Cold air intake reviews
Discussion in 'Performance and Tuning' started by Cpa757va, Jul 23, 2019.
  1. Jul 23, 2019 at 4:30 PM
    Cpa757va
    Cpa757va [OP] New Member
    Chad
    Hampton roads VA
    2019 Tundra limited TRD off road
    See build thread below.
    Hello all, I’m thinking about purchasing a TRD cold air intake and installing it myself. Wanted to see if anyone has done it and if so what are the benefits of it, is it relatively easy to do yourself. Worth the money, etc. I have done it to previous vehicles and I liked the deeper growl it gave the engine when hitting higHer RPMs.
    Thanks!
  2. Jul 23, 2019 at 4:32 PM
    aggie_tundra
    aggie_tundra Always Tired
    2021 2500 Custom
    TRD air flow accelerator for $15 and an AFE drop in dry filter for $60 or whatever they cost now
    BENWALES, 10TundraSR5, Rica25 and 2 others like this.
  3. Jul 23, 2019 at 4:44 PM
    Borgs
    Borgs New Member
    PA
    I put the TRD Cold Air Intake on in the spring. Very easy install. I don’t notice any gains. In fact I think I prefer the way it ran - especially in beast mode - when I had the stock in. I consider it a waste of money. If I had some free time I’d probably pull it out and sell it.
    I have TRD dual exhaust too. And I think i actually preferred the exhaust notes before I installed the CAI.
    Rica25 and Trooper2 like this.
  4. Jul 23, 2019 at 4:54 PM
    Cpa757va
    Chad
    Hampton roads VA
    This is new to me, are you saying go with these two options instead of installing a cold air? What do I remove from stock to make this happen and is it pretty easy to do?
    Rica25 likes this.
  5. Jul 23, 2019 at 5:06 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    CAIs in Tundras are pretty subjective but you’re gonna see more guys say to do the SABM.
    Rica25 likes this.
  6. Jul 23, 2019 at 5:27 PM
    Mnorris1206
    08 tundra
    Inquiringone and Rica25 like this.
  7. Jul 23, 2019 at 6:12 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Exactly what I did.
  8. Jul 23, 2019 at 7:02 PM
    Rica25
    Ricardo
    Tulare
    I had Volant intake for about 1 yr and removed it went back to stock and put in TRD drop in filter with the SABM.......much better response with SABM and also throttle body by pass
    texasrho83 likes this.
  9. Jul 23, 2019 at 7:14 PM
    Rica25
    Ricardo
    Tulare
    I made my own SABM with lowes purchases
    Inquiringone likes this.
  10. Jul 23, 2019 at 7:19 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    I have the TRD, got it during the 40%sale. I love the sound of it and it looks cool. I hear all the noise about no gains, may be true. I seem to feel and hear difference in my but and ears and thats all that counts! It sounds badass under throttle. I probably would have waited a little while longer if not for the 40% off sale. Also have the TRD duals, also sounds good and looks great... no drone either!
    P-Factor and Rica25 like this.
  11. Jul 23, 2019 at 8:42 PM
    Tundra_power
    Tundra_power New Member
    Nick
    You did the throttle body coolant bypass did you notice any performance bump.
    Rica25[QUOTED] likes this.
  12. Jul 23, 2019 at 8:54 PM
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    I too have the trd Cai and exhaust. The Cai is a waste of money with a cool factor. But at 40% it was hard to pass by. The exhaust was worth the money.
  13. Jul 23, 2019 at 9:08 PM
    Rica25
    Ricardo
    Tulare
    hard to say due to doing all the mods at same time
    Tundra_power[QUOTED] likes this.
  14. Jul 23, 2019 at 9:13 PM
    Tundra_power
    Nick
    How did you do it?
  15. Jul 23, 2019 at 9:20 PM
    Rica25
    Ricardo
    Tulare
    i cut the 3 inch hole then went to Lowes to purchase a black drain couple images_b091978362c41201648f571172917276f1e4a5c3.jpgsomething like this it was only a few bucks [​IMG]this one here went bolted to the fender and the first pic attached to the second picture then also made the whole in the air box
    revtune and Inquiringone like this.
  16. Jul 23, 2019 at 9:24 PM
    Tundra_power
    Nick
    Cool also how did you do the coolant bypass on the throttle body.
    Rica25 likes this.
  17. Jul 23, 2019 at 9:24 PM
    Rica25
    Ricardo
    Tulare
  18. Jul 24, 2019 at 4:13 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Save your money. The stock intake is really well designed. I just did an air filter swap for the TRD filter. Thought about getting the air flow accelerator but decided against it just because I drive like an old man and wouldn't see any gains. Maybe down the road but who knows.
    Rica25, texasrho83 and TXTundra2722 like this.
  19. Jul 24, 2019 at 6:05 AM
    TXTundra2722
    2015 Black Tundra
    Many members have posted this and unless you're running a SC then you're wasting your money..... aside from the looks. You are correct that Toyota actually designed this part right and there hasn't been any sign"In numbers" of improvement over stock. Once again only the SC'd guys have reported small gains from this.
    Rica25 likes this.
  20. Jul 24, 2019 at 6:06 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    There’s hardly any feedback that shows TRD accelerators give noticeable, if any, gains. I looked into getting one myself but after research, decided against.
    revtune likes this.
  21. Jul 24, 2019 at 8:00 AM
    Rica25
    Ricardo
    Tulare
    I did one at same time with th SABM
  22. Jul 24, 2019 at 6:00 PM
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    I did the AFE superstock system combined with trd accelerater and noticed an improvement throughout the entire rpm band. Picked it up for under $200 with a 25% off promotion they were running. MPGs went up a few ticks too.
    Hbjeff likes this.
  23. Jul 25, 2019 at 12:06 PM
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
  24. Aug 2, 2019 at 1:45 PM
    Cpa757va
    Chad
    Hampton roads VA
    179CED49-B61D-4279-818D-F46B935C9C55.jpgI took everyone’s advice and opted against the cold air and purchased these two items, am I on the right track? How easy is installation?
    Thanks
    Rica25, bgdv1 and BamaMan44 like this.
  25. Aug 2, 2019 at 1:48 PM
    Tundra_power
    Nick
    Did you get the sabm intake??? Thats what i would do if i was you.
    Rica25 likes this.
  26. Aug 2, 2019 at 1:50 PM
    Tundra_power
    Nick
    I had the sabm and than i had the s&b intake. For me personally i would choose the s&b any day. The build quality is amazing and from the butt dyno seems to have more pep off the line than sabm and k&n drop in. And im running bullydog tune on performance.
  27. Aug 2, 2019 at 1:52 PM
    Cpa757va
    Chad
    Hampton roads VA
    What exactly is a SABM? I’m unfamiliar with what that requires.
    Rica25 likes this.
  28. Aug 2, 2019 at 2:53 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I have the S&B, Doug Thorley long tubes, dual exhaust & Bully Dog in premium/whatever the enhanced transmission is and can get out of my way!
    lol
  29. Aug 2, 2019 at 3:30 PM
    Tundra_power
    Nick
    Stock air box mod.. You have to cut another hole in your fender for more cold air. Its like 100 bucks or so.
    Rica25 likes this.
  30. Aug 2, 2019 at 3:32 PM
    Tundra_power
    Nick
    I have the same setup but i have the doug thorley shorties crazy low end torque and 4.88 gears with lsd running 33" tires runs like a street car lol.. But its a work truck sometimes.
    Rica25 likes this.
