Coilovers stock setting lift
Discussion in 'Suspension' started by Cuban11182, Aug 7, 2018.
  1. Aug 7, 2018 at 4:35 PM
    Cuban11182
    Cuban11182 [OP] New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
    I'm looking to get a set of coilovers and know they say 0-3 for most of them but are they at 0 right ito if the box? Reason I'm asking is my last two trucks all gained from the stock setting.
    Also, for best in road comfort, is King the go to for these trucks?
  2. Aug 7, 2018 at 5:26 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Most are 2-3” of lift out the box. I believe kings are set at 2” out the box. @TheBeast ?
    King has my vote for best overall ride. You consider 6112’s at lowest setting? Those are good for how much they are.
    TheBeast likes this.
  3. Aug 7, 2018 at 5:28 PM
    TheBeast The Beach
    yes, roughly 2". both are set the same so if you have Tundra lean then make sure to adjust driver side before you install them.
  4. Aug 7, 2018 at 5:32 PM
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    Sounds good, thank you.
    I'm considering all of them and not used to the aftermarket support since Nissan didn't have much. I did run Radflo 2.5, Fox 2.0, 5100 and settled on Kings with my 2012 Pro4X and ran Icons on my XD. That said I loved the Kings.
  5. Aug 7, 2018 at 5:33 PM
    TheBeast The Beach
    check also ADS offering
  6. Aug 7, 2018 at 5:50 PM
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    I've seen them around but have no real comparison. I see they're a tad bit more expensive too. Has anyone tested both the Kings and them? Why do you suggest them?
  7. Aug 7, 2018 at 5:54 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I have radflos. Good but if you can afford kings go that route!
