Confused.
Discussion in '2nd Gen Tundras (2007-2013)' started by Blur'd Vision, May 13, 2023.
  1. May 13, 2023 at 9:18 PM
    Blur'd Vision
    Blur'd Vision [OP] New Member
    Dave
    2007 Tundra DCAB SR5
    I have an 07 Tundra 145,000 miles on the 5.7 2wd. This problem has happened 3 times in 2 years of ownership. Jump in, start the truck, let it get fluids moving around before I drop it in D. I head up the road about 3-4 miles and stop at a store. Shut the engine off and go into the store for maybe 5-10 minutes. (80+ degrees out) when I try to start the truck it turns over and starts but immediately stalls. I do the same thing again and same happens. IF I push the gas pedal it stalls out instantly too. It maybe runs for a couple seconds. This happens about 6-8 tries, then it starts and runs fine. Scares me to take it on a long trip. Any thoughts out there?
  2. May 14, 2023 at 12:37 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I would start at the battery terminals. If they're loose or corroded they will do some weird stuff.... Maybe look into replacing the Alt fuse and relay. My Tundra has never behaved that way, only when the battery was pretty much dead, it would leave me stranded usually in the middle of nowhere, but my Celica does similar things, but usually dies completely... I usually have to steal my own car by jumping the starter relay with the key in the ignition for it to start.
  3. May 14, 2023 at 2:49 AM
    Do you top off tank when filling up? Evap system could be saturated.
    KNABORES likes this.
  4. May 14, 2023 at 5:33 AM
    Schmidt_l
    Schmidt_l New Member
    Leidir (Lay-Jeer)
    2008 Tundra Sr5 DC
    Grille??
    It happened to me once just after a mechanic scan the truck
    he said its something to do with anti-theft system reseting
    it sounded weird at first.,
    but locking and unlocking the truck with the remote cleared the code as he had the scan on the truck
  5. May 14, 2023 at 7:46 AM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Ditto on the batt terminals...the factory ones are cheap IMHO...I replaced my + terminal with a real traditional terminal with a raised/threaded connection stud for the hot wires.
  6. May 14, 2023 at 8:10 AM
    Blur'd Vision
    Dave
    I find it difficult to believe it's anything with the battery. It cranks over fine every time. Just my opinion after 50 years of driving and owning 150+ vehicles. But then again these newer cars with computers leaves me ??????? at times. I don't drive the truck much and when it sits it is battery tendered. I will keep looking but it's hard to diagnose a glitch that happened 3 times in 2 years. Thanks all.
  7. May 14, 2023 at 9:34 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Happens to me every 6 months or so. I keep my valet key with me, the brown one, so when it does happen i switch to the brown key and it always starts right up. Next trip I switch back to the black key and it's all good for a while.
    Seems to me leaving the black key in the ignition for a period of time after I've shut the truck off triggers it. I also have an anti-theft code active and have for a long time.
  8. May 14, 2023 at 2:49 PM
    Blur'd Vision
    Dave
    AH HA! Now that makes sense as I did leave the key in the ignition while in the store at least twice as my wife stayed in the truck. Cool, THANK YOU!!
    Schmidt_l likes this.
  9. May 14, 2023 at 3:38 PM
    Schmidt_l
    Leidir (Lay-Jeer)
    2008 Tundra Sr5 DC
    Grille??
    yep, that’s probably it
    it triggered the anti-theft system
  10. May 14, 2023 at 5:24 PM
    Giskk
    Giskk New Member
    Mississippi
    2021 Cement Tundra TSS Off-road
    Does your key have a battery? May need replaced? I’ve heard of codes when the key battery is low.
  11. May 15, 2023 at 5:01 PM
    tmac58star
    Reset the system.
