Cold Air Intake
Discussion in 'Performance and Tuning' started by PNJ 4x4, Jun 29, 2020.
  1. Jun 29, 2020 at 7:53 PM
    PNJ 4x4
    PNJ 4x4 [OP] New Member
    2018 TRD OFF ROAD
    Any thoughts? Just picked up a left over 2019 trd pro. Did go for the extended factory warranty so wanted some feedback on the trd cold air intake vs the k&n, s&b..warranty thoughts?
  2. Jun 29, 2020 at 8:02 PM
    RobertD
    Robert
    DFW, Texas
  3. Jun 29, 2020 at 8:02 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    cold air intakes are a power robbing waste of money on our trucks. the best one money can buy is already installed on your rig.
    Rex Kramer likes this.
  4. Jun 29, 2020 at 8:15 PM
    PNJ 4x4
    2018 TRD OFF ROAD
    Thanks
  5. Jun 29, 2020 at 9:01 PM
    snappy924
    snappy924 New Member
    Garrett
    Pasadena, California
    2017 Tundra Crewmax 4x2
    Bilstein shocks, Tembren bump stops,
    Can’t run the CAI here in Ca!
  6. Jun 29, 2020 at 9:21 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    SABM > CAI
    Tundra234 likes this.
  7. Jun 29, 2020 at 9:54 PM
    AZTundra
    Paul
    Phoenix, AZ
    Agree with the above post. Search for SABM.
  8. Jun 30, 2020 at 4:59 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Toyota has a really well designed stock intake. Just swap the air filter with a TRD / K&N and call it a day. If you want to get all fancy pants, install the TRD air flow accelerator while you're at it. As much as I like the TRD CAI, the fact it uses the stock bottom tells me all I need to know. I personally can't justify spending the money for it.
    Black Wolf likes this.
  9. Jun 30, 2020 at 6:35 AM
    timdske
    timdske Another Old Guy
    Fort Worth Texas.
    2019 MGM SR5 4x4 Tundra TSS Offroad
    I like the way a cold air intake looks. It really adds to an engine bay especially when several other mods have been done. It gives a real finished look. But the price tag on some of them are ridiculous. I just watched the vid on the SABM mod. That looks really slick. I might try that one.
    InsaneAuto86 and texasrho83 like this.
  10. Jun 30, 2020 at 6:55 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    The bottom is reused and yes it is pricey but it is awesome when paired with the trd dual exhaust.
    Tundyfundy likes this.
  11. Jun 30, 2020 at 7:11 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Get an AFE DRY drop in filter. If you want a little more throttle, get a Sprint booster. Those 2 parts will cost around the same as a CAI
  12. Jul 1, 2020 at 1:25 PM
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    Don't be afraid to check out the Stillen unit. I'm way happy with it.
  13. Jul 1, 2020 at 1:40 PM
    prevent
    prevent New Member
    2014 5.7L Tundra SR5 DC
    TRD Catback Stillen CAI DAP Tune Tow Mirrors Light sensor Dashcam TRD Pro Grill LED Interior lights + DRL’s
    I second the Stillen.
    BENWALES likes this.
  14. Jul 6, 2020 at 12:46 PM
    snappy924
    Garrett
    Thanks for your write up! Saved me some $$$$$. Oh wait the wife already spent it! Stay healthy!
    10TundraSR5[QUOTED] and RobertD like this.
  15. Jul 18, 2020 at 8:10 AM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Check out the new Stillen unit for sure...have it on my 2020 Platinum and love it...proven results on dyno, that’s why I went with it over the others and no regrets...truck feels more responsive and the little extra sound paired with my exhaust is awesome...hope it helps!
    https://youtu.be/ShMHlSM2tJg
  16. Aug 23, 2020 at 10:14 AM
    GREENwithENVY
    GREENwithENVY New Member
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Did you go with a dry or oiled filter?
  17. Aug 23, 2020 at 8:59 PM
    2020Platinum
    Patrick
    Northeast PA
    I went with the oiled...I’ve heard that oiled filters give a little better sound so I decided that was the route I wanted to go
  18. Aug 23, 2020 at 9:07 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  19. Aug 24, 2020 at 3:56 AM
    I really like this CAI. Besides the TRD intake, I can finally recommend one for the Tundra. Having the air intake also coming from the front...definite improvement.
    Air intakes that are partial open on top like the K&N...might as well just suck the air from the engine compartment.
    Air Intake Temperatures can be rather high on factory/craptastic aftermarket ones. The factory one on my truck was 20-25+* higher AIT than ambient temperature. When towing in 95* weather, that sucked.
  20. Aug 24, 2020 at 10:57 AM
    2020Platinum
    Patrick
    Northeast PA
    Absolutely, couldn’t agree more!...this is probably the only CAI I would recommend as well!
