Cold start issues
Discussion in 'General Tundra Discussion' started by gtucke, Feb 18, 2022.
  1. Feb 18, 2022 at 10:27 AM
    gtucke
    gtucke [OP] New Member
    First crank in the morning truck turns over fine but it cranks and wants tries to shut off before starting After the first start does not happen again all day. No codes Truck is a 2019 with 72000 miles. Puzzled
  2. Feb 18, 2022 at 10:37 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Still on your original battery? They've been known to go bad after about 3 years.
    You could also be affected by the fuel pump recall which can make your truck stumble on startup.
  3. Feb 18, 2022 at 10:41 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    My truck had a series of odd issues when my battery was dying off. My seats would routinely try to pin me to the wheel, door locks would act up when i was driving and my temp display was always off. A battery health test likely doesn't cost much if anything.
  4. Feb 18, 2022 at 10:42 AM
    gtucke
    New battery has been installed and charging system checked.
  5. Feb 18, 2022 at 10:46 AM
    Tbrandt
    Tristan
    Kansas City
    Watch these videos, this guy had to have his fuel pump replaced. Does his experience match yours?
  6. Feb 18, 2022 at 11:06 AM
    gtucke
    Not like that mine cranks rpm drop to 400 and then runs fine after a couple of seconds
  7. Feb 18, 2022 at 11:13 AM
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Eibach Pro Sport Shocks (1.25in), RAS HD, Sumo Springs, HAWK Talon Rotors, OEM Tow Mirrows, Lund Hard Fold Tonneau, ESP Storage, Stampede Flares, Husky xAct Fit liners, General Grabber ATX 275/60R20
    Sounds like same issue I had with my 2016 with 72k miles about a month ago. Look for VIN match in "Additional Information" section. I had to argue with local dealer, but after showing this, all was taken care of by Toyota. They kept telling me that "There are no recalls for your truck", I kept telling them, "This is a TSB, not a recall". Good Luck!
  8. Apr 7, 2022 at 6:08 PM
    bmtrujillo98
    bmtrujillo98 New Member
    As @16CMTXED said, could be a flex-fuel issue if your truck is a FFV. The problem is, the alcohol density sensor gets out of whack and thinks you’re running too much ethanol (even in my case, have never run a drop of E-85) when it’s cold. This causes the truck to run a different firing sequence and leads to weird fuel trims and extended cranking. Reflashed my ECM twice to no avail, eventually the fuel pump failed due to all the cranking. Finally, my problems have gone away when I got the supposed newer style fuel pump with those recalls from 2019 and reflashed the ECM again for good measure. Truck starts up first try on negative fahrenheit days here in Colorado.
    16CMTXED likes this.
