Cold Tail Gate Won’t Latch.
Discussion in 'General Tundra Discussion' started by alpinepro4, Nov 19, 2018.
  1. Nov 19, 2018 at 8:56 AM
    alpinepro4
    alpinepro4 [OP] What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Using my tail gate this morning I noticed it won’t latch. It was 5 degrees. Any one have this problem. What did you do to fix it?
  2. Nov 19, 2018 at 9:05 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Probably needs lubricated, even a little crud can hold water and make them stick in the cold weather. Spray them with some WD40 and see if it gets better then follow up with some white lithium grease.
    15whtrd likes this.
  3. Nov 19, 2018 at 9:26 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Lube it up like Fester said. I’ve had that happen on other vehicles before. Nothing a little shot of grease won’t fix.
    15whtrd likes this.
