Color Matched Bumper Swap
Discussion in '2.5 Gen Tundras (2014-2021)' started by veg hed, Oct 7, 2016.
  1. Oct 7, 2016 at 11:44 AM
    veg hed
    veg hed [OP] Thug
    Utah
    2016 Ta-Tundra Barcelona Red
    I didn't find a lot of info on this when I was researching this so I'll post some pics...
    By far the hardest part of the swap is getting the black plastic piece between the bumpers off. I found it was easier when I laid underneath the truck pushing the tabs with a long screwdriver while someone pulled from the top. I removed the whole piece, which included unhooking the license plate lights and trailer hookup.
    These are the tabs that you have to push up on from the bottom. There are also 2 below the license plate that are hard to get to. And one behind the license plate that is a circular pull tab kind that is accessed by removing the license plate. Don't forget this one.
    After you remove the plastic piece start removing the 12mm bolts. There is one on the bottom of each side that has a nut on the back of it and is a little difficult to get to.
    You reuse all of the bolts and the bracket behind the chrome bumper ends. I just posted this as an example of where it goes. I found it was easier to install in one piece with the new black bumper piece.
    After a little finagling I figured out it was easier to install the bracket in the new black bumper piece held on with one bolt.
    It was an afterthought but definitely a good idea to tape up the tailgate and where the bumper might make contact with the paint. Especially when removing the plastic piece in the middle. Line up the black piece with the bracket installed and start reinstalling the bolts.
    The new color matched end caps from @Roman went on easily and everything I needed was there.
    These clips are self explanatory once you start putting it all together. 3 tabs on each side.
    Line up the tabs on the black piece and push down. They should all snap into place.
    Hookup the trailer wiring harness and the license plate lights.
    And done....
    I also used this pic as a reference:
  2. Oct 7, 2016 at 12:33 PM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    @Tundracm16 ok here is a step by step on removing and replacing our bumpers
  3. Oct 7, 2016 at 12:57 PM
    TheBeast The Beach
    looks good
  4. Oct 7, 2016 at 1:53 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Awesome write up! This should help clear up any questions about installation, and why the extra hardware is needed.
    Carlos, Krezz, T-Rex266 and 1 other person like this.
  5. Oct 7, 2016 at 1:55 PM
    geek755
    geek755 New Member
    2016 Blazing Blue Tundra SR5 CM (XP Package)
    Looks a lot better. I hate the chrome on my 16CM.
    Am I right in my understanding, you have to get new brackets and the end caps (covers) for the front and rear?
    Can I ask what the whole thing ran you? Close to $1K?
    Ike74 likes this.
  6. Oct 7, 2016 at 2:23 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Very nice write up!! Thks I'll be doing that soon
  7. Oct 7, 2016 at 2:57 PM
    veg hed
    veg hed [OP] Thug
    Utah
    Not quite that much. Closer to $600 to $700 if I remember. I ordered a few things all at once. @Roman made it easy by including all the parts I needed with no research on my end. Plus he will get them paint matched for you.
    Roman and geek755[QUOTED] like this.
  8. Oct 10, 2016 at 6:32 AM
    Roman
    Roman
    Franklin, TN
    geek755 and veg hed[OP] like this.
  9. Oct 10, 2016 at 7:03 AM
    geek755
    geek755 New Member
    Thanks for the link @Roman. This confirms my thought...for front and back, with stays and paint, it's > $1000. I'll have to just paint the chrome as i can't justify that expense. Thanks!
    Ike74 and Roman like this.
  10. Oct 10, 2016 at 7:04 AM
    veg hed
    veg hed [OP] Thug
    Utah
    Oh, I thought you were talking about just the back. Yeah, that's more like it for the front and back.
  11. Nov 22, 2016 at 1:31 PM
    jwm9289
    jwm9289 New Member
    Great write up, i did my inferno orange a few weeks ago. Pics were a HUGE help.
    Thanks,
    Roman and veg hed[OP] like this.
  12. May 14, 2017 at 3:00 PM
    djohn8002
    djohn8002 New Member
    2014 Tundra SR5
    So I will definitely have to remove the middle part in order to change the end caps?
  13. May 15, 2017 at 6:22 PM
    veg hed
    veg hed [OP] Thug
    Utah
    From my experience, yes. Unless you want to remove the bumper? I really don't know since I didn't go this route. The middle piece took a little figuring out but once it was off it allowed for better access to the bolts necessary to remove the bracket.
  14. May 15, 2017 at 6:24 PM
    djohn8002
    2014 Tundra SR5
    Ok, thank you. Great post.
    veg hed[OP] likes this.
  15. May 16, 2017 at 3:11 AM
    khunk
    khunk Tundra Fan
    Marty
    Leland, NC
    2017 CM Limited 4x4
    And there it is Folks.........another way to use the worthless "Uncle Sam" issued wool blanket! :rofl:
    Black Wolf and CaptObvious like this.
  16. May 29, 2018 at 1:46 PM
    Maverick510
    Maverick510 New Member
    Mark
    Thanks for the write up!
    Question and maybe this is for a new thread, can you install new end caps with sensors if your originals didn't have them, are they pre-wired?
  17. Jun 7, 2018 at 6:29 PM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    i must say... its easier to remove the entire bumper than to try and work around it. i had on plastic stud holder break from the center piece(i epoxied it back on). had i not had the bumper off many more would have broken. go on youtube and search tundra bumper and watch the guy at rhino remove it.
    do not do this project when its cold! you will damage a lot of plastic parts as they are brittle.
    NewImprovedRon likes this.
  18. Feb 4, 2019 at 7:32 PM
    Jsnake89
    Jsnake89 New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    This is amazing and really shows me how much is involved. I really want to get rid of the the chrome plus it is clashing with my TRD Pro new color macteh grill.
  19. Feb 16, 2019 at 12:12 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I’m just popping in here to say fine work.
    Also...Those plastic tabs holding down the plastic on top if that bumper are a disaster.
  20. May 4, 2020 at 10:28 AM
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    Reviving an old thread. Thanks for this step by step write up. Very helpful. Are you aware of a similar write up for the front bumper end cap swap. Having my chrome ones powdercoated. Thanks in advance.
  21. Oct 1, 2021 at 1:27 PM
    Tundra_King1
    Tundra_King1 New Member
    Ryan
    2018 Tundra 4x4 5.7L Crewmax
    2.5" Level with Bilstein 5100s, 275/70R18 Nitto Ridge Grapplers, and JBA UCAs.
    Great thread! For those of you who wanted painted front and rear bumper caps paintedoemparts.com paints them OEM paint to match and sends them to you. Around $1k for both sets of end caps painted.
  22. Nov 2, 2021 at 7:43 PM
    pappaboz
    pappaboz New Member
    Hello. New to this forum. Looking to black out my 2019 Tundra. Great thread! Your install process and pics are very helpful. Can you confirm if the existing bumper brackets used with chrome caps (part# 20) are used to mount part# 9 for abs caps? Thanks.
  23. Apr 17, 2024 at 3:39 PM
    Alphapig806
    Alphapig806 New Member
    Joe
    2020 tundra quicksand
    Did you have to use the #11 mount on the diagram?
