Concrete cleaning
Discussion in 'Home Improvement' started by Moon Puppy, Jul 13, 2019.
  1. Jul 13, 2019 at 3:15 PM
    Moon Puppy
    Moon Puppy [OP] I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    jewsNbrews likes this.
  2. Jul 13, 2019 at 6:05 PM
    Ps3udonymous
    Ps3udonymous Who is the smart ass that changed the title?
    Those rotory things work better than the broom one. If your stuff is super dirty, finer nozzle, like 10 degree or 15 degree will clean deeper.
    If you aren't afraid of chemicals, masonry cleaner is excellent at cleaning concrete, it's a lower percentage of muriatic acid. This will get almost any stain out of concrete with minimal work. It will also clean the snot out of grout in tile. Just make sure to sprinkle baking soda on after words to neutralize the acid and rinse well.
    Moon Puppy[OP] and Pudge like this.
  3. Jul 13, 2019 at 6:17 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I used the rotating circular one with decent success on some pretty badly soiled concrete, though it was painted. Definitely get a good detergent to help loosen up the gunk before washing :thumbsup:
    Moon Puppy[OP] likes this.
  4. Jul 13, 2019 at 6:36 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    The rotating disc ones work pretty well. I used it on my deck and it made short work of it. I think I'll be doing my garage this fall with it. The skirt around the disc really keeps the mess down too
    Edit. I second the idea for muriatic acid. Works great and will surprise you on how well it lifts stains.
  5. Jul 13, 2019 at 7:08 PM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    Thanks guys, heading to home depot tomorrow.
  6. Jul 13, 2019 at 7:49 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Make sure you clear any loose debris. They love throwing rocks and other things, especially if you pump 10,000psi through them.
  7. Jul 13, 2019 at 7:52 PM
    Squatting Pigeon
    Holden
    North Texas
    If you do use an acid, especially one as strong as muriatic, just be careful. Its rough stuff and will affect anything metal or natural stone pretty aggressively.
  8. Jul 13, 2019 at 8:34 PM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    I doubt i'll use acid, just good ol' water pressure. I'm not going for pristine, just get the old mildew.
    Squatting Pigeon likes this.
  9. Jul 13, 2019 at 8:43 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I have a 20” North Star rotary and a 4K pressure washer, I could never go back to just the wand. I was washing our rent house before we moved out C9D8C8DE-2C71-40BA-8AFF-79F5F65876CA.jpg
  10. Jul 13, 2019 at 8:48 PM
    Waterboy45661
    Waterboy45661 New Member
    Tommy
    07 Red SR5
    Just did mine, had one of the rotary disk’s but it quit spinning after the second day.DCEF07B5-7BA1-43CC-8879-223EF9D67FB9.jpg
  11. Jul 14, 2019 at 1:13 PM
    Ps3udonymous
    You must have one hell of a surface cleaner lol, the ones I've seen go up to like 6k psi
  12. Jul 14, 2019 at 1:21 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    Was dong commercial properties with a 10,000 psi steam unit and 36" surface cleaner.
  13. Jul 14, 2019 at 1:23 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I have installed several Iron oxidation reduction systems on well water sourced irrigation systems, because the homeowners were sick of the iron staining their drive and walkways. This one has a 13 x 54 tank, there is also a 10 x 54 version.
  14. Jul 14, 2019 at 2:33 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Damn that’s a hell of a driveway!
  15. Jul 14, 2019 at 3:07 PM
    Ps3udonymous
    Oh old mildew? Grab some bleach. It'll help if the water pressure alone doesn't get it
  16. Jul 14, 2019 at 5:02 PM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    New on old. I about busted my but going out to the garage the other evening, time to get'er done.
  17. Jul 14, 2019 at 5:27 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If I knew I had to clean all that I would quit too
    :eek:
    Waterboy45661[QUOTED] and Pudge like this.
  18. Jul 14, 2019 at 6:19 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I had one that quit after a week. It had a shielded bearing in it instead of a sealed one. Bought a new $15 SKF bearing and it's been running since.
    Waterboy45661[QUOTED] likes this.
  19. Jul 14, 2019 at 7:45 PM
    Waterboy45661
    Tommy
    07 Red SR5
    Yes it is, took me about 4 days to get it done.
  20. Jul 14, 2019 at 7:59 PM
    Waterboy45661
    Tommy
    07 Red SR5
    I took it back and got another one of course when I was almost done.
