Codes P0171 and P0441
Discussion in '1st Gen Tundras (2000-2006)' started by RR60, May 8, 2022.
  1. May 8, 2022 at 1:20 PM
    RR60
    RR60 [OP] New Member
    2003 SR5 Tundra long bed
    Trying to help out a friend. I have a Tundra also.
    But his is a 2000 RC V6 about 104K miles.
    Runs great but engine light is on and shows these codes.
    He has had work done on it by a friend who is a ford master mechanic but they cant solve this problem.
    When they try something the light will go off for a couple days then back on.
    So far have replaced the vapor canister, fuel pump, and checked vacuum hoses.
    Anyone have any suggestions
    Thanks
  2. May 8, 2022 at 5:35 PM
    RR60
    Forgot to list that. The gas cap was also replaced.
    Mogo Gogo[QUOTED] likes this.
  3. May 8, 2022 at 5:53 PM
    shifty` All my rowdy friends have settled down
    But did he go w/OEM (or Bosch) for the O2 sensors? If not, many have reported issues with non-OEM coil packs and O2 sensors.
    And just checking, if OEM, sidn't install V8 O2 on the V6? Aren't they different?
  4. May 9, 2022 at 7:13 AM
    dlowry81
    dlowry81 New Member
    Doug
    2004 Tundra Doublecab
    Was the solenoid replaced with the evap cannister?
    Mogo Gogo likes this.
  5. May 9, 2022 at 8:13 AM
    RR60
    Not sure on that part, but will put it on the list to be sure.
    Appreciate all suggestions that keep coming.
    The plan is for me to get a list from this forum. And just start replacing parts anyone suggest until the problem is solved. Like me. He likes the truck so much. That whatever it takes he is wiling to try.
    So far will try
    Another gas cap in case slight chance got a bad one. Cheap enough
    O2 sensors.
    solenoid for the evap cannister
  6. May 9, 2022 at 9:18 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Since lean condition(P0171 Bank 1) can be typical of unmetered air, suggest double checking all vacuum lines(hissing sound), PCV(which is on bank 1 side) including it's hose and clean MAF sensor w/CRC MAF cleaner.
    Might also ask friend if he has habit of over filling fuel tank which can be related to P0441.
    5N0W808 likes this.
