Cooking turkey in a smoker temp?
Discussion in 'Off-Topic Discussion' started by MS22, Nov 27, 2019.
  1. Nov 27, 2019 at 7:20 PM
    MS22
    MS22 [OP] New Member
    02 Tundra 4x4
    This year will be my first time smoking a turkey (16lb) in my smoker. I have read a lot of threads and I noticed that the smoking temperatures vary from 225 degrees to 325 degrees and I have a hard time understanding what temp is better.
    Has anyone here cooked a turkey in a smoker and what temp did you use?
    What about spatchcocking is that a better way to go?
    Thanks much and wish you all an early Happy Thanksgiving day!
    ColoradoTJ likes this.
  2. Nov 27, 2019 at 7:28 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I have smoked mine with temps hovering at or around 240 degrees. I do 30-35 minutes per pound. But it is going to depend on how long you have before serving dinner. I am sure your guests will appreciate the deliciousness that you’ll be serving them tomorrow. Good luck
    MS22[OP] likes this.
  3. Nov 27, 2019 at 7:28 PM
  4. Nov 27, 2019 at 7:29 PM
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
    Spatchcock 100%. Line a baking pan with tin foil and put the spatchcocked bird flat on the pan in the smoker. 16 lb bird I would do 300F-325F for 3 ish hours I’m guessing. I don’t think they come out as good at 220 for 7 hours. Yoder Smokers/ALl Things BBQ has a good video on the whole process.
  5. Nov 27, 2019 at 7:31 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I like smoking turkey, spatchcoked, under 250 maybe 230 or 240. The one thing is the skin will not get crispy so for turkeys I will smoke it at 230 for a few hours then bring it in and finish it in the over to crisp it up. Make sure you put a tin pan under it in the smoker, and I toss all the giblets and neck in there with some Turkey stock. Collect all those drippings and flavors and make yourself an amazing smokey gravy.
  6. Nov 27, 2019 at 7:44 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Go to How to Barbecue Right with Malcom Reed online. He is a big country boy so you know he knows how to cook. It’s great website for beginners and experts to learn tricks of the BBQ trade. He goes over temp, types of smokers types of wood etc. His recipes are all excellent.
  7. Nov 27, 2019 at 7:48 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    100% spatchcock. I did one last night for one side of the family and everyone raved about it. I don't like low and slow with birds cause i think they get too dry.
  8. Nov 27, 2019 at 8:30 PM
    Blue Thunder
    Washington
    - 24hr brine
    - Cook for 20-25minutes/lb at 250 degrees (at the grill, not the smoker temp)
    - Watch the temp in the breast. Remove from the smoker at 155 degrees
    - Let rest for 30+ minutes.
    Meat is always amazing and moist.
    I don’t inject as I’ve never found it to add anything. I get a seasonal brine every year, but only because I’m lazy. Just a salt water solution works great too.
  9. Nov 27, 2019 at 8:34 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    325F gets the skin crispy. Use a good thermometer. Internal temp 160 for the breast and 170 for the thighs and yeah spatchcock is good, deconstruct is also good.
    Put some salt on that thing tonight and smoke away.
  10. Nov 27, 2019 at 8:37 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    First to this post... Malcom is awesome and his videos are entertaining. Check out his Meatball sub video. Recipe for marinara is the best I have made.
    Back to turkeys I am smoking mine tomorrow as well. It will be my first so I am not an expert. However, the plan is 225 till internal of 110(breast) then finish it off at 375 till 155-160. Brined yesterday, air drying today, butter under and over skin tomorrow morning.
  11. Nov 27, 2019 at 8:42 PM
    Rica25
    Ricardo
    Tulare
    My brisket is going in the smoker here shortly
  12. Nov 27, 2019 at 8:59 PM
    goldldr
    goldldr New Member
    Andy
    Spring,TX
    2019 SR5 CrewMax (Cavalry Blue)
    This is pretty much what I do when smoking a turkey. It turns out well every year. I don’t like the flavor injections, but I prepare a brine and then after brining I put spices and butter under the skin and aromatics in the cavities as well.
  13. Nov 27, 2019 at 9:05 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Just make sure your guests and family know that the Pink meat is from smoke....not raw turkey. If you can pull a gravy out of it, it's amazing too.
    I'm in the higher temp, spatchcock camp. Dry rub/brine.
    Times will be vary a lot. Make sure to test breast and thigh for doneness. If you do it right and spatchcock, they'll be done at the same time.
  14. Nov 27, 2019 at 9:06 PM
    Aerindel
    Aerindel New Member
    Montana
    Spatchcock....always, then 325º in the smoker, not using too much smoke, a little goes a long way with poultry.
