Coilovers install? Drop LCA or loosen?
Discussion in 'Suspension' started by Bigfx, Sep 3, 2015.
  1. Sep 3, 2015 at 6:31 AM
    Bigfx
    Bigfx [OP] New Member
    Hey guys
    Researching the best way to install my new ome coil-overs, some videos show loosening the lower control arm and prying out the strut others show lowering the LCA completely and lowering the strut straight down? Which way is better for a install on jack stands thanks in advance
  2. Sep 3, 2015 at 7:22 AM
    Funny you should ask. I'm picking up an OME 3" lift setup from ToyTec this coming Tuesday. I will be swapping out my OEM TRD coil overs/spacers that I recently swapped in for the stock SR5 KYB's. I used jack stands. We disconnected front sway bar links from LCAs . Also disconnected UCAs each spindle. Make sure you disconnect the speed sensor line bracket/mounts from each UCA. Remember to disconnect speed sensor connector from its bracket located near the engine too, otherwise you will stretch them too far when lowering LCAs and F them up. Should be an easy swap from there. The only hold up we had was loosening the sway bar link bolts. One side was a bitch to loosen. You may not have to disconnect the links but it made it much easier to swap, otherwise you can try the prying method which we tried but couldn't get enough leverage so we dropped the LCA's
  3. Sep 3, 2015 at 7:47 AM
    Bigfx
    Did you have to mess with the tie rod ends?
  4. Sep 3, 2015 at 7:58 AM
    No. By disconnecting the UCAs from the spindle, you can move the spindle either direction to facilitate the install without disconnecting the tie rods.
  5. Sep 3, 2015 at 8:04 AM
    Bigfx
    Great thank you
  6. Sep 3, 2015 at 8:27 AM
    No problem. I'm only getting the OME coil overs with front diff drop kit and rear OME shocks. Don't need the u bolts/ block spacer since I have a additional leaf for rear lift already. Going to have ToyTec assemble the coil overs. Still have to work out what discount I'm getting. I may go for the new Boss rear shocks since they are priced similar to the OME rears.
  7. Sep 3, 2015 at 8:41 AM
    Bigfx
    I did the whole kit and got that 10% discount on Monday so I'm pumped plus I had them assemble the front coilovers so it's just a straight swap
    T-Rex266 likes this.
  8. Sep 3, 2015 at 9:27 AM
    Cool. I'll make sure I get 10% too. The BOSS lift is real nice, but the OME is a good lift too for the money.
  9. Sep 7, 2015 at 1:20 PM
    Bigfx
    Ok just got done installing the fronts with my cousin, the first side was some trial and error issues but after that we tackled the other side took and it maybe 10 minutes, installed the front diff kit too overall about 2 hours from start to finish getting it aligned right now
    Black Wolf likes this.
  10. Sep 7, 2015 at 5:07 PM
    Cool. I guess all that is left for me to to get a %10 discount instead of %5.
  11. Sep 8, 2015 at 4:37 AM
    Bigfx
    The only reason I got was bc they were running a special for customer appreciation that ended the 31st
  12. Oct 14, 2015 at 6:12 PM
    timekop
    timekop New Member
    Red 4w 2010 DC
    MBRP duals, 3" Pro Comp 3/1 level, nfab front bump w/ PIAA, 18" RockStar, Nitto Grap, K&N drop in
    Bigfx,
    So how is the ride with the OME coil over?
  13. Oct 14, 2015 at 6:19 PM
    My setup is a little stiff on the road due to the heavy duty coil option. Off road is night and day compared to stock/TRD suspension. The old mining roads here in CO can be a bitch. I'm not bouncing around near as much as I use to and can haul ass if I want. Huge difference.
  14. Oct 14, 2015 at 6:35 PM
    timekop
    timekop New Member
    Red 4w 2010 DC
    Nice. I'm thinking about replacing the spacer I have on fronts with a decent coilover. I guess you can't beat the price. Probably go with a lighter spring since I don't have anything heavy on the front bumper.
  15. Oct 14, 2015 at 6:40 PM
    The OME is a very good mid range setup. Maybe the best for its price point. Check with ToyTec for 5% member discount off decent pricing already.
    timekop[QUOTED] likes this.
  16. Oct 14, 2015 at 7:02 PM
    Bigfx
    I love the way the 612 ride more responsive but not jarring at all seriously the truck should have come this way
  17. Oct 14, 2015 at 7:07 PM
    It was like I was driving a different truck. The stance and feel were immediately noticeable.
  18. Oct 14, 2015 at 7:10 PM
    Wanted to add that ToyTecs OME coil overs will give you 3" lift.
  19. Oct 14, 2015 at 7:35 PM
    timekop
    timekop New Member
    Red 4w 2010 DC
    Did you guys do the front diff drop too?
  20. Oct 14, 2015 at 7:42 PM
