Cold air but A/C isn't on
Discussion in '3rd Gen Tundras (2022+)' started by Silver23, Jan 4, 2023.
  1. Jan 4, 2023 at 9:18 AM
    Silver23
    Silver23 [OP] New Member
    2023 Silver 1794 TRD
    First, let me admit I have not read the manual. Picked up my 2023 1794 iForce Max in mid-December. Now that it is hot outside in Louisiana, I noticed very cold air coming out of the vents and the a/c button isn't on (no amber light), nor is "A/C" displayed on the screen. I've been driving in Eco mode. When I press the AC button and the amber light comes on and AC is displayed on the screen, there really isn't any difference in the temp. I'm no genius, but it appears that there is an issue. And let me clarify, for the last several days, it's been about 77 degrees with 90% humidity. There's no way cold air should be flowing through the vent if the AC isn't on. Thanks.
  2. Jan 4, 2023 at 9:44 AM
    rickpaw
    rickpaw New Member
    2023 Tundra LTD
    In the settings/climate control menu on the big screen, you can select to have the AC on with AUTO mode. I think it's set to AC on by default, but you can turn it off.
  3. Jan 5, 2023 at 11:58 AM
    Silver23
    I did a quick look yesterday evening in settings on big screen and didn't see where I could make any adjustments for the HVAC. The "Auto" button is not on.
  4. Jan 5, 2023 at 11:59 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Did you pop the hood and see if the AC compressor is running/turning when this occurs?
    2mchfun likes this.
  5. Jan 5, 2023 at 6:19 PM
    rickpaw
    rickpaw New Member
    2023 Tundra LTD
    257B2255-4EF4-4796-BDCA-92425328A5F9.jpg Mine is a limited so the interface maybe different.
    On the big screen with the engine running/gear in Park, you go to setting/vehicle customize/climate control. Then you can make the selection from there. AC is set to be on by default.
  6. Jan 5, 2023 at 6:55 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    But even with that, wouldn't the AC light come on when the AC was running?
    I don't have a Gen 3, I'm just curious...:confused:
  7. Jan 6, 2023 at 4:59 AM
    rickpaw
    rickpaw New Member
    2023 Tundra LTD
    Dont know. This is the first Tundra I’ve owned.
  8. Jan 6, 2023 at 7:37 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Next time it is blowing cold air when you feel the ac is off, open the hood and see if the compressor turning/running.
    If the ac is off, it shouldn't be turning..
    The ac clutch pulley on the belt of course spins all the time, but the actual compressor should only run/turn with ac or defrost on.
    Also note that the system will blow cold air when the defrost is on.
    Not a Tundra but this is what I'm referring to.
    https://youtu.be/bhVV2f25kQg?t=57
    Also, the ac tubing will be warm or cold under the hood if the ac actually is on.
    As well as condensation dripping under the truck if the ac is on, especially with your high humidity.
    If the compressor is turning all the time with the ac and defrost off, then you have a problem..
    And welcome to the forum..
    Good luck..
    2mchfun likes this.
  9. Jan 6, 2023 at 12:41 PM
    rickpaw
    rickpaw New Member
    2023 Tundra LTD
    Thanks for the replies, but I think it's more beneficial to the OP. I don't have any issues on my Limited.
    PS - tried looking under the hood for the AC compressor. No dice, as it appears to be buried.
    1lowlife[QUOTED] likes this.
  10. Jan 6, 2023 at 12:46 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Sorry, I thought you were the OP, I wasn't paying attention.
    The AC compressor is way down on the driver's side on my Gen 2.5, you can just barely see the front of the clutch.
    It may be buried on your Gen 3 I've never looked under the hood of one..
  11. Jan 6, 2023 at 1:18 PM
    blenton
    blenton New Member
    Do you have the air vents set to the defroster position? The vehicle cycles the AC in defroster to dry the air out no matter the temperature setting. It doesn’t illuminate the AC light on the dash when doing this.
    But that’s interesting to see the on-screen settings for third gen’s to automatically set the AC to on. Other vehicles that I’ve owned don’t really communicate that the AC is on when using auto climate.
  12. Aug 25, 2023 at 5:04 PM
    Toyota Crown
    Toyota Crown New Member
    I have the same thing for 2023 Toyota Crown here. Settings: front vent only, no ac auto on..................and i get cold air with ac light is NOT on. Salesman couldn't explain it to me why. i have seen online videos that it's due to ac compressor belt is always running when you turn on your car with or without engine on. And when i push ac button on, i feel the air a little colder. I am still doing some more research for this. And i will ask tech service when i come in for oil change there.
  13. Aug 25, 2023 at 5:11 PM
    Utahcamper
    Utahcamper New Member
    2023 Tundra Platinum
    Try this, when you feel the air is cold, hit the AC switch. It will most likely say on. Hit again and it will say off.
    pwpblue likes this.
