Codes codes codes
Discussion in '2nd Gen Tundras (2007-2013)' started by littlehandegan, May 9, 2024.
  1. May 9, 2024 at 4:57 PM
    littlehandegan
    littlehandegan [OP] New Member
    2008 Tundra 2wd , 4.0 V6 with 208,000 miles
    P043F (Confirmed) - EVAP System Leak Detection Reference Orifice High Flow
    P2419 (Confirmed) - Evaporative Emission Pressure Switching Valve Stuck On
    P043E (Confirmed) - EVAP System Leak Detection Reference Orifice Low Flow
    P0441 (Confirmed) - EVAP System Incorrect Purge Flow
    P2402 (Confirmed) - Evaporative Emission Leak Detection Pump Stuck On
    P2401 (Confirmed) - Evaporative Emission Leak Detection Pump Stuck Off
    P0420 (Pending) - Catalyst System Efficiency Below Threshold Bank 1
    Where in the world do I even begin?
  2. May 11, 2024 at 10:44 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Evap, check your intake tube and double check vacuum hoses for cracking... p0420 may be your upstream oxygen sensor driver side.