  21. Aug 25, 2020 at 2:19 PM
    Zero One Actual
    Not knowing anything about CAI’s other than what I have read here and on YouTube and never having used one, what is the deciding factor to purchase a CAI or to not purchase one?
  22. Aug 25, 2020 at 4:29 PM
    CAI’s like the following are just crap. In most cases, the factory system nets better overall power/torque numbers:
    See how the open top and the side of the box can and most likely does draw in hot air from the engine compartment. The Air Intake Temperatures on this style are actually power robbers. You want the coolest, dense air possible to improve performance.
    Ones like the Stillen or the like draws the coldest air from outside.
    5129A288-9FE4-4C19-858E-4129FE9A5857.jpg 2816F191-5D3D-4D37-9576-680D1B390106.jpg D3C2E47E-26A4-492B-AD99-CD19FDC5E98D.jpg
    I just installed the Banks Ram Air on my truck due to the performance gains many others have experienced. Now if I would have a functioning hood scoop like GM has, I wouldn’t have even bothered.
    Most of you have seen or know about swamp coolers right? In dry/hot climates they work rather well to cool down a house. It works on evaporation. Swap coolers do not work in higher humidity environments. Most of you know I operate a combined cycle natural gas power plant. We use this very technology to gain more efficiency/heat rate from cooler, more dense air before entering the 17 stage compressor.
    06C018D6-894D-4E57-A504-CE478553437B.jpg 216C518E-9144-4297-9A62-7BA9F246C129.jpg
    Probably more information than need.
  23. Aug 25, 2020 at 4:31 PM
    Zero One Actual
    No, that’s perfect. I’m just wondering if I have a 2019 with under 9500 miles on it and is used as a around town/ off road hunting and camping rig if the $400 is worth it? Thank you for taking your time for that write up!
  24. Aug 26, 2020 at 4:58 AM
    10TundraSR5
    Tennessee
    I would say most people get them based on looks, sound, and the promise of power gains. Personally, when I look at Toyota's stock design, I just don't see how you can really improve it. Air enters through the fender well, goes through the filter, and travels a very short distance in a straight line directly to the throttle body. It is the most unobstructive stock design I've ever seen. Filter swap for me but if I bought one, it would be the TRD CAI just so I could have more TRD parts on my truck. I still debate it to this day....
  25. Aug 26, 2020 at 5:30 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Increasing airflow into the engine has little benefit if you
    don't also increase the engines ability to exhaust that air.
    How I increased horsepower and torque on a budget.
    DAP tune: 15-20 hp peak gain, and 20-30 low & mid-range power gain with 91 octane.
    BAMuffler cat-back with single stock tail pipe: 3 to 10 hp, no loss in low end torque.
    Drop in aFe Magnum FLOW Pro DRY S Air Filter: 5 to 10 hp, but only if the exhaust is freed up.
    These 3 changes cost me about $1500 and they made a world of difference in how the engine performs... keeping the MAF clean ensures peak performance.
    Vr0ck likes this.
  26. Aug 26, 2020 at 11:48 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    The only intake I've seen available for our trucks that I would even consider is the Stillen. Actually, I'm pretty sure I'm going to get one soon. Anything else you're likely going to lose power. The TRD Pro version is just a fancy looking stock intake, I highly doubt it does anything more than the regular stock intake, maybe make a little more noise. I just don't see anything different in the design or where the air comes from to make me think it makes any power over stock (OK, maybe 1 HP more). And my hood is closed 99.5% of the time, so I don't really need a big $500 TRD logo hiding underneath the hood for no reason.
    Whether its worth it for your needs is really up to you. If you want a little more power (marginal) and a little more sound, and potentially a bump in MPG (again, marginal) then I'd say its worth it. Like Rex said above, until you start stacking complimentary mods each one on its own has very little real impact. A good intake and a tuned exhaust will allow the motor to operate more efficiently and should provide a slight bump in power and MPG. Add a tune and now you're cooking. It does sound awesome with an intake and exhaust, for whatever that's worth. Again, whether its worth the initial cost is up to you.
  27. Aug 27, 2020 at 6:11 AM
    Zero One Actual
    I currently have the TRD duel exhaust I picked up awhile ago when they had that TRD forty year anniversary forty percent off sale. I have a 2019 and I don’t think there is a tune out for it that I am aware of. I agree with the Stillen design which is why I’m so interested in it. I’ve read about the TRD CAI being a waste for a long time, so that’s why I got excited about this one coming out. I will go ahead and try it out and see how it goes. Thanks for your information!
  28. Aug 27, 2020 at 8:57 AM
    10TundraSR5
    Tennessee
    Let us know what you think when you get it. Its a nice looking setup.
