Coolant Flush
Discussion in '2.5 Gen Tundras (2014-2021)' started by Andrew_Tress, Mar 24, 2023.
  1. Mar 24, 2023 at 9:02 AM
    Andrew_Tress
    Andrew_Tress [OP] New Member
    Andrew
    2014 Tundra SR5 5.7l
    Hi -
    What is the right method for doing a coolant flush in a 2014 5.7l? I have seen conflicting methods on youtube.. I want to drain and fill with coolant cleaner and then drain and replace coolant.
    Cheers
  2. Mar 24, 2023 at 10:49 AM
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Here's the best tutorial: https://youtu.be/OivwKhMyLxs
    No need to flush with cleaner unless your current coolant is in poor condition. Draining the radiator from the lower port and draining the block from drain cocks is adequate for most.
