Concern about 4WD
Discussion in '3rd Gen Tundras (2022+)' started by Vermilion, Nov 18, 2022.
  1. Nov 18, 2022 at 3:31 AM
    Vermilion
    Vermilion [OP] New Member
    I admit I am spoiled since all my recent vehicles have had AWD. We just got snow here in northern Minnesota so I have been using my 1794 4WD. Even on slippery surfaces and with very modest turning the vehicle jerks like the wheels aren't fully engaged. Not at all smooth like my other AWD vehicles have been. I engage 4WD when stopped, the flashing signal goes to solid 4WD. Am I supposed to be doing something in addition? It is a very pronounced jerking. If driving straight ahead it does not do that
  2. Nov 18, 2022 at 3:52 AM
    timsp8
    NY
    It jerks because it’s binding. You had too much traction on the surface you were on. It was working correctly. It can break a CV axle. Read up on the differences between 4WD and AWD.
    JLS in WA, =JSG= and NewImprovedRon like this.
  3. Nov 18, 2022 at 3:55 AM
    Vermilion
    I know that could be the problem however when this happens i am on very slippery compacted snow and the turn is not very much. really the surface is very slippery even to the point that walking has to be done carefully.
  4. Nov 18, 2022 at 3:58 AM
    timsp8
    NY
    If the 4WD light was solid, it should be working. That sounds like normal symptoms of turning in a 4WD with it engaged.
  5. Nov 18, 2022 at 4:11 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Amazed on how many recent '22 threads I've seen about this. 4x4, is not AWD, and is working how it should. Have a great day :thumbsup:
  6. Nov 18, 2022 at 4:44 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Could be more helpful (if 4WD is overkill) to put a couple hundred pounds in the bed over the rear wheels. The added weight will assist with 'grabbing' the road.
    FLTon and Maharisc like this.
  7. Nov 18, 2022 at 7:53 AM
    osu1978
    osu1978 New Member
    Tire technology has increased so much over the past 10-15 years it seems to be making 4wd only necessary for really tough spots.
    TheBeast likes this.
  8. Nov 18, 2022 at 8:07 AM
    Toyotaloop
    Toyotaloop New Member
    Pittsburgh
    2021 SR5 Crewmax MGM
    Very little so far
    Is this a 3rd gen issue? I keep seeing posts about binding in 4wd. Either the 3rd gen has a very 'sensitive' drivetrain (?) Or there are a lot of new 4x4 owners who aren't used to 4x4s and don't know the different feels of light binding and full-on lock to lock turns on dry pavement?
  9. Nov 18, 2022 at 8:47 AM
    DFS
    DFS New Member
    2022 Capstone Tundra
    I'm going to guess it's primarily people who think AWD or 4A are interchangeable with 4H and don't understand how it works, or when 4H is actually needed.
  10. Nov 18, 2022 at 8:52 AM
    AZBoatHauler
    So.Arizona
    But there was snow on the ground…
  11. Nov 18, 2022 at 8:57 AM
    Toyotaloop
    Pittsburgh
    Very little so far
    Perhaps. Not trying to stir the pot or ridicule anyone. Genuinely interested. There are quite a few opinions posted about toyota adding AWD to Tundra over 4wd, which I can't wrap my head around when talking about trucks.
  12. Nov 18, 2022 at 9:02 AM
    mmasse
    mmasse Digital Forensics Cowboy
    Idaho
    2022 Magnetic Grey Tundra
  13. Nov 18, 2022 at 9:03 AM
    DFS
    DFS New Member
    I'm not either, I'm being purely objective. Almost every case of it being reported on here (not all), the user was engaging 4H on dry cement or other close to zero slip environments.
    I would be adamantly against "replacing" 4H with AWD on trucks, but Ford (and possibly GM) have the correct answer which is 4H and 4Auto. I always use 4A on my Raptor when in wet or slippery conditions without any binding concerns and almost instant traction when slipping, and can opt for 4H or 4L in more severe environments with the torsen front diff working wonders as well (not like an actual locker, but better than nothing). It's amazing Toyota didn't implement it with this update to me..
    22whatwedo, Jongie123 and TheBeast like this.
  14. Nov 18, 2022 at 3:28 PM
    mass-hole
    mass-hole New Member
    Nobody is condoning replacing 4wd with awd. What people want is both, which is completely possible. Look up the full-time 4wd transfer case that has been in the 4Runner, Lexus GX, 1st and 2nd Gen Sequoia, Land Cruiser, etc for a solid 20 years. You get 2wd, unlocked 4hi, locked 4Hi, unlocked 4lo, and locked 4Lo in one transfer case. When its unlocked(Full-time 4wd) it utilized a torsen limited slip center differential to send the power to the axle with the most traction.
    I almost never engage locked 4hi or 4lo in my GX. It doesnt need it. The torsen differential is good enough for 99% of situations that anyone would ever encounter in normal driving to not need it locked. I've even lifted tires off the ground and still pulled through the obstacle without locking it.
    Oh and the other awesome benefit is unlocked 4Lo. Its awesome for moving trailers around when you're on pavement. You get the benefit of the gear reduction from 4Lo without the binding. I use it to park my trailer in my side yard all the time without ripping up my lawn or binding on the street while manuvering.
    Black Wolf and SC4333 like this.
  15. Nov 18, 2022 at 5:30 PM
    xc_tc
    xc_tc New Member
    Even AWD vehicles like Audi will bind up when the steering wheel is cranked all the way left or right. It all depends on the system. Audi uses torsen center diffs which can act to lock the front and rear prop shafts. And that’s exactly what’s happening in your Tundra, the front and rear prop shafts are locked together because there is no center differential.
  16. Nov 18, 2022 at 6:46 PM
    =JSG=
    =JSG= New Member
    2006, 2017, 2021 Tacoma. Soon 2022 Tundra :)
    You don't need 4wd unless u have ice or couple inches of snow on a paved road. What you are thinking of is AWD systems (Subaru) where you have an automatic transfer case and a computer decides which tires need traction.
  17. Nov 19, 2022 at 4:30 AM
    FLTon
    FLTon New Member
    2022 CM TRD Sport
    So I’m the only one who turns traction control off and plays the soundtrack to “FF: Tokyo Drift”?
    AZBoatHauler likes this.
  18. Nov 19, 2022 at 4:33 AM
    2020cementsr5
    2020cementsr5 New Member
    It sounds like you’re taking to tight of turns. If there’s some compact snow and you want 4WD engaged, take less tight turns
