Console to Seat Conversion
Discussion in '2.5 Gen Tundras (2014-2021)' started by Motox, Jan 4, 2019.
  1. Jan 4, 2019 at 11:41 AM
    Motox
    Motox [OP] New Member
    Mississippi
    2020 Tundra CrewMax 4x4
    Hi new here and I’m going to be swapping my center console, steering column, shift cable, etc with jump seat and column shifter. I’ve got a 17 CM TSS SR5 with black and grey cloth interior. I’ve already purchased a column with shifter and that’s all. If anyone wants to sell or trade seat for column, shift cable, plastic dash pieces, and whatever else may be needed please let me know. I’ve got a 4th child on the way and will loose my @$$ if I trade(plus I don’t wanna loose the big fuel tank)! Thanks
  2. Jan 4, 2019 at 11:52 AM
    Nick452
    Nick452 New Member
    2019 SSM CM
    Even if you could get all of the pieces to make the switch aren't there some legalities with insurance and/or safety since this was not designated as a 6 passenger vehicle? This is where I wish Toyota offered the 38 gallon tank with the bench seat as an option. I guess it saves them enough $$ to not do so.
  3. Jan 4, 2019 at 12:23 PM
    Motox
    Mississippi
    Maybe. There’s a lot of ridiculous safety regs out there however, I’m not modifying anything it’s all bolt on. And between the two tanks its only an 80lb difference. I couldn’t see it affect insurance being that ppl cut frames and crossmembers to install suspension lifts but if I do get in that situation to use insurance, hopefully I won’t, then it was like that when I bought it... lol
    TRD-tv likes this.
  4. Jan 8, 2019 at 6:57 PM
    Motox
    Mississippi
    Well i have narrowed it down on the shift cable I need p/n 338200C120. That and a seat and I should be ready for the swap. If anyone out there is converting their bench to console message me. Any help for parts or advice I’d appreciate it.
  5. Jan 10, 2019 at 7:04 AM
    Nick452
    Nick452 New Member
    2019 SSM CM
    Good luck! I hope it works out for you.
  6. Mar 12, 2019 at 6:47 AM
    wanderingturtle
    wanderingturtle New Member
    I'm looking to buy a tundra and I need seating for six, which seems rare, so I may wind up doing this kind of swap too. Please document the process.
    dasunsrule32 likes this.
  7. Mar 12, 2019 at 6:49 AM
    Welcome from NY.
  8. Mar 13, 2019 at 12:48 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    If this works out I would love to see some pictures as I miss my 6th seat terribly.
  9. Mar 13, 2019 at 2:03 AM
    KLLVMDCL
    KLLVMDCL New Member
    Brandon
    Austin, Texas
    2017 Super White DC SR5
    just curious why you want the bench seat? the center console was a deal or no deal option for me
  10. Mar 13, 2019 at 6:16 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    Why not just get a SR or WT model?
  11. Mar 13, 2019 at 6:31 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    After doing a similar conversion (auto trans column shift to manual on the column) as a teen, this is not something I would take on at my age with a 2017, but you have good reasons.
    It is doubtful that there is any legal problem with the conversion because the SR5 comes standard with a 40/20/40 front seat and column shifter. The TSS package requires the SR5 Upgrade package as the starting point, and that's why you have the bucket seats and console. Practically speaking, in Texas I doubt that law enforcement cares what you do to your vehicle unless you tinker with the Feds environmental bs, and then it would be tough to get them interested.
    Advice: Forget part numbers. Buy everything you need, as a package deal, from a salvage yard. You start buying parts from Toyota to do this, and you will spend a fortune. Depending on how much this conversion will cost, you might want to just consider another SR5 CM.
    Tundyfundy likes this.
  12. Jul 9, 2019 at 6:01 PM
    Motox
    Mississippi
    Update just to keep this going. Just bought a center seat that matches in color and has air vents. Super hard to find that’s not $400+! Looks like I may break even after I sell all my stock stuff(column, shifter, console, cable, etc). Still on the hunt for shift cable and maybe a wire harness( too hot outside to start ripping apart just yet).
    Magnetic15 likes this.
  13. Jul 9, 2019 at 7:27 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Dude I’m interested in seeing how you pull this off. Never seen it done so keep us in the loop!
  14. Oct 20, 2019 at 2:04 PM
    Motox
    Mississippi
    upload_2019-10-20_16-1-30.jpgCan anyone with a column shifter see a p/n on the wire harness that goes to this connector I’m pointing to in the pic? If I can get this wire harness this conversion seems pretty possible
    HulkSmurf14 likes this.
  15. Oct 20, 2019 at 2:44 PM
    JohnLakeman
  16. Oct 21, 2019 at 5:42 AM
    Magnetic15
    Magnetic15 Steel City Member
    Eric
    2015 Platinum Crewmax
    2019 TRD Pro Black LED Headlights, 2019 TRD pro grill. Color matched door handles. Diamondback Tonneau cover.
    Looks like part 9/10 are the wiring controls for the shift lever. I'm curious to know if the upper/lower shroud for a column shift will work with power tilt.
    Do you have any pictures of this center seat with vents? I'd like to see it
  17. Oct 21, 2019 at 6:09 AM
    Motox
    Mississippi
    Not many good pics yet. Still have a few parts to buy but don’t wanna get too deep in buying stuff until I get this wiring figured out. The seat and new column fits great but will need a new air duct and column shrouds. Just stuck on this wiring for now. Definitely gonna be the deciding factor wether I push forward or trade the truck in for a loss. Prob gonna have to swing by a dealership n take a peek under the dash to see this wire harness I need if I can find a tundra with a column shifter which seems rare.
