Cold throttle issue
Discussion in '2nd Gen Tundras (2007-2013)' started by MonteSTL, Feb 9, 2021.
  1. Feb 9, 2021 at 8:31 PM
    MonteSTL
    MonteSTL [OP] New Member
    Monte
    2007 Tundra SR5 black
    stock
    Evening all, I’ve done several searches for this issue but all I’m getting is info on “all the time throttle response “. I’m very happy with the throttle except when it’s cold or been sitting for a week. I used jump in start it up and let it run for awhile, but now I’ve installed remote starter thinking letting it warm up for 5 mins and yet it still acts like a bronco bucking. It takes a good 20-30 min drive before it fully warms up and stops the jerking??? Back in the day I would say the choke was sticking, but we know that’s not the issue.. bad- coolant sensor or mass air sensor?
    Thanks Monte
    2007 - 5.7 engine
  2. Feb 17, 2021 at 10:24 AM
    MonteSTL
    Monte
    stock
    Bueller......Bueller?? HELP!..lol
  3. Feb 17, 2021 at 10:27 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Any codes thrown ? Is it only in cold weather or any temperature ?
  4. Feb 17, 2021 at 11:21 AM
    sethcphoto
    sethcphoto First Gen Freak
    Seth
    Seattle, WA
    2005 Tundra AC
    Try cleaning the throttle plate, make sure your resistances are good. Aftermarket remote starters can cause some weird things to go on in the computer
  5. Feb 17, 2021 at 11:28 AM
    MonteSTL
    Monte
    stock
    No codes showing and when temps are below 50°. It was happening before the remote starter was put on. It’s just saved me from going out to the truck warming it up. Thanks for getting back to me gents!
  6. Feb 17, 2021 at 11:32 AM
    sethcphoto
    Seth
    Seattle, WA
    2005 Tundra AC
    I'd start with cleaning your throttle plate, get some sort of cleaner and a tooth brush. Don't go to crazy with the cleaner cause that carbon filled liquid can get into the throttle motor and lock it up.
    MonteSTL[OP] likes this.
  7. Mar 9, 2021 at 10:26 AM
    MonteSTL
    Monte
    stock
    removed and cleaned throttle plate and Mass air sensor and seems to mostly fixed the issue. thanks all
