Coilovers for 7-8" lifts?
Discussion in 'Suspension' started by SullyMoto19, Jul 18, 2018.
  1. Jul 18, 2018 at 9:21 AM
    SullyMoto19
    SullyMoto19 [OP] New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    guys and gals, I have had so many mixed responsed to this question.
    I am looking at different coil over options for my '17 tundra with an 8" readly lift. I have aftermarket UCAs already. stock shocks and coils in the front.
    I have heard the strut will need to be taken out? doesnt make sense if its in there now and not effecting my stock shocks.
    can I just swap out the stocks for a pair of after market coils?
    makes sense because the readylift retains majority factory parts up front.
    please enlighten me....
  2. Jul 18, 2018 at 9:23 AM
    SullyMoto19
    Tyler
    Houston, Texas
    @1UPPER you're running at least a 7" procomp right? and you have the fox shocks and ressys with aftermarket UCAs. any problem when you were searching? TIA
    1UPPER likes this.
  3. Jul 18, 2018 at 9:24 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Fox, Icon and ADS make Coilovers for 7-8 inch lifts
  4. Jul 18, 2018 at 9:29 AM
    SullyMoto19
    Tyler
    Houston, Texas
    I mean they seem to be available, and adjustable. but I don't see where those companies differentiate from stock height to 8" lift.
  5. Jul 18, 2018 at 9:38 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Ill make it simple, use Pro Comp K5069B, remove the shocks from that kit and use Icon 58651 fronts and Icon 57721 rear. DONE:hattip:
    joonbug and GNTundra like this.
  6. Jul 18, 2018 at 9:39 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    You'll need to call for a custom build. They'll probably ask for a few measurements and your goals for the truck and build to that.
  7. Jul 18, 2018 at 10:35 AM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    There seems to be some confusion here, the factory coilover that is in your truck with a preload spacer and top mount spacer will be removed and replaced by a complete coilover it will come with a new spring & shock absorber. You shouldn't reuse any of the factory coilover pieces except maybe the bolts. The new coilover will be full length and not require the reuse of either of the Readylift front spacers. Tundras have coilovers, not struts, struts are on cars. Struts actually replace the upper control arm as the component that controls the top of the tire. You maybe getting some mixed info because people are calling the same part two different names.
    Lindenwood likes this.
  8. Jul 18, 2018 at 10:40 AM
    Cuzican
    Cuzican New Member
    Louisiana
    This image shows the difference between a strut and a coilover. While similar, they are different. Strut on left, coilover on right.
    SullyMoto19[OP] likes this.
  9. Jul 18, 2018 at 10:43 AM
    SullyMoto19
    Tyler
    Houston, Texas
    yes the spacer (about 4-6" in length) is what I was referring to.
    Im being told readylift 8" will need a custom coil like @trayday mentioned above. apparently they have super tight turn radius and the tie rods will hit the coils.
    there are some icon 58650 for sale near me and I wanted to look into them. but it seems like this is probably not going to be feasible. that is why I was asking if I can just swap it out and leave the spacer in.
  10. Jul 18, 2018 at 11:16 AM
    SullyMoto19
    Tyler
    Houston, Texas
    i find it incredibly hard to believe that im the only person to think of doing this.....
  11. Jul 18, 2018 at 1:00 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Most people want to get away from the spacer, it does more harm than good. The cost of a custom length setup isn't much more than a factory length design.
  12. Jul 18, 2018 at 1:08 PM
    Cuzican
    Cuzican New Member
    Louisiana
    I'm gonna go coilovers here soon, really hoping the Fox's will fit so I don't have to buy new rear shocks. A guy I work with just put them on his Zone lift, so I'm gonna do some measuring and see.
  13. Jul 18, 2018 at 1:52 PM
    Cuzican
    Cuzican New Member
    Louisiana
    I think the biggest issue with the question is that there just aren't as many trucks running the readylift 8".
  14. Jul 18, 2018 at 2:16 PM
    SullyMoto19
    Tyler
    Houston, Texas
    @Cuzican @trayday what about if I just swapped out the spacer for new shocks? I should be able to retain factory springs and the shock (6-8") would take place of the spacer? maybe add some shims?
