Compatible rear axle assemblies for 2WD double cab?
Discussion in '1st Gen Tundras (2000-2006)' started by carpartcountry, Apr 26, 2020.
  1. Apr 26, 2020 at 2:58 PM
    carpartcountry
    carpartcountry [OP] New Member
    2005 Toyota Tundra TRD
    3 inch life, tinted windows,
    My rear end is toast. I have a 2005 double cab 2WD. I found a local double cab 4wd rear axle assembly. Would that work? My mechanic knows how to make things work but I don’t want to get it if it won’t work. Please let me know if you guys have any advice. Thank you!
  2. Apr 26, 2020 at 4:04 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    The whole rear end assembly is toast or just the 3rd member (center section)?
  3. Apr 26, 2020 at 4:06 PM
    carpartcountry
    From what he told me it’s the actual housing that’s bad.
  4. Apr 26, 2020 at 4:18 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Ok, the axle off the 4wd should bolt right up if the yoke and companion flange look the same. Does the donor assembly come complete with center section? Pictures of the used assembly would help.
  5. Apr 26, 2020 at 4:22 PM
    carpartcountry
    Sadly enough I don’t have pictures. It’s an online price I found one state over. $500 compared to $850 for a complete assembly. I’ll see if the guy will take pictures for me.
  6. Apr 26, 2020 at 4:41 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  7. Apr 26, 2020 at 4:56 PM
    carpartcountry
    The whole housing. I guess it will always leak because the spot where the wheel bearing is has play and will always leak.
  8. Apr 27, 2020 at 3:31 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I don't know about the compatability between the two axles, but something doesn't add up in what your mechanic is telling you. The bearing housing that the bearing mounts into isn't even part of the axle housing. It's secured by 4 bolts to the end of the axle housing.
    If there was play in that -- which I don't see how there could be -- you'd replace just the bearing housing. #6 in this diagram. Link to part at Toyota of Cool Springs.
    I presume your axle is leaking gear oil? If so, first make sure the vent isn't plugged. If it's not, then you need to replace the bearing and the seal. That will require a press and a special tool... plus some attention to detail about how it comes apart and is pressed back together.
