Contaminated coolant
Discussion in '2.5 Gen Tundras (2014-2021)' started by Inder, Aug 26, 2020.
  1. Aug 26, 2020 at 3:51 PM
    Inder
    Inder [OP] New Member
    Inderjit
    2014 Tundra SR
    upload_2020-8-26_15-49-7.jpgAny idea guys what this might be i hope not the gasket on headupload_2020-8-26_15-50-4.jpg
  2. Aug 26, 2020 at 4:14 PM
    Inder
    Inderjit
    2014 Tundra SR
    Above is at cold temp and below is warm
  3. Aug 27, 2020 at 7:18 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I think there is a test you can perform to see if there are hydrocarbons in the coolant. At first I thought it may have been casting sand that could have been left in the block and circulating in the coolant, I know the 6.0 power stroke had that problem. But after looking at the second picture I really dont know, because it has a bigger footprint. You could get a suction gun and pull it out from the bottom of the coolant reservoir, and then inspect it in a shallow bowl or tray, if its oil you should be able to tell by rubbing it in between your fingers.
  4. Aug 27, 2020 at 7:48 PM
    Inder
    Inderjit
    2014 Tundra SR
    I did flush the system today. It is white looking fibers I would say. Not oil as it just sits at bottom.
  5. Aug 27, 2020 at 7:50 PM
    Inder
    Inderjit
    2014 Tundra SR
    As you said it does looks like something from casting. But it is not oil though. I will keep an eye on it all new coolant in system now.
  6. Aug 27, 2020 at 7:58 PM
    Sumo91
    TN
    Fibers? Like small strands of string?
  7. Aug 27, 2020 at 8:06 PM
    Inder
    Inderjit
    2014 Tundra SR
    upload_2020-8-27_20-5-59.jpgMore like this
  8. Aug 27, 2020 at 8:06 PM
    Inder
    Inderjit
    2014 Tundra SR
    Whitish material
  9. Aug 27, 2020 at 8:12 PM
    Inder
    Inderjit
    2014 Tundra SR
    It breaks apart when I shake the bottle but after sometime settles at the bottom which is what happened in the expansion tank.
  10. Aug 28, 2020 at 5:17 AM
    linwozzle
    linwozzle New Member
    Linden
    2014 SW Tundra Platinum 4x4 CM
    When was the last tie the fluid was flushed and replaced? Hopefully its none of that fix a leak in a bottle
  11. Aug 28, 2020 at 8:56 AM
    Inder
    Inderjit
    2014 Tundra SR
    This was first time
  12. Sep 13, 2020 at 6:46 PM
    Inder
    Inderjit
    2014 Tundra SR
  13. Sep 13, 2020 at 6:46 PM
    Inder
    Inderjit
    2014 Tundra SR
  14. Sep 14, 2020 at 5:56 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I suspect those deposits represent precipitated inhibitors or aluminum corrosion products due to (1) contamination of the cooling system with other products, (2) neglected maintenance, or (3) out-of-spec coolant with too-much or too-little corrosion inhibitors. These alone do not represent a serious condition, or anything that can be repaired. If you want to confirm this diagnosis, you can collect a sample and have it analyzed (See link below).
    https://www.labcheckresources.com/w...2/Coolant-System-Maintenance-Guide-FINAL1.pdf
    Thoroughly flush the cooling system to remove the precipitated solids and replace the coolant with Toyota or Zerex Asian antifreeze. If you buy concentrate, only use distilled water for dilution.
    Toyota coolant was one of the original long-life coolants, and I believe uses HOAT (hybrid organic acid technology) chemistry. It should not be contaminated, or "topped-off", with anti-freeze using other chemistry types.
  15. Sep 14, 2020 at 10:14 AM
    Inder
    Inderjit
    2014 Tundra SR
    Thank very much
