Color match tailgate handle
Discussion in '2.5 Gen Builds (2014-2021)' started by King Slayer, Apr 29, 2016.
  1. Apr 29, 2016 at 3:57 PM
    King Slayer
    King Slayer [OP] New Member
    Northwest
    2016 TRD Tundra
    Custom powder coated gun metal TRD wheels, Michelin Defender 265x70's (better road & tow tires), Bilstein 5100 shocks with front adjusters, rear anti-sway bar, TRD Pro color match grille, TRD Pro (blacked out) headlights, color match tailgate handle, VLED replacement bulbs all around, Leer 100 XQ canopy, Katzkin leather.
    I priced out color matching my tailgate handle since Toyota doesn't make one and at over $300 I decided to do it myself since I have spray equipment (but you could do it with a disposable preval setup (http://preval.com/pro-solutions/pro-automotive/automotive-in-the-field/).
    Supplies:
    220 grit sandpaper
    "Bullfrog" adhesion promoter for plastic
    2 part epoxy primer
    Color matching paint (local automotive paint store with your paint code inside the door panel)
    2 part clear coat
    Before/after
    I taped off the backup camera lens and sprayed the body so it didn't look like a hack job. I sprayed up inside the back of the handle and main latch body passages so I didn't get dark reflective shadows.
    Finished piece
    Going for a clean look with all the badges stripped off and now a color match tailgate handle.
    What do you think?
    69daec5c-7956-4570-9642-4edc73961efe_zps_22b0a2cac05d5243e6ab1b9cac7bf55c0bf12e45.jpg
  2. Apr 29, 2016 at 4:17 PM
    Nicely done, and you should probably do a write-up on it. Personally, I still prefer to keep a little black color on the tail-gate handle.
  3. Apr 29, 2016 at 4:26 PM
    King Slayer
    Northwest
    2016 TRD Tundra
    Perfect... I can tell the difference between your truck and mine in a parking lot. LOL
    ATV25 and T-Rex266[QUOTED] like this.
  4. Apr 29, 2016 at 7:20 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Nicely done!
    ATV25 likes this.
  5. Apr 30, 2016 at 1:31 PM
    King Slayer
    Northwest
    2016 TRD Tundra
    DIY'ers:
    #1 rule: Your finish will only be as good as your prep...
    220 sand, acetone wipe
    Bullfrog: 2 coats, 5 minutes between 1st & 2nd coat, 10 minutes between 2nd coat & 2 part primer
    2 Part epoxy primer: 2 wet coats minimum, 4 hours between coats, re-sand after 24 hours
    Color match: 2-3 wet coats (4-24 hours after epoxy primer otherwise re-sand) 15 minutes between color coats
    2 part UV protective clear: 1-2 wet coats, 30 minutes after color coat, 4-24 hours between coats, 24-48 hour full cure before re-install
    NOTE: DO NOT TOUCH PAINT BETWEEN COATS! This is a wet on wet process, You will put a finger print in the paint and will need to wait 24 hours to lightly sand and start over.
    If it looks good, it is!
    If you have your act together you could get it done over the weekend by doing your prep and 1st coat of paint Friday.
    tlakeTundra likes this.
  6. Apr 30, 2016 at 2:30 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    where did the embossed Toyota on the handle go?
    AggiePhil likes this.
  7. Apr 30, 2016 at 3:39 PM
    dandailey
    Dan D
    Newport News Va.
    If its gone ,that's a fail IMHO..
    SmokinGunner likes this.
  8. Apr 30, 2016 at 4:19 PM
    King Slayer
    Northwest
    2016 TRD Tundra
    Grinding dust... LOL
    In an effort to personalize a "clean" looking truck, all branding has been removed (badges, TRD sticker, and all things "Leer"). My TRD Pro grille still has the "TOYOTA" but I've ordered a royal core grille insert so that will be going away soon too. Still have "TUNDRA" on the tailgate, not an easy removal. The wheels have "TRD" caps. Don't get me wrong... 4th Toyota and love this Tundra! Call me an extremist... It's all part of being cursed with a type "A" personality. LOL
    JORDANTACO and Tundra Fan like this.
  9. May 6, 2016 at 7:18 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Very nicely done. Added link here
  10. Aug 18, 2017 at 9:35 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Props man, it turned out great. I want to do mine eventually as well, color matched looks tons better. Fortunately I don't have to worry about removing the toyota lettering.
    Now that yours is over a year old, how is it holding up?
  11. Jul 31, 2020 at 3:27 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    A body shop quoted you $300 just to paint that??
  12. Jul 31, 2020 at 4:41 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    I like it.Thought about doing that to mine . Maybe 1 day
  13. Nov 5, 2022 at 11:04 AM
    JORDANTACO
    JORDANTACO New Member
    JORDAN
    Would you be willing to do mine for me?? ill pay you of course. Need it done in super white
  14. Nov 5, 2022 at 1:10 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    you are responding to a thread from 2016. The person that started this tread has not logged into tundras since 2016 either
  15. Nov 6, 2022 at 1:18 PM
    JORDANTACO
    JORDAN
    yeah you're right... still not much out there on the net for changing the tail gate handle. :(