  14. Aug 25, 2023 at 6:51 PM
    Toyota Crown
    the ac switch can be on or off no problem there but cold air is still coming out even with ac switch is off on center dash and off in LED screen too.
  15. Aug 25, 2023 at 6:53 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Is the setting on auto? I notice if in auto it won’t display if it’s running AC or not, it just adjusts to make it the temp you set it at.
  16. Aug 25, 2023 at 6:56 PM
    Toyota Crown
  17. Aug 25, 2023 at 6:58 PM
    Toyota Crown
    no auto, no ac light on.............only front vent for air. And cold air does come out. I thought Toyota was genius if they could make cold air without ac on.
  18. Aug 25, 2023 at 7:00 PM
    22whatwedo
    The Open Road
    Maybe they can pull that trick on my house and keep this power bill down!
    batman900 and Black widow TRD like this.
  19. Aug 27, 2023 at 4:15 PM
    SketchSketch
    SketchSketch New Member
    2023 Limited TRD Off Road Red
    Chrome delete / Mustache Blackout / PPF
    The hybrids have an electric AC compressor, not a belt driven one. Not sure about the non hybrids. I've noticed the same thing about the AC light, but it never really bothered me as long as the air stayed cold.
  20. Aug 27, 2023 at 5:15 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Usually the complaint is AC on no cold air…. Wow, Fucken Toyota!!
  21. Aug 27, 2023 at 9:58 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Same thing always happened on my 2022 non hybrid.
    AC Off it says
    Front vents blowing only (no window vents)
    And... Air that blows is cold no matter what, ac is definitely working, and lots of condensation water dripping from under the truck.
    So basically, the AC Off sign that illuminates seems to be a joke. AC is always working regardless
    :rolleyes:Toyota
    msauter likes this.
  22. Aug 28, 2023 at 10:46 AM
    Toyota Crown
    I don't have prob with summer time. But when temp dips below 20's, i am not sure if it's smart way to run your ac compressor like that in a morning. My ac man told me once that when temp outside of the house below 50, don't turn my house ac on. That will damage compressor since metal shrinks due to cold weather. I understand that car ac compressor material is better than house ac compressor material. But when it's too cold outside, all material will shrink a little bit.
  23. Aug 28, 2023 at 1:33 PM
    nodak67
    nodak67 New Member
    JR
    if you put the system into defrost mode, it will run the compressor and not light the a/c button. its to ensure you dont fog up the front windshield in defrost mode.
    this is normal mode for toyota for many years.
  24. Aug 29, 2023 at 12:08 AM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Auto - No A/C light or fan settings. You just choose the Temp. It does the rest. If you choose the A/C button on/off or fan speed you are immediately out of Auto mode and in manual control. All lights will come on. *Note, you can always select the output mode ( dash, dash&floor, floor, defrost, etc ) while in either mode. **Defrost has run the AC compressor in all cars for 40+ years. The cold evaporator coil pulls the moisture out of the air reducing the fog on the windshield glass
  25. Aug 30, 2023 at 9:56 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Thank you for the explanation.
    By "defrost" do you mean when air is getting blown onto the windshield?
    Simple question - how can I run fan with AC OFF? Any way I try, AC is always ON, even though AC OFF message is lit up
    Thx
  26. Aug 30, 2023 at 10:18 AM
    Azrsx
    Azrsx New Member
    2023 tundra blueprint limited
    Glad this came up, was wondering myself since it's the first time I've seen this... Seems like no matter what, A/C is on from reading above. It's nice in AZ to cruise without in the winter and possibly save some gas mpg
  27. Aug 30, 2023 at 11:52 PM
    PNW Tundra Mike
    Southern Cal
    With AC set to off and the vent setting set to anything BUT the defrost symbol (windshield) or defrost+floor you should not have the compressor running. (either defrost setting fires up the compressor to dry the air) You also need to manually select fresh outside air and set the temp to LO to close off the warm side of the system. Learned all this on a previous 2009 Venza and the new Tundra is the same.
    nodak67 likes this.
  28. Aug 31, 2023 at 4:21 AM
    nodak67
    nodak67 New Member
    JR
    this has been toyota's mantra on all models for quite a while.
    in the long run it helps extends the life of the compressor without the owner knowing. i know it helps me since we can go 6-9 months without using the a/c system up there in ND due to we only maybe get above 90's for about 1 month a year.
  29. Nov 11, 2023 at 12:08 PM
    Toyota Crown
    Here is how to turn A/C off in your car:
    Using LCD screen only: select car icon - then select Climate - you will see A/C icon is on - Click it to turn it off. After that if you need to have a/c on, use physical button on your center dash.
  30. Nov 11, 2023 at 2:11 PM
    Rykr
    Rykr New Member
    2023 SR5 TRD Sport 4x4 MGM
    Wondered this also. The guy at the dealer told me the annoying thing about the gen 3 is that if you want AC you have to turn it on everytime you start the truck. Sometimes I forget and it’s still cold. It’s the same temp of the button is on or off. I don’t use AUTO either.
