Conflicting info on rear diff oil weight
Discussion in '1st Gen Tundras (2000-2006)' started by dwarmbrodt, Jan 12, 2017.
  1. Jan 12, 2017 at 4:27 PM
    dwarmbrodt
    dwarmbrodt [OP] New Member
    03 Tundra SR5
    Hello all,
    I am doing the rear diff cover upgrade and when attempting to purchase new oil I had every parts shop counter guy say I need syn 75-90 weight but I found the owners manual and it says syn 75-140 weight for standard differential. My instinct is to follow the manual, but why the difference of opinion? Did something happen since 2003 to make 75-90 a better choice?
    Thanks in advance!
  2. Jan 12, 2017 at 6:08 PM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    My manual says 75W85.
  3. Jan 13, 2017 at 9:36 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    My 2wd 2001, both the owners and Clymer repair manual agree, gl-5 90w for 0 degrees F and above, 80-90w gl-5 for temps under 0 degrees F. Be sure you are looking at the correct specs in the manual. If you are I would run it by a toyota service guy. I always follow the manual, but would want to see why the discrepancy. My info is for non limited slip diff. Good luck.
