Cold Air Intake Suggestions
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Izzydude51, Jul 17, 2025 at 9:42 PM.
  1. Jul 17, 2025 at 9:42 PM
    Izzydude51
    Izzydude51 [OP] New Member
    Yesterday
    Israel
    2016 Tundra TRD Pro
    Needed to replace cabin air filter and thought why not upgrade? Any suggestions???
  2. Jul 18, 2025 at 3:31 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    A majority of Cold air intakes are downgrades to hot air intakes. For a tundra, your best bet is what is called the SABM or stock airbox mod which involves drilling an extra hole in the air box and inner fender wall and installing flanged fittings and then joining them with a small piece of hose allowing extra air into the box. Do a search and you will find lots of info. The other thing you can do with or without the SABM very quickly and cheaply is the TRD airflow accelerator which uses the proven principals of a velocity stack to increase the airflow into the box. I recommend an AFE dryflow filter or a Wix paper filter for good flow and filtration.
    Saltyhero13 likes this.
