Code reader for 2015 Tundra
Discussion in 'Performance and Tuning' started by gosolo, Aug 6, 2017.
  1. Aug 6, 2017 at 6:43 PM
    gosolo
    gosolo [OP] You Don’t Know Who I Am But I Know Where You Live
    Ray (or maybe Dale)
    NW Oregon
    What is the best code reader for my 2015 Tundra? And where should I go for the best deal on one?
  2. Aug 6, 2017 at 6:44 PM
    An issue or just to have? Ultragauge has many functions, including a code reader.
    Sunnier likes this.
  3. Aug 6, 2017 at 6:59 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    You can get a handheld or Bluetooth diagnostics reader for pretty cheap on Amazon. Otherwise usually any auto parts store will read it for you for no charge
    Sunnier and T-Rex266 like this.
  4. Aug 6, 2017 at 8:11 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    There's quite a lot to choose from, wish I knew more about the new engine diagnostics. These 3 were on Amazon prime
    Does anyone even know what a timing light or feeler gauge was? lol
    Black Wolf likes this.
  5. Aug 6, 2017 at 8:16 PM
    cheehab
    cheehab Fan Boy
    Southern Maine
    2015 TRD Pro CrewMax
    Techstream
  6. Aug 6, 2017 at 8:20 PM
    Techstream you can do more with. Ultragauge monitors fuel, intake temp, etc
    Sunnier and 14burrito like this.
  7. Aug 6, 2017 at 8:32 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    If you have a smartphone, don't waste your money on a dedicated code reader. Just get a dongle that plugs into your diagnostic port and read/reset the codes on your phone.
    Sunnier and PMG like this.
  8. Aug 6, 2017 at 9:02 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    it depends on the dongle and the app. Some of the apps are free, others charge money. Either way, yes, it will be unlocked and functional. This is the one I use. It's a little pricy but will do more than any dedicated code reader will do. Once you get it just download the BlueDriver app from the Apple App Store
    Sunnier likes this.
  9. Aug 14, 2017 at 3:30 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I ended up with this one
    It's able to do lots more than just engine codes and I don't mind that it's vehicle specific since I'm planning on the Tundra being the last one I buy. Hope it works out...
    Tundraplatinum likes this.
  10. Aug 16, 2017 at 8:04 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @bobeast or @gosolo, do your readers provide access to the dealer setup options like belt chime, DRL, etc?
  11. Aug 16, 2017 at 8:27 AM
    I've got an old Sun timing light in storage. Haven't used it in decades. Still use my old feeler gauge.
    MT Madman and gosolo[QUOTED][OP] like this.
  12. Aug 16, 2017 at 3:21 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I downloaded the users manual. It does perform some two way operations such as clearing codes, resetting the maintenance service interval, etc but it doesn't look like it provides toyota specific option programming.
    gosolo[QUOTED][OP] likes this.
  13. Aug 16, 2017 at 8:15 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    No You can clear codes and read all the codes and parameters, but can't change the options. I have a Limited so I can change most of that stuff from the dash. What I can't change with that, I can use Techstream.
    NewImprovedRon and gosolo[OP] like this.
  14. Aug 18, 2017 at 4:32 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Short review for anyone interested:
    This thing
    Loading, registering, and connecting instructions were poor and contradictory.
    Once I got through that I plugged into my truck and when prompted to enter required information: under Tundra "year" it only had 2000-2013. 2015 wasn't even an option:
    When I had to make the choice of engine from this selection I decided that this piece of crap would be returned
    If you're interested in a scan tool, skip this one.
    I'm back to square 1.
  15. Aug 18, 2017 at 7:29 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    If you buy a wireless OBDII link, makecsure it has a power switch. The first one I bought didn't and the transmitter burned out. I bought one of these and it works great. https://www.amazon.com/gp/product/B015GMRZH2/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    I also bought an extension cord for the OBDII connector so I could get to the power switch easily. https://www.amazon.com/Diageng-Prof...d=1503109308&sr=8-10&keywords=Obdii+extension
    I used it on my S-10, a lot.
    I recommend the Dash Command software if you use an Iphone. I have an od Iphone 4 that I used just for the OBDII connection. http://palmerperformance.com/products/dashcommand/iphone/index.php
    Like I said, it was a Chevy and I used it a lot.
  16. Aug 19, 2017 at 3:30 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    Autel is a great scanner. You need to update your software it comes with 1 year free updates then you be up to 2016 and some 2017 vehicles
  17. Aug 19, 2017 at 9:08 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    After another 3 hours with no success I'm returning this and stand by my evaluation. Maybe the one I received is unusual because it's defective, maybe the one you have is unusual because it's not, who knows? Customer support is virtually nonexistent, centered out of Beijing.
    15whtrd and TundraTex like this.
  18. Aug 19, 2017 at 4:08 PM
    Tundraplatinum
    2016 Platinum CM
    You install the software on computer, take memory card out of tool plug into computer. then just run the software it will tell you when its done then just put card back in scanner. I just updated mine last night. works great for quick cheap scanner , the higher end autel scanners run android and update on wifi but those are spendy my maxisys was $3600
  19. Aug 19, 2017 at 4:52 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    None of this was even suggested in the procedures either in the booklet provided or on line. I've moved on. You undoubtedly possess technical skills above mine. I'm inclined to feel strongly that if 1, they can't provide a product that self identifies and loads on start up, 2, can't write an install guide, alternatively, that accurately describes the needed steps, in order, & 3, doesn't support their product with customer service, then I would expect nothing but disappointment down the road.
    I wish I had PM'd you for help, but didn't want to impose.
    Thank you for the response!
    Sunnier likes this.
  20. Aug 19, 2017 at 9:13 PM
    DrasticDelima
    DrasticDelima New Member
    2016 Black Tundra CrewMax 4x4 Heavily Customized
    7" Lift Kit HID Light and LED Tailight Upfit Custom Venom Bumpers TRD Pro Grill Custom Armor Skid Plate LED Flood Lamps (Hideaway) - Front and Integrated Rear Bumper
    Honestly, Just buy a Mini-VCI Cable on Amazon and if you search real hard I bet you'll find a way to get Techstream. It's the easiest thing and it just kinda works. I just hooked mine up today and was off and running in very short order. If you want to know more you can PM me and I'll be happy to share what I bought etc. You can get the cable you need for less than $40 USD.
