Connecting Aftermarket Fog Lights
Discussion in 'Lighting' started by worktruckwhite, Jul 15, 2019.
  1. Jul 15, 2019 at 12:30 PM
    worktruckwhite
    worktruckwhite [OP] bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    Hey, I’ve got four of these fog lights and I don’t know how to connect them. My truck is wired for fog lights, I just need the connector for these wires. Where can I find them?0CCC1C4C-48A7-4AA1-A8AA-72ED1A45E102.jpg0C54A253-2F2D-4905-9348-90A2BFAB4FEA.jpg
  2. Jul 15, 2019 at 1:44 PM
    throughitalldude
    throughitalldude New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
    To run those your going to have to clip off the stock connector and hard wire them accordingly. Red to red and black to black. If your not okay with that you will have to get yourself the opposing female connector and wire it onto the fog light's leads. Easier if you just snip those wires and wire them together with your choice of crimp on connectors from your local auto parts store.
    worktruckwhite[OP] likes this.
  3. Jul 15, 2019 at 2:07 PM
    worktruckwhite
    Charleston, SC
    2010 White Crewmax
    Thanks. I’ll probably clip them since it’s not like I’m going to run anything else in the future.
  4. Jul 15, 2019 at 2:26 PM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
  5. Jul 15, 2019 at 2:28 PM
    toyotech2016
    toyotech2016 New Member
    2016 Tundra 1794 2004 Tundra TRD 2004 Sequoia Limited 1988 4Runner LT
  6. Jul 15, 2019 at 3:34 PM
    groverdill
    groverdill New Member
    joe
    Rathdrum ID
    I would also suggest not cutting the factory harness, spend the few bucks get the adapters as shown
  7. Jul 15, 2019 at 3:56 PM
    worktruckwhite
    Charleston, SC
    2010 White Crewmax
  8. Jul 15, 2019 at 4:00 PM
    groverdill
    joe
    Rathdrum ID
    Just tie the lights together, it isnt perfect but it is better than cutting the factory harness. I did this with the 4 lights in my DV8 bumper on my 2nd gen, works fine. LEDs dont draw much power at all.
    Berdine likes this.
  9. Jul 15, 2019 at 4:39 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Tie 2 fog lights on 1 side together and the other 2 on the other side then get yourself these listed below, wire them to the fog lights, 1 on each side, they plug into the stock fog light harness. Don't cut the stock wiring, save you issues later on.
    Check this out at Amazon.com HALOYiVGO H8/H9/H11/881/H27/880 Bulbs Male Connector Sockets Adapter For Headlights Fog Lights Retrofit Extension Wiring Harness ABS + Copper Wire 2pcs (H11) https://www.amazon.com/dp/B07HF6PMQX/ref=cm_sw_r_other_apa_i_a4qlDbMZ66RKF
  10. Jul 15, 2019 at 4:52 PM
    shakezoola
    shakezoola Not a new member
    Kansas City
    2019 Tundra TRD Sport MGM
    N-Fab MRDS Bfront Bumper w/ Rigid Industries Radiance PODS and Curved LED Light Bar TRD Skid plate Victory 4x4 Roof rack and hood mounts with Rigid industries Midnight PODS Alpine Halo9 ILX-F309TND Alpine PDR-V75 5-Channel amp powering 4x Image Dynamics component speakers Alpine S-A60M powering 1x 12" sub Fortin Remote Start with MyCar App Switch Pros SP-9100 Pop-and-Lock tailgate lock vLeds front turn signals w/switchback Center Console Safe Pedal Commander Diamond Back HD bed cover Swing Cases Driver/Passenger Katzkin Leather seats w/ heated front seats Bilstein B8 5100's Front and rear AMP Research PowerSteps Toyota TSS wheels w/ DuraTracs Toyota bed mat Bed light (LEDs) Blacked out badges Sport Antenna
  11. Jul 15, 2019 at 4:55 PM
    Berdine
    Binghamton, NY
    Crap! glad you caught that, posted wrong one going through my Amazon orders
    shakezoola[QUOTED] likes this.
  12. Jul 15, 2019 at 6:00 PM
    worktruckwhite
    Charleston, SC
    2010 White Crewmax
    Thank you guys. I’ll post the results.
    SnrDisregardo likes this.
  13. Jul 20, 2019 at 1:04 PM
    worktruckwhite
    Charleston, SC
    2010 White Crewmax
    Bought these but they don’t fit the harness on my truck. Any ideas?
  14. Jul 20, 2019 at 1:35 PM
    shakezoola
    Kansas City
    Hmm... I've used those on my fogs on my last 2 tundras. On some of the H11 plugs the locking tab might interfere and need to be removed.
  15. Jul 20, 2019 at 3:56 PM
    Berdine
    Binghamton, NY
    Use these then, you can tap your harness and unplug them if needed. Did it on my old jeep. Can get then at the auto store
    Check this out at Amazon.com Nilight 120 Pcs/60 Pairs Quick Splice Wire Terminals T-Tap Self-stripping with Nylon Fully Insulated Male Quick Disconnects Kit, 2 Years Warranty https://www.amazon.com/dp/B07CP987BN/ref=cm_sw_r_other_apa_i_xV5mDbDZEKTZB
  16. Jul 20, 2019 at 6:26 PM
    worktruckwhite
    Charleston, SC
    2010 White Crewmax
    Thanks guys
  17. Jul 28, 2019 at 4:06 PM
    Bigbird57
    Bigbird57 New Member
    They make adapters with 2 fog light connections.
  18. Aug 1, 2019 at 2:43 PM
    coopski
    coopski New Member
    Jay
    Morgan Hill, CA.
    2015 trd crew
    Question
    Can I just replace my stock fog light bulbs with LED’s?
  19. Nov 18, 2021 at 1:13 PM
    Fergie
    Fergie New Member
    Dredging this thread up in my search for an answer. Please bear w me in that I'm not very electrically inclined and have been trying to determine what type of connector I need to use to connect these ends w an adapter pigtail.
    These are the two female connector ends...finally got around to getting pics of them....C19 and my MH clinic have kept me crazy busy...
    This is the female connector on the ARB fog light side.
    Tundra fog light connector.
    Ideally, I'd like to have a pigtail adapter that goes betwixt the two without cutting...where can I find this?
    Thanks!
  20. Nov 18, 2021 at 4:47 PM
    worktruckwhite
    Charleston, SC
    2010 White Crewmax
    No worries on bumping. Might have better luck starting your own thread as well. Sorry I can’t help more
