Complete CoLight Mini upgrade
Discussion in '1st Gen Tundras (2000-2006)' started by VR6T, Feb 14, 2024.
  1. Feb 14, 2024 at 4:44 PM
    VR6T
    VR6T [OP] In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    If you're looking at updating your night time visual presence and ability to see I did this Tuesday, 02/13/24. Below you will find the link, 2 videos and my first hand pictures of the mod process.
    CO LIGHT Anti-glare 9003/H4 LED... https://www.amazon.com/dp/B0CN72DSBT?ref=ppx_pop_mob_ap_share
    https://youtu.be/vDi-fIp0jkw?si=spFaTUyeliPW7MkY
    https://youtu.be/5QAYWycrOyU?si=RvJ7SSnP50Ua6bsz
    Step 1 tear out you brand new refractor housing from your headlight, should look like this.
    Step 2, remount spring and break your latching lug (optional, not reccomended)
    Step 2a. (Optional) Using a hole saw drill bit and a step bit, cut you out big circle of plastic, step out the center hole to 3/4". Cut in half, drill pilot holes with small drill bit. Install the now "better" retention lock. (Also not reccomended if you dont finger fuck your housings up.)
    Step 3 Install blub into housing secure in place
    Step 4 Install vented rubber housing cover
    Step 5 Thread back on the heat sink over the rubber boot. Optional, trim rubber boot to fit over heat sink for easier access in the future. Not mandatory.
    Step 6 reconnect/ pin together voltage/ relay box
    Step 7 Thread on pin connector/ weather nut to seal the power connection.
    Step 8 Install and enjoy. I mean blind everyone, I mean calibrate
    Well I am a fan. And not such a bad job on the sketchy day time alignment.
    Building is about 100 110 feet away from me.
    Lows
    Highs
  2. Feb 14, 2024 at 4:47 PM
    That looks pretty good man, which lights did you use?
  3. Feb 14, 2024 at 4:49 PM
    VR6T
  4. Feb 14, 2024 at 5:12 PM
    Nicklovin
    Nicklovin Yap Yap
    Nick
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    Damn that looks pretty good for $70
    FrenchToasty and VR6T[OP] like this.
  5. Feb 14, 2024 at 5:14 PM
    VR6T
    I got welders eyes, and I can see like 150 200 feet down the road now. Vast vast vast improvement
    Nicklovin[QUOTED] and KNABORES like this.
  6. Feb 14, 2024 at 7:25 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I think he used colights. :D
  7. Feb 14, 2024 at 7:29 PM
    VR6T
  8. Feb 14, 2024 at 8:14 PM
  9. Feb 14, 2024 at 9:18 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Are those colights?
    455h0le_dachshund likes this.
  10. Feb 15, 2024 at 1:56 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Now we know the brand, How did you mount them in the housings???
    :frusty::duh:
  11. Feb 15, 2024 at 2:54 AM
    artsr2002
    'Yonder
    Duct tape and bubble gum. Duct tape keeps them in there. Bubble gum gives them a cushion so vibrations don't jar the light output. :rofl:
  12. Feb 15, 2024 at 8:33 AM
    VR6T
    This
