Complete Fuel System Cleaner?
Discussion in '2.5 Gen Builds (2014-2021)' started by Aggie2002, Nov 3, 2019.
  1. Nov 3, 2019 at 9:59 PM
    Aggie2002
    Aggie2002 [OP] New Member
    Arlington, VA
    2017 Tundra Limited TRD Offroad
    Fellow Tundra Owners:
    I am in the process of finding a complete fuel system cleaner. The local Toyota dealership where I get my oil changes recommends 44K. Does anyone have any good feedback on this cleaner? Since a can treats 20 gal., I assume I should use almost 2 cans in a 38 gal tank.
    What do you all recommend? Is there a thread on complete fuel system cleaners? Thanks for the help.
  2. Nov 4, 2019 at 4:08 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    IMO, that service is just free money for the dealer aka snake oil. Just run a good quality fuel from a reputable gas station. Don't go searching for a problem when there isn't one.
    Patriot, Black Wolf, Rica25 and 2 others like this.
  3. Nov 4, 2019 at 4:52 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Many threads. Sea Foam (Seafoam) or Berryman's B12. Or just use Top Tier fuel.
    Black Wolf, Rica25 and GODZILLA like this.
  4. Nov 4, 2019 at 5:01 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Occasional treatment of Techron works...or just use Chevron gasoline which costs a few cents more per gallon.
    Medic343 and Rica25 like this.
  5. Nov 4, 2019 at 5:31 AM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    On my 2015 Tundra I ran 1 can of BG 44k through the tank at around 30k just for preventative maintenance. That truck had the smaller tank so just used 1 and filled it up. I can only assume it worked well as I didn’t have the truck much long after I did the 44k. Not sure on 2 whole cans, might see if you can call BG directly and ask. Only advice I think
    Is to run it a few hundred miles before an oil change.
  6. Nov 9, 2019 at 5:35 AM
    Badger Co-Op
    Badger Co-Op Blood sausage, cheese, and lutefisk; hit me!
    Kenny
    WISCO
    +1
    Go to [real gas dot org] and find a station that sells ethanol-free fuel. It may take a while to find one in your area, but worth it. Next, avoid fill ups on Th/Friday. Those are the day that tankers most likely make their deposits and you are likely to get the water/crap stirred up from the bottoms. IMHO, it's kind of what sucks with the whole "flex-fuel" marketing; there's a higher likelihood for there to be water in it.
    Black Wolf and Rica25 like this.
  7. Nov 9, 2019 at 6:06 AM
    Rica25
    Ricardo
    Tulare
    I've seen some you tube videos that say that shell 91 or 93 octane have 7 to 10 times more additives to clean than 87 or 89 octane so on my truck since 2008 I have always used shell 89 and once a month I fuel up with 93 or 91 to clean it and so far no problems. I also used BG additive every oil change for the oil and also the fuel tank
    Kerch71 likes this.
  8. Nov 9, 2019 at 6:34 AM
    Can't go wrong with Shell or ethanol free from Maverick. Beware of snake oil remedies offered at most tune up shops.
    Rica25 likes this.
  9. Nov 9, 2019 at 7:13 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    +1 for berrymans b12 chemtool
    Rica25 likes this.
  10. Nov 9, 2019 at 7:49 AM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    I've never had any issues with my vehicles and I exclusively use Chevron fuel in my Tundra. Even while traveling I will go out of my way to find a Chevron station. In my wife's vehicle, she doesn't care where she puts fuel, I add a bottle of Chevron w/Techron complete fuel system cleaner to it every 5k miles. I'm by no means a pro but you asked for my $0.02
  11. Nov 9, 2019 at 12:03 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Another vote for Shell 93 octane. I will occasionally add a fuel injector cleaner and also had complete fuel system flush at around 25K miles just for the hell of it.
  12. Nov 9, 2019 at 1:34 PM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    nope....never, owned Toyota’s since 89.