  15. Jul 18, 2018 at 2:27 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    I dont think thats possible. The spring would be useless if it opened up.like that. Thats why coilovers need to replace spacer and shock. Did u try calling the big companies? Icon has some specs already and if they dont you will need to get the some measurements.
  16. Jul 18, 2018 at 2:33 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    I just ordered some kings ! It was a extra $200 for custom length! I have a 17 Pro with a 7in bds lift on it! I got kings all around coming in!
  17. Jul 18, 2018 at 2:35 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Yes I’m running 7” pro comp with Fox coil overs, rear reservoir shocks and UCA. No issues
  18. Jul 18, 2018 at 2:35 PM
    SullyMoto19
    Tyler
    Houston, Texas
    yeah ive gotten a shit ton of different answers. apparently when you install the readylifts, you have a to swap the driver side and passenger side tie rods. the readylift has a very weird turn radius. anyway, you need to swap the tie rods back to factory and aftermarket coils will rub against the tie rods if the alignment isn't perfect.
    seems more difficult than it should be.
  19. Jul 18, 2018 at 2:37 PM
    SullyMoto19
    Tyler
    Houston, Texas
    thatll be a badass setup. i guess ill just have to have some custom ones made.
    just amazes me that stock coils will fit on this lift but after market, non-adjustables wont. even if they were adjustable and i left them at the lowest adjustment, how could they not fit? lol
  20. Jul 18, 2018 at 2:38 PM
    SullyMoto19
    Tyler
    Houston, Texas
    must have different geometry than the 8" readylift. i wanted fox coils but the shop said the spacer would give me problems and i might actually lose some lift taking it out
  21. Jul 18, 2018 at 2:40 PM
    anthonygan
    2017 Cement TRD PRO
    Heck ya I’ll post photos once they come in!!! It cost me 4K for the front and back!!! I spec’d them OUT!
  22. Jul 18, 2018 at 2:44 PM
    SullyMoto19
    Tyler
    Houston, Texas
    damn... yeah little more than i wanna spend right now, but youre doing it right! maybe ill hold off and re-gear ;)
  23. Jul 18, 2018 at 2:45 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Are u wanting to put coil overs with the spacer on it?
    The whole point of coilovers is to remove the spacer. Have u tried a different shop?
  24. Jul 18, 2018 at 2:47 PM
    anthonygan
    2017 Cement TRD PRO
    Haha heck ya!! Re gear is on my mind for the future! I also just got Icon RTX leaf pack to replace the oem one and the 4 in lift block from bds ! Now the rear will still be lifted and handle a lot better !
    1UPPER likes this.
  25. Jul 18, 2018 at 2:48 PM
    SullyMoto19
    Tyler
    Houston, Texas
    i don't really care if the spacer is on or not. i just need all the clearance i can get with my 14 wide wheels. (i was asking about the spacer cause there is a guy here locally selling icons for dirt cheap lol they are for stock suspension though)
    anywho, ive talked to about 3 shops, all with different answers
  26. Jul 18, 2018 at 2:49 PM
    anthonygan
    2017 Cement TRD PRO
    damn 14 WIDE!!! Let’s see some photos
  27. Jul 18, 2018 at 2:55 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Got it. From the little thsat i know thsts not a good match. @Spvrtan might have some info for u. He has a bad ass truck
  28. Jul 18, 2018 at 3:03 PM
    SullyMoto19
    Tyler
    Houston, Texas
    Jsena and anthonygan[QUOTED] like this.
  29. Jul 18, 2018 at 3:22 PM
    anthonygan
    2017 Cement TRD PRO
    Damn those look sick!!! What are the specs of the wheels and tires ? I want a setup like that!!!
  30. Jul 18, 2018 at 3:24 PM
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    David
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    That is why you get custom length shocks for a big lift. I have a Pro Comp 7" lift. I went to Filthy Motorsports to get my custom King shocks. They will have you take all the measurements and when you receive your custom shocks the spacer goes away and your truck will be at the same height it was with the spacer. Take notes and measure everything as it is now. Ground to center of fender etc. When you order your shocks they will ask you if you are good with that height or do you want to go higher or lower. Do your research and good luck. Check out my build thread to see what I have on my truck.
    1UPPER and Jsena like this.