  18. Oct 21, 2019 at 7:25 AM
    JohnLakeman
    Check that white connector on the left side console harness to see if it matches the connector on your steering column. If you find they match (shape, number of wires, size, wire colors), that says the connector you're pointing to is for the shift lever position...your hope is still alive imo.
    The main harness behind the dash may be different for the floor shifter and the column shift models, which means the conversion is still possible, but you'll likely have to build an adapter harness from the console area to the column location. Toyota won't sell such a harness.
    If you find building an adapter harness is necessary, I would start by finding wrecked column shift Tundra and buying all the wiring harness I could from the connector you're pointing to back to the main harness, You can extend the wires with same gage wire and add a connector at the other end to match to the console harness.
  19. Oct 22, 2019 at 3:10 PM
    Motox
    Mississippi
    Yes you are probably right. The biggest problem I’ve been having is finding a wrecked tundra with a column shifter. Even the dealerships around me don’t have em. If I can ever get past this wiring it will b possible.
  20. Oct 23, 2019 at 8:26 AM
    Magnetic15
    Eric
    eBay has a few, ~$100, only thing stopping me from buying one to test fit is do I need an entire column, or just bits and pieces to swap over. Spent too much this month on exhaust and wheels and tires lol
  21. Oct 23, 2019 at 9:14 AM
    Motox
    Mississippi
    Prob should have been more careful w my words but I meant it’s hard to find a totaled tundra with a column shifter so I can take the wire harness from it. I have a steering column with the shifter no tow haul and it fits perfectly! Also I’ve put the new seat with vents in place and it fits perfectly. What I need is a new air vent, a small dash panel, and a shifter cable however, I won’t buy anything else until I can get this wiring figured out. I wish someone could snap a pic of their wire harness or maybe see if it has a p/n on it. Gonna have to keep calling around to junk yards, maybe I get lucky.
  22. Oct 23, 2019 at 10:35 AM
    Archtaan
    Archtaan New Member
    2017 SR5 Crewmax. Bench seat. 4x4 5.7
    Nada yet.
    Hi, I pulled my column apart to see if I could find you the part number for that connector. Unfortunately the part that is exposed doesnt have any part numbers and it connects to the other main harness with the other 4 separate connectors as seen in the top right of pic. At least you can maybe check the colors of the wires to see if you can match them up - White Red and light blue I think.
    Couldnt get my phone at a good angle to get a better pic. I followed it back as far as I could but could not find a part number anywhere. If there is anything else under there you have questions on let me know. Sorry I couldnt be more helpful.
    ZappBrannigan and Motox[OP] like this.
  23. Oct 23, 2019 at 10:53 AM
    MGM
    MGM New Member
    Good luck to you as this seems like much work. 4th gen tundras need this as option.
  24. Oct 23, 2019 at 12:14 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    You're gonna need more carpet there in the front as the console won't cover that hole. Husky liner sells a transmission hump floor mat that I run in my truck. It's like 10 dollars and will cover that area.
    Motox[OP] likes this.
  25. Oct 23, 2019 at 12:35 PM
    Motox
    Mississippi
    Thank you! That is probably gonna answer my question about which bundle goes where in the column, now I need to find out where it connects to at the main harness. Have a pretty good idea. I’ll snap a pic when I get home today.
  26. Oct 23, 2019 at 1:56 PM
    Motox
    Mississippi
    Here’s some images of my factory harness.
    (1)-steering wheel controls, prob same on all
    (2)-goes to side of ignition. Won’t b used for new column.
    (3)-4 connectors tapped away not being used. I figured these are the ones the harness I need goes to. A few promising pins when I run a ohm chk from connectors (4).
    (4)-goes to console shifter. Lower connector goes to manual shift and upper are the wires that are in question.
  27. Oct 23, 2019 at 1:58 PM
    Motox
    Mississippi
    Can anyone find out if the harness I need goes to the 4 blank connectors(3)? I’m pretty sure the stock wires (4) go through some type of controller.
  28. Oct 24, 2019 at 7:41 PM
    Archtaan
    Archtaan New Member
    Nada yet.
    Ill see if I can check mine this weekend if its not raining.
  29. Oct 24, 2019 at 7:54 PM
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    My 2019 sticker shows the truck as originally having a bench seat but a center console/seat conversion option was added. It is a Gulf States TSS. Maybe that is the legality that would allow the conversion back to 6 passenger. I am sure it is from factory with center console and buckets.
  30. Dec 30, 2019 at 7:47 PM
    Hatric
    Hatric New Member
    2015 Gray Tundra SR5 4X4
    How far are you with this swap?
    I need to get a shift cable assembly, but have a seat and a steering column. From a scrap yard. FYI LKQ is where you need to go to get your junk yard parts.
    The column I bought came with ~12" of harness cut off so I have the top part of the cabling for the column shift.
    It's attached to 3 other plugs through a white w/ black stripes cable.
    Looks like a signal cable or something.
    My tow package is on the dash so I got the column w/o tow.
    (5) Is the plug that attaches to the column shift portion of the new (to me) column.
    I wonder if one of those three unused cables match this cable and if that's the case I wonder if you have to do anything at all about the old console cables other than tape them out of the way.
    Other thing I'm having issues with is removing the ignition cylinder from the new column so I can swap mine into it to keep the key the same.