  15. Nov 27, 2019 at 9:16 PM
    MS22
    02 Tundra 4x4
    Thank you all for the tips they are greatly appreciated:) Any particular chips you use? I have hickory, cherry and apple.
  16. Nov 27, 2019 at 9:32 PM
    Aerindel
    Aerindel New Member
    Montana
    I always use cherry. The year I used hickory it tasted a little like an ash tray.
    JMB and MS22[OP] like this.
  17. Nov 27, 2019 at 9:33 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    I just did a 22lb turkey last weekend on my Green Mountain Grill (pellet) at 225 degrees. Turned it up to 350 degrees for the last 1.5 hours because I was freaked out it wasnt going to be done. I didnt do spatchcock, didnt even know what it was until seeing it here. Took about 10 hours to get to 160 degrees and was fantastic. Everyone was raving about it at our party. I mixed a stick of butter with a dry rub and put it on the meat under the skin.
  18. Nov 27, 2019 at 9:37 PM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Yeah, I would use a fruit wood with poultry. Cherry, apple, etc.
    Rica25 and MS22[OP] like this.
  19. Nov 27, 2019 at 9:45 PM
    unclebeejo808
    unclebeejo808 New Member
    Oahu
    What’s the benefit of spatchcocking it? I’ve cooked them whole and always came out perfect. If you want crispy skin just turn up the smoker to 350 for the last 45 minutes.
  20. Nov 27, 2019 at 9:49 PM
    Blue Thunder
    Washington
    This is very true. The white meat will have some pink because of the smoke. Trust your temp reading, but the juices are another good indicator. If they’re clear, then the meat is cooked. Still murky or bloody and the meat isn’t cooked enough.
    And definitely find a way to keep the renderings. They’re amazing for gravy.
  21. Nov 27, 2019 at 9:51 PM
    Blue Thunder
    Washington
    I’ve used lots of different pellets and never tasted a difference. I do only use 100% wood blends from a reputable brand to ensure quality and no filler crap in the wood. If you’re using block hardwood, then your results may be different.
    Rica25 and MS22[QUOTED][OP] like this.
  22. Nov 27, 2019 at 9:53 PM
    Aerindel
    Aerindel New Member
    Montana
    Massively shorter cooking times....which results in moister turkey. Instead of cooking a turkey being an all day affair you're talking just a couple of hours. Because it cooks so fast, there is very little risk of it getting dry.
  23. Nov 27, 2019 at 10:12 PM
    MS22
    02 Tundra 4x4
    I just found out about the spatchcock today searching threads today. Even though I allready stuffed the turkey with apples, carrots, onions and celery I'm going to try the spatchcock way.
  24. Nov 27, 2019 at 10:15 PM
    Aerindel
    Aerindel New Member
    Montana
    Once you spatchock, you never go back. :)
    Just adjust cooking times accordingly, a spatchcocked turkey will cook in about a quarter the time of a stuffed bird.
  25. Nov 27, 2019 at 11:19 PM
    MS22
    02 Tundra 4x4
  26. Nov 27, 2019 at 11:48 PM
    Aerindel
    Aerindel New Member
    Montana
    325º, if your smoker gets that hot.
    Mine doesn't so I smoke it at about 250º for an hour and then move it to the inside oven at 325º For the last hour to hour and a half. Even for a 20lb turkey its done in less than three hours this way. (160º breast meat, 180º thighs)
    MS22[OP] and Rica25 like this.
  27. Nov 28, 2019 at 12:46 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Brine, spatchcock, inject, under skin baste with butter or mayo, outside dry rub, 325* for 4 or 5 hours or when IT hits 160-165. Monitor skin in later portions of cook, if you get to about 140 IT and skin is still real soft crank the heat up.
  28. Nov 28, 2019 at 1:38 AM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Another vote for Howtobbqright, Malcom Reed, youtube and he has a website with the video links there.
    I don't brine a bird, never had any issues with a dry bird. Your mileage may vary, lots of folks do tho. Same with the spatchcock method.
    What kind of smoker? I prefer to use apple or cherry wood for pork and poultry. Use it for beef as well but thinking about changing to hickory or oak for a few smokes.
    Good luck, enjoy the day and smoke on. It is raining here so I am cooking inside today.
  29. Nov 28, 2019 at 3:55 AM
    shawn474
    MoCo, Maryland
  30. Nov 28, 2019 at 6:14 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Spatchcock is where it's at. As discussed above, it's quicker, moister and crispier skin.
    For the gravy from smoked type birds we do on our charcoal or wood smoker ...our kids call it "Liquid Gold" as it's so good
