2 and 15whtrd like this.
  7. Nov 16, 2019 at 5:47 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    It is just condensation caused the the engine heating up and cooling down. If you drive short distances the engine does not get hot enough or stay hot long enough to let the moisture evaporate.
    I would not worry unless the oil in the pan started looking funny.
    MS22 likes this.
  8. Nov 16, 2019 at 10:29 AM
    Dr_Al
    Dr_Al New Member
    Al
    Yep, nothing to worry about.
  9. Nov 16, 2019 at 1:47 PM
    Rontech71
    2008 Tundra
    I know GM cars and trucks have trouble with intake manifold gaskets due to the plastic/silicone material used. I have changed many of these gaskets and the first sign of trouble was this same type of snotty yellowish gunk under the oil fill cap. Has anyone had an intake off of a Tundra 5.7? I have no idea what type of gasket these engines have. I do not drive very many short trips with my truck. I drive 25 miles one way to work every day. I did a water pump and thermostat last year and used an after-market thermostat. I have noticed it doesn't seem to get to operating temp as quickly as it used to but it does get there within the first 3-4 miles and stays there.
  10. Nov 16, 2019 at 4:24 PM
    Fourknights
    Georgia/Florida
    If you are not losing coolant no worries.
    MS22 likes this.
  11. Nov 16, 2019 at 7:12 PM
    ND_Porkchop
    ND_Porkchop New Member
    2008 Tundra 5.7 CM DSM
    Order a sample kit from black stone labs if you are worried.
    I don't feel like there are many head gasket issues on the forum, so unless you are losing coolant and/or the oil looks like chocolate milk, I prob wouldn't worry
    MS22 likes this.
  12. Nov 18, 2019 at 4:18 PM
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    Pretty common on past vehicles I have owned. I just wipe it off. It went away on my 4runner after I changed the PCV but that may have been a coincidence as winter hasn’t come around again.
